My PC configuration and question
hk_niko
Post by hk_niko »
Hi all
I am writing my hardware configuration and some work on the software that I have made successfully.
Mainboard: Asus Formula 3 am +
CPU: AMD x4 phenom2 3.2 [overclocked 3.5]
RAM: 4gb ddr3 1067 corsair [replace with 16gb ddr3 1600]
HHD: Seagate 1T [short replace it with a ssd and saegate use him for the 'upload].
I changed mysql [my.cnf] adding connections and increasing other parameters [buffer and the like]. I also changed the parameters of Firefox for viewing and added the parameter kernel.shmmax (as explained in the main documentation). I made changes to the skins to set it for my pleasure.
Now I can hold onto 50 Monitor [352 * 288 | 640 * 288 {mobotix etc.} ] in Modect, also all in montage. The system load is approximately 13% and is equal to 3.2GB Ram busy, I have a problem with sleeping processes that I also deal with a lot of swap (and I do not know how to finish it, I would create a script for this).
I'll have to try adding another monitor to test the PC.
I would like to add other types of opencv video analysis, but also start using the X10 but do not know where to start.
Tips?
