Axis 221 IP camera
Axis 221 IP camera
i need the Remote Host Path: of axis 221 IP camera. as i find the wiki not supported Axis 221 IP camera. i have 32 axis 221 IP camras. and i want to run it on ZoneMinder please help me.
Re: Axis 221 IP camera
From an old post in 2011: Remote Host Path /axis-cgi/mjpg/video.cgi?resolution=320x240&compression=20
Give a try anyway
Give a try anyway
As above id be amazed if an axis camera wasnt compatible. Just be careful with the maxfps string. If its not supported in the firmware then it may cause the camera to provide no image. Remove that from the default axis string and you should be fine. to test start with jpeg and work up from there
James Wilson
Thanks you for updating us with this interesting information. you did very great job. keep it up Hope you will share more ideas and pictures, I wish you good luck
"ONe Day I will be Part of your World.")
