Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libphp-serialization-perl
The following NEW packages will be installed:
libphp-serialization-perl zoneminder
0 upgraded, 2 newly installed, 0 to remove and 4 not upgraded.
Need to get 1,626kB of archives.
After this operation, 7,070kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1
http://us.archive.ubuntu.com/ubuntu/ lucid/universe libphp-serialization-perl 0.33-1 [10.8kB]
Get:2
http://us.archive.ubuntu.com/ubuntu/ lucid/universe zoneminder 1.24.2-2build3 [1,615kB]
Fetched 1,626kB in 1s (1,086kB/s)
Selecting previously deselected package libphp-serialization-perl.
(Reading database ... 277933 files and directories currently installed.)
Unpacking libphp-serialization-perl (from .../libphp-serialization-perl_0.33-1_all.deb) ...
Selecting previously deselected package zoneminder.
Unpacking zoneminder (from .../zoneminder_1.24.2-2build3_amd64.deb) ...
Processing triggers for man-db ...
Processing triggers for ureadahead ...
Setting up libphp-serialization-perl (0.33-1) ...
Setting up zoneminder (1.24.2-2build3) ...
Starting ZoneMinder: Can't open config file '/usr/local/etc/zm.conf': No such file or directory at /usr/local/share/perl/5.10.1/ZoneMinder/Config.pm line 100
BEGIN failed--compilation aborted at /usr/local/share/perl/5.10.1/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/local/share/perl/5.10.1/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/local/share/perl/5.10.1/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: error processing zoneminder (--configure):
subprocess installed post-installation script returned error exit status 2
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
