Scaling feature in Zones and Pre-set configuration screen [Solved]
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
pankaj13
Post by pankaj13 »
Just like the scale feature we have in Montage and Camera view (3x, 2x, 1/2x, 14x and so on). It will be great to have similar scaling functionality in the view of Zone and presets. Usually the Zone and presets are much larger with high res camera and the only way is to use CTRL - to zoom out using browser feature then zoom back up once you are back to cosole.
My two cents.....
Re: Scaling feature in Zones and Pre-set configuration screen
already implemented in master.
pankaj13
Re: Scaling feature in Zones and Pre-set configuration screen [Solved]
Post by pankaj13 »
@iconnor Thanks :)
