H.264 Camera Distortion Periodically
joako
Post by joako »
I have setup a generic IP camera that seems to work OK. However in Zoneminder I am forced to use the source type Ffmpeg because that camera sends non-hexadecimal characters in the RTSP session ID and Zoneminder only expects hexidecimal in that field, so I do not have the setting Source: Remote + RTSP to compare with.
When I use the Ffmpeg source the image sometimes is OK but sometimes it is not and half of the image is distorted badly. How can I resolve this? The camera always views OK through its web-interface. I have attached and example frame. This will go on continuously for minutes.
Ehover_India
Re: H.264 Camera Distortion Periodically
Post by Ehover_India »
Hi....
till now no problem all good
I have enabled authentication in zoneminder and restarted
Now I am also facing same problem
I use very less resolution (320x240) and whole image gets distortion
please give any suggestion.....
stenny73
Post by stenny73 »
Hello
i have this Problem on wansview when i Insert in Maximum FPS or Alarm Maximum FPS any fps.
do insert nothing in Maximum FPS or Alarm Maximum FPS
(sorry for my english)
stenny
Here are my comments from the ZM 1.26.4 area:
I had this same issue with ZM 1.25.0 and my recent upgrade to 1.26.4. Running Ubuntu 12.04 LTS. I actually rebuilt the server with a fresh Ubuntu 12.04 Server, X264 and ZM 1.26.4 from the Launchpad repository (see my how to in the Ubuntu specific area of the WIKI). I have 11 Linksys IP cameras, 1 Vivotek IP camera, and 1 Logitech USB camera on a Core 2 Duo, 2.66 MHZ with 8 GIG RAM. The Vivotek was running on FFMPEG H.264 stream and recording smeared images every two minutes or so.
Earlier tonight I switched the Source to Remote
Remote Protocol: RTSP
Remote Method: RTP/RTSP
Remote Host Name: IP of camera
Remote Host Port: 554
Remote Host Path: set to the H.264 camera stream setting
Happy to report it has been over two hours with no smeared images! Only things that move get recorded.
bb
