Hi there,
i've just updated zm to 1.36.1 and now i cant see the log anymore. Is there a special option to activate it?
ZM 1.36.1 cant see log
Re: ZM 1.36.1 cant see log
How long did you wait?
I limit my logs to 1000, and still takes a couple seconds to load.
Check the limits in options - I bet yours are huge.
how long has debug been turned on? maybe turn that off for now, at least, although I don't know where they would go...
If you're on a debian type system, take a look at /var/log/zm and check sizes and permissions. www-data probably should own them.
/var/log/zm is owned by www-data.
Turning off debug not helps. I guess i have to reinstall zm
reinstall could help, but maybe just delete the existing logs would do it.
Maybe you should notice that it is a known problem with 1.36.1 and is fixed in 1.36.2.
thank you dougmccarry and iconnor.
With the 1.36.2 update the problem is solved. Thanks for your time and help
