Email fields missing
TheDamnedKirai
Post by TheDamnedKirai »
Hi all.
I'm on Zoneminder v1.35.16. Some days ago i have upgraded my ubuntu from ver 18 to 20.
After that upgrade the EMAIL_ADDRESS EMAIL_SUBJECT and EMAIL_BODY are missing from the web interface, so I am unable to configure email sending anymore (it was working before).
When I upgraded I was on a previous version, so I did like 4 upgrades to ZM but the fields never came back.
What i get is this error because I am unable to configure the recipient:
zmfilter_1[138612]: ERR [No email address defined, not sending email]
Someone knows how i can get around this?
EDIT: I already cleared browser cache and also switched browser entirely
Re: Email fields missing
Do you mean in the filter?
TheDamnedKirai
No, i mean here. In the main configuration Window that's all the fields i've got now (Options --> Email)
That all looks fine.
TheDamnedKirai
As you can see here:
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
In the EMAIL_ADDRESS field enter the email address you want to get these alarms
EMAIL_SUBJECT and EMAIL_BODY are self explanatory
As you can see those fields are completely missing for me, and if I add the recipient email address in the message_address is doesn't works and throws the error I said in the main topic.
It seems that only configuration options for message are present, and not those for email except:
FROM_EMAIL
EMAIL_HOST
so those are definitely missing:
EMAIL_ADDRESS
EMAIL_SUBJECT
EMAIL_BODY
That part doesn't send messages. Look under filters.
Screenshot 2021-01-02 at 16.19.23.png (63.75 KiB) Viewed 1427 times
To save me the thousand words.
TheDamnedKirai
Thanks, I should have forgot that part.
Solved! :)
