I finally got monitoring to work and now can't play any captures. I verified that the timezones match could not find anything else that might be causing the problem. I looked in the logs and now errors. I am using ZM on a raspberry so not sure if that is part of the problem.
Finally Monitoring Works now now video
Re: Finally Monitoring Works now now video
What are your storage settings?
I got it worked out. I had to upgrade raspberry and 1.35 All working!!!
now just need to figure out how to get it to move back to a preset after it has moved,
