I have grey video in BW or red video in color, but can see clock ticking
I'm using zmodopipe
What's wrong in setting ? Anybody help?
grey video but has clock ticking?
- no_video.jpg (57.46 KiB) Viewed 3763 times
Re: grey video but has clock ticking?
May be that you do not have the resolution set right. The WxH settings in ZM need to match the camera output exactly.
Please tell us a bit more about your system (Linux version) and camera.
Camera is zmodo DVR so it's buffered using zmodopipe under linux
(viewtopic.php?t=18137)
See below for ffmpeg output
# ffmpeg -i /tmp/zmodo2 -vn -vcodec copy -y camera.mp4
ffmpeg version 3.1.3-1~bpo8+1 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.9.2 (Debian 4.9.2-10)
configuration: --prefix=/usr --extra-version='1~bpo8+1' --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --disable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librubberband --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-chromaprint --enable-libopencv --enable-libx264
libavutil 55. 28.100 / 55. 28.100
libavcodec 57. 48.101 / 57. 48.101
libavformat 57. 41.100 / 57. 41.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 47.100 / 6. 47.100
libavresample 3. 0. 0 / 3. 0. 0
libswscale 4. 1.100 / 4. 1.100
libswresample 2. 1.100 / 2. 1.100
libpostproc 54. 0.100 / 54. 0.100
[h264 @ 0x1971120] Invalid NAL unit 0, skipping.
[h264 @ 0x1971120] FMO not supported
Last message repeated 1 times
[h264 @ 0x1971120] top block unavailable for requested intra mode
[h264 @ 0x1971120] error while decoding MB 0 0
[h264 @ 0x1971120] concealing 330 DC, 330 AC, 330 MV errors in P frame
[h264 @ 0x1971120] sps_id 4 out of range
[h264 @ 0x1971120] sps_id 3 out of range
[h264 @ 0x1971120] sps_id 2 out of range
[h264 @ 0x1971120] chroma_log2_weight_denom 9 is out of range
Last message repeated 4 times
[h264 @ 0x1971120] luma_log2_weight_denom 10 is out of range
[h264 @ 0x1971120] luma_log2_weight_denom 8 is out of range
[h264 @ 0x1971120] reference overflow (pps)
Invalid UE golomb code
[h264 @ 0x1971120] pps_id 3199971767 out of range
Input #0, h264, from '/tmp/zmodo2':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p, 352x240, 25 fps, 25 tbr, 1200k tbn, 50 tbc
Output #0, mp4, to 'camera.mp4':
