Lots of single frame sections
Thinqer
Post by Thinqer »
I'm running ZM 1.32.3 on Ubuntu 18.04 with 5 IP cameras (all wired) all from different manufacturers but mostly set up in ZM as ONVIF on port 554. I've noticed that two of my cameras have multiple single frame sections/events even though they're set to record continuously for 30 minute sections - see attached for two screen grabs from the events log for each camera to illustrate what I mean
These single frame sections seem to happen almost every other one, but not quite.
The cameras are both set up similarly:
  • One is Mocord the other is Record
  • Both are Ffmpeg
  • Both TCP on port 554 (default admin user and ONVIF password discovered via iSpy IIRC)
  • Both 1920x1080
  • Both X264 Encode
  • Both have default Buffers settings
  • Neither have any Control set
  • Both set to record for 1800 second sections
Does anyone have any ideas what could be causing this behaviour or how to fix it?
Happy to share any other things with you but am not sure what would be useful - please just ask.
Many thanks in advance,
Ben.
deanzm
Re: Lots of single frame sections
Post by deanzm »
Hi Thinqer, I'm seeing the exact same thing. Were you able to get this fixed?
