Trouble Compling ZoneMinder 1.25.X from Source/Ubuntu 12.04
metallica1973
Post by metallica1973 » Wed Oct 17, 2012 1:08 am
I orginally installed Zoneminder 1.25.X on Ubuntu 12.04 using there repositories and ran into a roadblock using the Bluecherry BC-08240A - 8 port video, 8 port audio realtime hardware compression card. The card requires the solo6010-dkm driver which uses ('extended' layouts)
http://community.bluecherrydvr.com/resp ... sion_cards
I am able to see the video inputs(8,9 respectively) and the capture palette(UYVY [UYUV 4:2:2 Packed, UYVY]) on the card
[0xb5000960] v4l2 demux debug: trying kernel V4L2
[0xb5000960] v4l2 demux debug: device Softlogic 6010 using driver solo6x10 (version 2.4.3) on PCI 0000:0a:09.0
[0xb5000960] v4l2 demux debug: the device has the capabilities: 0x05000001
[0xb5000960] v4l2 demux debug: (X) Video Capture, ( ) Audio, ( ) Tuner, ( ) Radio
[0xb5000960] v4l2 demux debug: (X) Read/Write, (X) Streaming, ( ) Asynchronous
[0xb5000960] v4l2 demux debug: video input 0 (Camera 1) has type: External analog input *
[0xb5000960] v4l2 demux debug: video input 1 (Camera 2) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 2 (Camera 3) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 3 (Camera 4) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 4 (Camera 5) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 5 (Camera 6) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 6 (Camera 7) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 7 (Camera 8) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 8 (Multi 4UP-1) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 9 (Multi 4UP-2) has type: External analog input
[0xb5000960] v4l2 demux debug: input set to 0
[0xb5000960] v4l2 demux debug: device supports chroma UYVY [UYUV 4:2:2 Packed, UYVY]
[0xb5000960] v4l2 demux debug: boolean Motion Detection Trace (08000002)
[0xb5000960] v4l2 demux debug: current: false, default: false
[0xb5000960] v4l2 demux debug: found default width and height of 704x480
this being said and finding a solution to my issue:
http://www.zoneminder.com/forums/viewto ... tch#p76736
I decided to recompile my version of Zoneminder with the adjustment made in the post above. I made most of the changes and have wrestled around with my compile errors and am stuck here:
export CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}";/opt/zm# ./configure --prefix=/usr --with-webdir=/var/www/zm --with-cgidir=/opt/zm/cgi-bin
/opt/zm#make
zm_jpeg.o -MD -MP -MF .deps/zm_jpeg.Tpo -c -o zm_jpeg.o zm_jpeg.cpp
mv -f .deps/zm_jpeg.Tpo .deps/zm_jpeg.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS   -g -O2 -MT zm_local_camera.o -MD -MP -MF .deps/zm_local_camera.Tpo -c -o zm_local_camera.o zm_local_camera.cpp
mv -f .deps/zm_local_camera.Tpo .deps/zm_local_camera.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS   -g -O2 -MT zm_monitor.o -MD -MP -MF .deps/zm_monitor.Tpo -c -o zm_monitor.o zm_monitor.cpp
zm_monitor.cpp: In member function ‘virtual void MonitorStream::runStream()’:
zm_monitor.cpp:3479:14: warning: variable ‘frame_sent’ set but not used [-Wunused-but-set-variable]
mv -f .deps/zm_monitor.Tpo .deps/zm_monitor.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS   -g -O2 -MT zm_ffmpeg.o -MD -MP -MF .deps/zm_ffmpeg.Tpo -c -o zm_ffmpeg.o zm_ffmpeg.cpp
mv -f .deps/zm_ffmpeg.Tpo .deps/zm_ffmpeg.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS   -g -O2 -MT zm_mpeg.o -MD -MP -MF .deps/zm_mpeg.Tpo -c -o zm_mpeg.o zm_mpeg.cpp
zm_mpeg.cpp: In member function ‘void VideoStream::OpenStream()’:
zm_mpeg.cpp:179:30: error: too few arguments to function ‘int avcodec_open2(AVCodecContext*, AVCodec*, AVDictionary**)’
/usr/include/libavcodec/avcodec.h:4074:5: note: declared here
zm_mpeg.cpp:244:27: error: too few arguments to function ‘int avformat_write_header(AVFormatContext*, AVDictionary**)’
/usr/include/libavformat/avformat.h:1662:5: note: declared here
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:386:77: error: ‘av_rescale_q’ was not declared in this scope
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/opt/zm/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/zm'
make: *** [all] Error 2
I made most of the changes to the depriecated functions to what was replaced and now I get the above error messages in reference to:
What do I need to do to get this to successfully compile? Should I downgrade "FFMPEG" to an older version that used the previous funtions that I had changed? What version of FFMPEG does Zoneminder 1.25.X use?
kamil
Re: Trouble Compling ZoneMinder 1.25.X from Source/Ubuntu 12
Post by kamil » Wed Oct 17, 2012 8:09 am
try using this to compile,
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin \
ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser \
ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl --enable-debug=no \
--with-webgroup=www-data --with-webuser=www-data --enable-mmap CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"  CPPFLAGS=-D__STDC_CONSTANT_MACROS
metallica1973
Post by metallica1973 » Thu Oct 18, 2012 12:33 am
thanks,
makes no difference.
PacoLM
Post by PacoLM » Thu Oct 18, 2012 7:15 am
Try this:
## link for ffmpeg 0.6.5 http://ffmpeg.org/download.html
cd /usr/src
wget http://ffmpeg.org/releases/ffmpeg-0.6.5.tar.gz
tar -xzvf ffmpeg-0.6.5.tar.gz
cd /usr/src/ffmpeg-0.6.5
./configure --prefix=/usr --enable-shared --enable-gpl --enable-pthreads --enable-nonfree --disable-stripping --enable-avfilter --enable-version3
make -j3
make install
make install-libs
cd /lib && ln -s /usr/local/lib/libswscale.so.0 && ln -s /usr/local/lib/libavformat.so.52 && ln -s /usr/local/lib/libavcodec.so.52 && ln -s /usr/local/lib/libavutil.so.50 && \
ln -s /usr/local/lib/libavdevice.so.52
ldconfig
If you get errorr while compiling/making ZM, then try this:
cd /usr/src/zm (put here your zm source path)
wget http://ab-log.ru/files/File/zm-patch.zip
unzip zm-patch.zip
patch -p1 < zm-patch.diff
Post results, hope it helps,
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
metallica1973
Post by metallica1973 » Fri Dec 14, 2012 3:03 pm
Many Thanks for the reply. I will give this a shot and give you some feedback.
chriswiggins
Post by chriswiggins » Sat Dec 15, 2012 4:14 am
There is actually a patch that someone has submitted to launchpad that seems to fix the issue. I used it the other day to compile ZoneMinder 1.25.X for the first time ever on Ubuntu!
I will write a how-to and get back to you soon. Probably within the next week :-)
chriswiggins
Post by chriswiggins » Sat Dec 15, 2012 4:42 am
OK I have already done it :-)
http://www.zoneminder.com/wiki/index.ph ... rom_source
Give it a go and let me know how you get on.
Chris
Users browsing this forum: No registered users and 0 guests
