Not show the events
Not show the events
Greetings,
I´m new here, and a novice user Linux and ZM...
After instalation and basic´s uses, I can´t view the record event´s. When I click on the event, not show anything, have images, but dont play anything.
Somebody have a tip for correct show the record?
and another question: How to record only moviments? I like when stay moviment off, not record anything.
Thanks.
Marcos Francisconi
Using: Ubuntu 10.10 and ZM 1.24.2
Thanks.
Marcos Francisconi
Re: Not show the events
This is the problem...
never show anything.!
- ScreenShot003.JPG (89.43 KiB) Viewed 6516 times
Somebody have any ideia ?
I'm try this but dont solve my problem:
The other common cause for being unable to view streams is that you have installed the ZoneMinder cgi binaries (zms and nph-zms) in a different directory than your web server is expecting. Make sure that the --with-cgidir option you use to the ZoneMinder configure script is the same as the CGI directory configure for your web server. If you are using Apache, which is the most common one, then in your httpd.conf file there should be a line like
where the last directory in the quotes is the one you have specified. If not then change one or the other to match. Be warned that configuring apache can be complex so changing the one passed to the ZoneMinder configure (and then rebuilding and reinstalling) is recommended in the first instance. If you change the apache config you will need to restart apache for the changes to take effect. If you still cannot see stream reliably then try changing Options->Paths->ZM_PATH_ZMS to just use zms if nph-zms is specified, or vice versa. Also check in your apache error logs.
In your capture of the events window, seems that all the events are null events (no frames), so maybe you have to solve this problem before. Are you able to see the events in the database using phpmyadmin?.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
My phpmyadmin not run! I'm input on browser "localhost/phpmyadmin" e not show anything.
The message say: Not possible load that page.
I´m re-install with apt-get install phpmyadmin but not run yet.
What hell is going on?
PacoLM suggested the answer and he nailed it exactly: you aren't recording anything! Your .png shows null events (empty), so you'll need to look in log files to see what's the problem. If they don't give you the answer then enable debug to a level that will. Debug is in the config menu's.
I'm recording, belive this. I'm navigate to folder and I see all events, have over than 1000 events, but only images statics...
I suspicious that my database sql is corrupt.
I will verify the debug, and after I post here that conclusion. Thanks a lot.
I,m re-install all again, and no success! Where I'm config to show events recorded???
See that printscreen's of my system.
- Captura_de_tela-1.jpeg (90.91 KiB) Viewed 6470 times
- Captura_de_tela.jpeg (93.12 KiB) Viewed 6470 times
This is my httpd.conf:
ScriptAlias /cgi-bin/ "/cgi-bin/nph-zms"
Alias /zm /usr/share/zoneminder
<Directory /usr/share/zoneminder>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
I'm try this too on the FAQ:
Why can't I see streamed images when I can see stills in the Zone window etc?
2) The other common cause for being unable to view streams is that you have installed the ZoneMinder cgi binaries (zms and nph-zms) in a different directory than your web server is expecting. Make sure that the --with-cgidir option you use to the ZoneMinder configure script is the same as the CGI directory configure for your web server. If you are using Apache, which is the most common one, then in your httpd.conf file there should be a line like
And this too:
Why am I getting broken images when trying to view events?
Zoneminder and the Apache web server need to have the right permissions. Check this forum topic and similar ones: http://www.zoneminder.com/forums/viewto ... 8754#48754
</IfModule>
</Directory>
And this too:
Forget phpmyadmin. It's pointless.
Increase buffers.
- Buffers must be higher for than the sum of other buffers.
- buffers.png (20.21 KiB) Viewed 6452 times
Are you storing the events in the default location?
I'm try change buffer, but not run yet.
I think my solution is same this:
but my http.conf is empty, and my apache2.conf not have anything that have on this solution topic.
I'm using ubuntu 10.10.
I'm going crazy with this zoneminder...
Did you check the default-server.conf (if you have this file)? Your link says that's where they added the fix in SuSE 10.3, ZM 1.23.3.
I found it in the default-server.conf, it had a 'none' after Options, I just added the 'Indexes FollowSymLinks' saved it, then restarted zm, mysql and apache2. Worked beautifully aftewords.
What is "default-server.conf"??? I'm don't have this file, but I have apache2.conf
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "foo.log"
# with ServerRoot set to "/etc/apache2" will be interpreted by the
# server as "/etc/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs/2.2/mod/mp ... l#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
LockFile ${APACHE_LOCK_DIR}/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
MaxRequestsPerChild 0
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadLimit: ThreadsPerChild can be changed to this maximum value during a
# graceful restart. ThreadLimit can only be changed by stopping
# and starting Apache.
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
</IfModule>
# event MPM
<IfModule mpm_event_module>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include mods-enabled/*.load
Include mods-enabled/*.conf
# Include all the user configurations:
Include httpd.conf
# Include ports listing
Include ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include conf.d/
# Include the virtual host configurations:
Include sites-enabled/
# the directives.
Timeout 300
KeepAlive On
KeepAliveTimeout 15
# prefork MPM
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
</IfModule>
# worker MPM
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
</IfModule>
# event MPM
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
</IfModule>
# directive.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# text.
# nameserver.
HostnameLookups Off
# alert, emerg.
LogLevel warn
Include httpd.conf
Include ports.conf
Include conf.d/
