I have a Montage view issue with zmNinja. I am using 4 identical cameras (Foscam FI9853EP) and montage view is strange on my Pixel C (see attached file).
I couldn't make the same view on my phone as it's only a Full-HD display.
Regards,
Arnaud
zmNinja - Montage view issue (1.0.5)
- Strange Montage view
- Screenshot_20160125.png (626.58 KiB) Viewed 3728 times
Brave old Desktop (Ubuntu14.04 - ZM1.29.0 - ZMNinja)
Re: zmNinja - Montage view issue (1.0.5)
Oups, my fault, I forgot to toc the "3 dots" on the right position.
But "vertical" view remains strange...
- Normal view
- Screenshot_20160125-2.png (824.58 KiB) Viewed 3726 times
Hi, yes, zmNinja has two modes of display:
a) Arrange by row (horizontal dots) (usually better with similar sized monitors)
b) Arrange by columns (vertical dots) (usually better with dissimilar sized monitors)
You should choose one that works best for your dimensions of cameras. Here is how it works: when you move the slider,
Mode a) arranges the images horizontally till columns are filled (canvas width) and then moves to the next row.
Mode b) arranges the images vertically - in this mode it will ensure the number of columns are maintained that you selected but will keep laying images vertically till it runs out of height (canvas height) - so it will move to the next column either when height runs out, or if it needs to move to the next column to maintain the column size you selected
I like column mode because it allows images to be tightly packaged as its aligning according to column, but given your # of monitors or size, it can look odd at times, so I offered both.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
