Foscam FI9821P (ptz ; indoor ; ircut ; HD)
vox
Post by vox »
Source in english or in french.
Tested on ZM 1.30
Default login : admin
Default password : nothing
WARNING : THE WEBUI OF THE FI9821P NOT WORKING ANYMORE !
  • You can just change the main (root) login and password, after a RESET and only via Internet Explorer. Others options and parameter are not accessible ! You can't watch your cam via the WEBUI, you need use ZM, VLC or other external software.
Read the stream with VLC
  • rtsp://LOGIN:PASSWORD@IP_ADDRESS:554/videoMain (audio available)
    rtsp://LOGIN:PASSWORD@IP_ADDRESS:554/videoSub (audio available)
    rtsp://LOGIN:PASSWORD@IP_ADDRESS:554/audio (not working)
Add the camera on ZoneMinder
  • remote protocol: RTSP
    Remote Method : RTSP/Unicast
    Remote Host Name : LOGIN:PASSWORD@Camera_IP (if you can don't use admin user !)
    Remote Host Port : camera port (default : 554)
    Remote Host Path : /videoMain
    Capture Width (pixels) : 1280
    Capture Height (pixels) : 720
Add PTZ control on ZoneMinder
  1. If you can, go to your camera WEBUI and creat a dedied "operator" user (never use an admin user with an uncrypted communication)
  2. Go to ZoneMinder Webui and connect to admin account.
  3. Go to Options => System => select OPT_CONTROL and save.
  4. Restart ZoneMinder
  5. Now go to your foscam parameters in Control tabs and configure it :
    • Controllable : select this case
      Control Type : Foscam FI9821W
      Control Device : USER:PASSWORD
      Control Address : IP_Address:88
      Track Motion : don't select (not working)
      Return Location : preset 1
      • screenshot-2017_11_06-ZoneMinder-add_camera_foscam_FI9821P_controle_ptz.png
Pics
Relative Link
alabamatoy
Re: Foscam FI9821P (ptz ; indoor ; ircut ; HD)
Post by alabamatoy »
Error in step 5 of the PTZ setting - for the control address setting, mine would not work with hostname:88, it worked with hostname:87.
The pan and tilt seem to work, but the zoom does not. When I select zoom tele, it changes the white balance, same for the zoom wide. The other controls - focus, white, iris and the presets - do nothing.
