I am interested in the topic discussed in this 15 year old post:
viewtopic.php?t=4567
I am using v1.32.3 installed from using the instructions from the PPA https://launchpad.net/~iconnor/+archive ... inder-1.32
Was this feature request ever implemented?
I have many cameras that support uploading events (motion detection, etc) using FTP, and many of these cameras are behind firewalls etc where I cannot or do not want to expose their ports on the internet, the obvious solution is to upload using FTP to a directory and let ZM peruse them there.
Is this possible?
FTP upload from camera
Re: FTP upload from camera
Sure. Source Type has a File option. Have never used it but it should work.
TYVM for the sanity inducing reply. Face palm, now having found the Source type things are getting there, though I have other issues now, the docs for those wondering in that I have found are here:
https://wiki.zoneminder.com/index.php/H ... ly_support
of note, it is failing for me with errors in the log such as:
it is of note that I got around the issue of having multiple files and used inotfiywatch:
the file is a jpeg:
and it is owned by www-data:
2020-01-08 13:06:11.400900 zmdc 30217 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-01-08 13:06:11.353021 zma_m1 21669 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2020-01-08 13:06:11.274770 zmdc 21669 INF 'zma -m 1' started at 20/01/08 19:06:11 zmdc.pl
2020-01-08 13:06:11.274770 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:06:11, pid = 21669 zmdc.pl
2020-01-08 13:06:11.218550 zmdc 30217 INF 'zmc -m 1' exited normally zmdc.pl
2020-01-08 13:06:11.180834 zmc_m1 21012 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2020-01-08 13:06:11.148270 zmdc 30217 INF 'zmc -m 1' sending stop to pid 21012 at 20/01/08 19:06:11 zmdc.pl
2020-01-08 13:06:11.074610 zmdc 30217 INF 'zma -m 1' exited, signal 14 zmdc.pl
2020-01-08 13:06:11.042150 zmdc 30217 INF 'zma -m 1' sending stop to pid 21475 at 20/01/08 19:06:11 zmdc.pl
2020-01-08 13:06:10.940980 zmwatch 30409 INF Restarting capture daemon for Monitor-1, no image since startup. Startup time was 1578510360 - now 1578510370 > 5 zmwatch.pl
2020-01-08 13:06:08.034020 zmdc 21475 INF 'zma -m 1' started at 20/01/08 19:06:08 zmdc.pl
2020-01-08 13:06:08.033490 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:06:08, pid = 21475 zmdc.pl
2020-01-08 13:06:07.870620 zmdc 30217 INF Starting pending process, zma -m 1 zmdc.pl
2020-01-08 13:06:02.223960 zmfilter_2 30373 INF Checking filter Update DiskSpace update disk space returned 0 events zmfilter.pl
2020-01-08 13:06:00.858821 zmc_m1 21012 INF Starting Capture version 1.32.3 zmc.cpp 223
2020-01-08 13:06:00.748510 zmdc 30217 INF 'zmc -m 1' starting at 20/01/08 19:06:00, pid = 21012 zmdc.pl
2020-01-08 13:06:00.748380 zmdc 21012 INF 'zmc -m 1' started at 20/01/08 19:06:00 zmdc.pl
2020-01-08 13:06:00.708160 zmdc 30217 INF Starting pending process, zmc -m 1 zmdc.pl
2020-01-08 13:05:57.673090 zmdc 30217 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-01-08 13:05:57.640839 zma_m1 20765 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2020-01-08 13:05:57.522580 zmdc 20765 INF 'zma -m 1' started at 20/01/08 19:05:57 zmdc.pl
2020-01-08 13:05:57.522570 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:05:57, pid = 20765 zmdc.pl
2020-01-08 13:05:57.343320 zmdc 30217 INF Starting pending process, zma -m 1 zmdc.pl
2020-01-08 13:05:55.367110 zmfilter_1 30342 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
2020-01-08 13:05:52.306170 zmdc 30217 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-01-08 13:05:52.198652 zma_m1 20430 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2020-01-08 13:05:52.121290 zmdc 20430 INF 'zma -m 1' started at 20/01/08 19:05:52 zmdc.pl
2020-01-08 13:05:52.121280 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:05:52, pid = 20430 zmdc.pl
2020-01-08 13:05:52.029750 zmdc 30217 INF Starting pending process, zma -m 1 zmdc.pl
2020-01-08 13:05:50.997100 zmdc 30217 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-01-08 13:05:50.932288 zma_m1 20403 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2020-01-08 13:05:50.855220 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:05:50, pid = 20403 zmdc.pl
2020-01-08 13:05:50.855220 zmdc 20403 INF 'zma -m 1' started at 20/01/08 19:05:50 zmdc.pl
2020-01-08 13:05:50.807910 zmdc 30217 INF 'zmc -m 1' exited normally zmdc.pl
2020-01-08 13:05:50.719792 zmc_m1 19378 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2020-01-08 13:05:50.695090 zmdc 30217 INF 'zmc -m 1' sending stop to pid 19378 at 20/01/08 19:05:50 zmdc.pl
2020-01-08 13:05:50.620990 zmdc 30217 INF 'zma -m 1' exited, signal 14 zmdc.pl
2020-01-08 13:05:50.583700 zmdc 30217 INF 'zma -m 1' sending stop to pid 19455 at 20/01/08 19:05:50 zmdc.pl
2020-01-08 13:05:50.478950 zmwatch 30409 INF Restarting capture daemon for Monitor-1, no image since startup. Startup time was 1578510335 - now 1578510350 > 5 zmwatch.pl
2020-01-08 13:05:36.596040 zmdc 19455 INF 'zma -m 1' started at 20/01/08 19:05:36 zmdc.pl
2020-01-08 13:05:36.596030 zmdc 30217 INF 'zma -m 1' starting at 20/01/08 19:05:36, pid = 19455 zmdc.pl
2020-01-08 13:05:36.561730 zmdc 30217 INF Starting pending process, zma -m 1 zmdc.pl
2020-01-08 13:05:35.647981 zmc_m1 19378 INF Starting Capture version 1.32.3 zmc.cpp 223
2020-01-08 13:05:35.520190 zmdc 30217 INF 'zmc -m 1' starting at 20/01/08 19:05:35, pid = 19378 zmdc.pl
2020-01-08 13:05:35.520190 zmdc 19378 INF 'zmc -m 1' started at 20/01/08 19:05:35 zmdc.pl
2020-01-08 13:05:35.462290 zmdc 30217 INF Starting pending process, zmc -m 1 zmdc.pl
2020-01-08 13:05:31.887240 zmdc 30217 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-01-08 13:05:31.855363 zma_m1 19116 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2020-01-08 13:05:31.736870 zmdc 19116 INF 'zma -m 1' started at 20/01/08 19:05:31 zmdc.pl
#!/bin/bash
: ${WATCHER_DEBUG:=false}
WATCH_DIR=$1
echo "Watching $WATCH_DIR on $(hostname)"
inotifywait -m $WATCH_DIR -e close_write -e moved_to |
while read path action file; do
echo "The file '$file' appeared in directory '$path' via '$action'"
FILE_TYPE=$( file -b $path$file|cut -f1 -d, )
this_uuid=$(uuidgen -r)
if [[ $FILE_TYPE == "JPEG image data" ]]; then
chown www-data. $path$file /storage/zmwatch/camera1-sputnik.jpg
chmod 775 $path$file /storage/zmwatch/camera1-sputnik.jpg
ln -f $path$file /storage/zmwatch/camera1-sputnik.jpg
else
echo -n "file type was '$FILE_TYPE', "
echo -n "$file Not JPEG, "
if [[ $WATCHER_DEBUG == true ]]; then
echo "retaining in tmp for further inspection. "
else
echo -n "throwing away. "
rm -v $path$file
fi
fi
done
/storage/zmwatch/camera1-sputnik.jpg: JPEG image data, JFIF standard 1.01, aspect ratio, density 1x1, segment length 16, Exif Standard: [TIFF image data, big-endian, direntries=3, datetime=2020:01:08 03:33:00], baseline, precision 8, 640x352, frames 3
ls -alh /storage/zmwatch/camera1-sputnik.jpg
-rwxrwxr-x 2 www-data www-data 30K Jan 8 19:13 /storage/zmwatch/camera1-sputnik.jpg
I am looking for a free surveillance software to browse ftp uploads from my cameras. I don't want to run a surveillance software 24/7 on a dedicated computer to read video streams from the cameras and write where ever it needs to be stored, but the motion detection of the cameras is OK for me and the cameras currently write only if needed. My cameras write pictures and videos to a Synology NAS via ftp. I think Synology surveillance stations is not what I need: it has only 2 free licenses and it would monitor the cameras all the time.
Most of my cameras are reolink cameras, so I can use the reolink windows client to browse the files on the SD cards of the cameras. In most cases this is OK. But I can't use the client to browse ftp uploads.
Reading this thread here it looks like I could use ZM on top of the FTP files as a surveillance software "on demand"? Or are there any other ideas to comfortable browse ftp uploads in a timeline and with some surveillance features?
