Specified value 640x360 not in contents:
2021-01-24 17:53:34 web_php 623813 WAR Specified value 640x360 not in contents: Array( [] => Custom [176x120] => 176x120 QCIF [176x144] => 176x14 [320x240] => 320x240 [320x200] => 320x200 [352x240] => 352x240 CIF [352x480] => 352x480 [640x480] => 640x480 [640x400] => 640x400 [704x240] => 704x240 2CIF [704x480] => 704x480 4CIF [704x576] => 704x576 D1 PAL [720x480] => 720x480 Full D1 NTSC [720x576] => 720x576 Full D1 PAL [1280x720] => 1280x720 720p [1280x800] => 1280x800 [1280x960] => 1280x960 960p [1280x1024] => 1280x1024 1MP [1600x1200] => 1600x1200 2MP [1920x1080] => 1920x1080 1080p [2048x1536] => 2048x1536 3MP [2560x1440] => 2560x1440 1440p QHD WQHD [2592x1944] => 2592x1944 5MP [3840x2160] => 3840x2160 4K UHD) /usr/share/zoneminder/www/includes/functions.php 505
Is there a fix for this, or is it a bug, or?
Re: Specified value 640x360 not in contents:
Can't you enter those values manually?
Source - Capture Resolution (pixels) do not use the drop down values.
bbunge wrote: Fri Jan 29, 2021 8:23 pm Can't you enter those values manually?
I can and do enter it in the camera config page, and I would suppose that would add it to the array, but I haven't been able to figure out where it belongs.
It all seems to work OK, just annoying seeing the WAR.
Latest master will auto-add it.
