The filter creation is not possible in Zoneminder master 1.35.21~20210317171513-focal [Solved]
bkjaya1952
Post by bkjaya1952 »
The filters can't be saved in Zoneminder master 1.35.21~20210317171513-focal
Re: The filter creation is not possible in Zoneminder master 1.35.21~20210317171513-focal
Should be fixed but packages are not building yet.
bkjaya1952
iconnor wrote: Thu Mar 18, 2021 8:54 pm Should be fixed but packages are not building yet.
Thank you for the reply sir .
I have checked with a freshly installed Zoneminder master 1.35.21~20210318092440-focal released today . Unfortunately , The filter creation problem is still there .
It was fixed after that package. Please check todays.
bkjaya1952
iconnor wrote: Fri Mar 19, 2021 1:36 pm It was fixed after that package. Please check todays.
I have checked just now with zoneminder master 1.35.21~20210319092402-focal . No luck
bkjaya1952
bkjaya1952 wrote: Fri Mar 19, 2021 3:08 pm
The error log is attached herewith please
Screenshot from 2021-03-19 22-27-58.png (370.41 KiB) Viewed 209265 times
bkjaya1952
Test run on Zoneminder master 1.35.21~20210321091944-focal
Date:- 21-3-2021 / 22:45 PM
Results:- Filter creation failed.
Error log :-
Screenshot from 2021-03-21 22-47-05.png (205.88 KiB) Viewed 209167 times
bkjaya1952
Test run on Zoneminder master 1.35.21~20210321131706-focal
Date:- 2021-3-22/ 11:03:30 AM
Error log:-
Screenshot from 2021-03-22 11-03-42.png (405.04 KiB) Viewed 209146 times
Latest should fix this.
bkjaya1952
iconnor wrote: Mon Mar 22, 2021 5:03 pm Latest should fix this.
Thank you Sir . I will check and let you know soon.
bkjaya1952
I have tested the zoneminder master 1.35.21~20210322130228-focal released about 1 hour back
Now the filters can be created with out any problem !!
Thank you very much Sir , for solving the problem ! :D :D :D
The Emailing and uploading can be done
Screenshot from 2021-03-23 00-31-16.png (292.79 KiB) Viewed 209111 times
Screenshot from 2021-03-23 00-30-36.png (251.21 KiB) Viewed 209111 times
Screenshot from 2021-03-23 00-30-53.png (276.82 KiB) Viewed 209111 times
The installation of Zoneminder seems to be simplified by eliminating the mysql configuration
https://bkjaya.wordpress.com/2021/03/23 ... cal-fossa/
Thank you again !!
