1.35.18~20210210170809-focal -problem in creating zm user and getting zm panel
bkjaya1952
Post by bkjaya1952 »
I have done a test run on Zoneminder master 1.35.18~20210210170809-focal issued yesterday using a usb camera.
When creating zmuser using the following command , there was an error as shown below
mysql -e "CREATE USER 'zmuser'@localhost IDENTIFIED BY 'zmpass';"
ERROR 1396 (HY000) at line 1: Operation CREATE USER failed for 'zmuser'@'localhost'
When ALTER is instead of CREATE , zmuser the new zmuser was created ( mysql -e "ALTER USER 'zmuser'@localhost IDENTIFIED BY 'zmpass';" )
Then I got the ZM_WEB_TITLE Login screen then stuck on the privacy screen without getting the zm panel.
Screenshot from 2021-02-11 12-08-02.png (37.28 KiB) Viewed 1300 times
Screenshot from 2021-02-11 12-08-37.png (202.35 KiB) Viewed 1300 times
Therefore I had to drop the zm database using the following command and re do the mysql zm configuration from the beginning.
mysql -e "drop database zm;"
Conclution:-
You will have to drop the exiting zm database before configuring mysql for zm
