Installation error in CentOS 5.5
- Contact:
Fedora is very similar to CentOS. If you'd like to stay with redhat releases like CentOS or Fedora, check out my latest post for an easy (easier?) install on Fedora14.
It's all done with YUM. No need to compile anything manually. Not perfect but I hope it helps someone.
-Steve in Phx.
-Steve in Phx.
-Steve in Phx.
I have managed to install ZM with out any ffmpeg installed but when Ive install either version 0.5 or 0.6 I end up with errors during the make command still, and the error message saying to inform ZM about the ffmpeg libs being present but not usable.
[/code]
[root@localhost ZoneMinder-1.24.2]# ./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-libarch option.
This tells configure where to find architecture specific libraries.
The default of 'lib' is usually ok but 64 bit machines may require lib64.
e.g. --with-libarch=lib or --with-libarch=lib64
configure: WARNING: You can call configure with the --with-mysql option.
This tells configure where to find the MySql C library and headers if configure cannot
locate them automatically.
e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-ffmpeg option.
This tells configure where to find the ffmpeg root directory within which are the libavcodec
and libavformat files that can be used to build true MPEG streaming into ZoneMinder. Ensure that
your copy of ffmpeg has installed libraries as well as binaries (use 'make installlib'). If you
are using a local install of ffmpeg you may have to remove or rename a previous real installation
as the headers and libraries from that will probably be picked up before your local copy.
e.g. --with-ffmpeg=/usr/local
configure: WARNING: You can call configure with the --with-extralibs option.
Ordinarily you will need to use this option only when your copy of ffmpeg has been built
with support for additional formats and you would use this option to detail which additional
libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
You will need to wrap this option in quotes if it contains any spaces.
e.g. --with-extralibs="-lmp3lame"
configure: WARNING: You can call configure with the --with-webuser option.
This tells configure what the user name of the web user is if it is not the default of 'apache'.
e.g. --with-webuser=apache or --with-webuser=web
configure: WARNING: You can call configure with the --with-webgroup option.
This tells configure what the group name of the web group is if it is not the default of 'apache'.
e.g. --with-webgroup=apache or --with-webgroup=web
configure: WARNING: You can call configure with the --enable-debug=<yes> or --disable-debug option.
This tells configure whether to compile ZoneMinder with debug included. Although debug is included
by default it is not output unless explicitly switched on elsewhere. These checks may induce a
small penalty on performance and if you are after squeezing the maximum possible performance out
of ZoneMinder you may use this switch to prevent debug from being compiled in.
e.g. --enable-debug=yes or --disable-debug
configure: WARNING: You can call configure with the --enable-crashtrace=<yes> or --disable-crashtrace option.
This tells configure whether to compile ZoneMinder with crash tracing included. This allows a
dump of the stack trace when a ZoneMinder binary crashes or is killed by an unexpected signal.
Although this should work on most systems it does rely on un(or loosely) documented features and
so should be regarded as experimental. If you experience problems compiling zm_signal.cpp or
ZoneMinder binaries fail to shut down correctly then you should probably disable this feature.
e.g. --enable-crashtrace=yes or --disable-crashtrace
configure: WARNING: You can call configure with the --enable-mmap=<yes> or --disable-mmap option.
This tells configure whether to compile ZoneMinder with mmap support rather than IPC shared
memory. This is an experimental feature that uses memory mapped into files which all processes
can share. Memory mapping requires less configuration and is more flexible than shared memory
but may slow down your system unless the mapped files are configured to reside on a fast or
RAM based filesystem.
e.g. --enable-mmap=yes or --disable-mmap
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking whether ln -s works... yes
checking for ranlib... ranlib
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C++ preprocessor... g++ -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... no
checking for an ANSI C-conforming const... yes
checking for uid_t in sys/types.h... yes
checking for inline... inline
checking for mode_t... yes
checking for size_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking return type of signal handlers... void
checking for siginfo_t... yes
checking for struct sigcontext... yes
checking for struct sigcontext.eip... yes
checking for ucontext_t... yes
checking whether gcc needs -traditional... no
checking for stdlib.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking types of arguments for select... int,fd_set *,struct timeval *
checking whether lstat dereferences a symlink specified with a trailing slash... yes
checking whether stat accepts an empty string... no
checking for strftime... yes
checking for working strtod... no
checking for pow... yes
checking for vprintf... yes
checking for _doprnt... no
checking for gethostbyname... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for munmap... yes
checking for putenv... yes
checking for select... yes
checking for socket... yes
checking for sqrt... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strcspn... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strrchr... yes
checking for strsignal... yes
checking for strspn... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoull... yes
checking for ffmpeg... yes
checking for ffmpeg... /usr/bin/ffmpeg
checking for pnmscale... yes
checking for pnmscale... /usr/bin/pnmscale
checking for mysql_init in -lmysqlclient... yes
checking for jpeg_start_compress in -ljpeg... yes
checking for pthread_create in -lpthread... yes
checking for dlsym in -ldl... yes
checking for MD5 in -lgnutls-openssl... yes
checking for pcre_compile in -lpcre... yes
checking for av_malloc in -lavutil... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... yes
checking for sws_scale in -lswscale... yes
checking for BZ2_bzCompress in -lbz2... no
configure: WARNING: zm requires libbz2.a for recent versions of ffmpeg
checking for compress in -lz... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for memory.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/socket.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking linux/videodev.h usability... yes
checking linux/videodev.h presence... yes
checking for linux/videodev.h... yes
checking linux/videodev2.h usability... yes
checking linux/videodev2.h presence... yes
checking for linux/videodev2.h... yes
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... yes
configure: WARNING: libavutil/avutil.h: present but cannot be compiled
configure: WARNING: libavutil/avutil.h: check for missing prerequisite headers?
configure: WARNING: libavutil/avutil.h: see the Autoconf documentation
configure: WARNING: libavutil/avutil.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavutil/avutil.h: proceeding with the preprocessor's result
configure: WARNING: libavutil/avutil.h: in the future, the compiler will take precedence
configure: WARNING: ## ------------------------------------- ##
configure: WARNING: ## Report this to support@zoneminder.com ##
checking for libavutil/avutil.h... yes
checking ffmpeg/avutil.h usability... no
checking ffmpeg/avutil.h presence... no
checking for ffmpeg/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... yes
configure: WARNING: libavcodec/avcodec.h: present but cannot be compiled
configure: WARNING: libavcodec/avcodec.h: check for missing prerequisite headers?
configure: WARNING: libavcodec/avcodec.h: see the Autoconf documentation
configure: WARNING: libavcodec/avcodec.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavcodec/avcodec.h: proceeding with the preprocessor's result
configure: WARNING: libavcodec/avcodec.h: in the future, the compiler will take precedence
checking for libavcodec/avcodec.h... yes
checking ffmpeg/avcodec.h usability... no
checking ffmpeg/avcodec.h presence... no
checking for ffmpeg/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... yes
configure: WARNING: libavformat/avformat.h: present but cannot be compiled
configure: WARNING: libavformat/avformat.h: check for missing prerequisite headers?
configure: WARNING: libavformat/avformat.h: see the Autoconf documentation
configure: WARNING: libavformat/avformat.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavformat/avformat.h: proceeding with the preprocessor's result
configure: WARNING: libavformat/avformat.h: in the future, the compiler will take precedence
checking for libavformat/avformat.h... yes
checking ffmpeg/avformat.h usability... no
checking ffmpeg/avformat.h presence... no
checking for ffmpeg/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... yes
configure: WARNING: libswscale/swscale.h: present but cannot be compiled
configure: WARNING: libswscale/swscale.h: check for missing prerequisite headers?
configure: WARNING: libswscale/swscale.h: see the Autoconf documentation
configure: WARNING: libswscale/swscale.h: section "Present But Cannot Be Compiled"
configure: WARNING: libswscale/swscale.h: proceeding with the preprocessor's result
configure: WARNING: libswscale/swscale.h: in the future, the compiler will take precedence
checking for libswscale/swscale.h... yes
checking ffmpeg/swscale.h usability... no
checking ffmpeg/swscale.h presence... no
checking for ffmpeg/swscale.h... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
checking for pcre.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking whether round is declared... yes
checking whether MD5 is declared... yes
checking whether backtrace is declared... yes
checking for perl... perl
checking for perl version greater than or equal to 5.6.0... ok
checking for perl module Sys::Syslog... ok
checking for perl module DBI... ok
checking for perl module DBD::mysql... ok
checking for perl module Getopt::Long... ok
checking for perl module Time::HiRes... ok
checking for perl module Date::Manip... ok
checking for perl module LWP::UserAgent... ok
checking for perl module PHP::Serialization... ok
checking for perl module Module::Load... ok
checking for perl module Device::SerialPort... ok
checking for perl module Net::FTP... ok
checking for perl module Archive::Tar... ok
checking for perl module Archive::Zip... ok
checking for perl module Net::SMTP... ok
checking for perl module MIME::Lite... ok
checking for perl module MIME::Entity... ok
checking for perl module X10::ActiveHome... no
configure: WARNING: X10::ActiveHome is required for X.10 support
configure: creating ./config.status
config.status: creating Makefile
config.status: creating zm.conf
config.status: creating db/Makefile
config.status: creating db/zm_create.sql
config.status: creating scripts/Makefile
config.status: creating scripts/zm
config.status: creating scripts/zmaudit.pl
config.status: creating scripts/zmcontrol.pl
config.status: creating scripts/zmdc.pl
config.status: creating scripts/zmfilter.pl
config.status: creating scripts/zmpkg.pl
config.status: creating scripts/zmtrack.pl
config.status: creating scripts/zmtrigger.pl
config.status: creating scripts/zmupdate.pl
config.status: creating scripts/zmvideo.pl
config.status: creating scripts/zmwatch.pl
config.status: creating scripts/zmx10.pl
config.status: creating scripts/zmdbbackup
config.status: creating scripts/zmdbrestore
config.status: creating scripts/zmeventdump
config.status: creating scripts/zmlogrotate.conf
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Base.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Config.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Memory.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm
config.status: creating src/Makefile
config.status: creating src/zm_config.h
config.status: creating web/Makefile
config.status: creating web/ajax/Makefile
config.status: creating web/css/Makefile
config.status: creating web/graphics/Makefile
config.status: creating web/includes/Makefile
config.status: creating web/includes/config.php
config.status: creating web/js/Makefile
config.status: creating web/lang/Makefile
config.status: creating web/skins/Makefile
config.status: creating web/skins/classic/Makefile
config.status: creating web/skins/classic/ajax/Makefile
config.status: creating web/skins/classic/css/Makefile
config.status: creating web/skins/classic/graphics/Makefile
config.status: creating web/skins/classic/includes/Makefile
config.status: creating web/skins/classic/js/Makefile
config.status: creating web/skins/classic/lang/Makefile
config.status: creating web/skins/classic/views/Makefile
config.status: creating web/skins/classic/views/css/Makefile
config.status: creating web/skins/classic/views/js/Makefile
config.status: creating web/skins/mobile/Makefile
config.status: creating web/skins/mobile/ajax/Makefile
config.status: creating web/skins/mobile/css/Makefile
config.status: creating web/skins/mobile/graphics/Makefile
config.status: creating web/skins/mobile/includes/Makefile
config.status: creating web/skins/mobile/lang/Makefile
config.status: creating web/skins/mobile/views/Makefile
config.status: creating web/skins/mobile/views/css/Makefile
config.status: creating web/tools/Makefile
config.status: creating web/tools/mootools/Makefile
config.status: creating web/views/Makefile
config.status: creating config.h
config.status: executing depfiles commands
perl Makefile.PL
Checking if your kit is complete...
Looks good
Writing Makefile for ZoneMinder
[root@localhost ZoneMinder-1.24.2]# make
make all-recursive
make[1]: Entering directory `/root/ZoneMinder-1.24.2'
Making all in src
make[2]: Entering directory `/root/ZoneMinder-1.24.2/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zmc.o -MD -MP -MF ".deps/zmc.Tpo" -c -o zmc.o zmc.cpp; \
then mv -f ".deps/zmc.Tpo" ".deps/zmc.Po"; else rm -f ".deps/zmc.Tpo"; exit 1; fi
/usr/include/libavutil/common.h: In function ‘int32_t av_clipl_int32(int64_t)’:
/usr/include/libavutil/common.h:154: error: ‘UINT64_C’ was not declared in this scope
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.24.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.24.2'
make: *** [all] Error 2
I upgraded my system to 64bit and followed the same steps as I did before and im up an running. Only two problems came up.
1. The first day or so of recording is real wierd, events should last 599-600 seconds, however I was getting events with 10,000 or some crazy number. But now all seems fine.
2. Everyonce in a while it just crashes and freezes the entire machine. I see apache processes climbing up until it just stops, then it starts again after 10 or 20 minutes.
i have successfully installed the zm 1.24.2 under centos 5.5 and posted the documentation. here's the link:
Zoneminder Centos 5.5
http://akeness.blogspot.com/2010/12/zon ... de-on.html
does anyone still get these problems?
I've tried 3 versions of ffmpeg now...versions most recently tried are:
however still getting the following when trying to "make" zoneminder (tried with and without CXXflag options);
sorry for long post :/ (and sorry for possibly resurrecting dead thread!)
Similar errors across the board with all versions of ffmpeg i've tried (all mentioned within this thread)
It's driving me crazy
Running on Centos 5.5, mad thing is i had this working earlier last year, something i've done seems to have eaten it!
If anyones got any further advice it would be much appreciated!
Thanks all
Moo
FFmpeg version git-a1c1d3c, Copyright (c) 2000-2011 the FFmpeg developers
built on Feb 8 2011 11:15:32 with gcc 4.1.2 20080704 (Red Hat 4.1.2-48)
configuration: --enable-gpl --enable-swscale --prefix=/usr
libavutil 50. 37. 0 / 50. 37. 0
libavcore 0. 16. 1 / 0. 16. 1
libavcodec 52.110. 0 / 52.110. 0
libavformat 52. 97. 0 / 52. 97. 0
libavdevice 52. 2. 3 / 52. 2. 3
libavfilter 1. 74. 0 / 1. 74. 0
libswscale 0. 12. 0 / 0. 12. 0
make all-recursive
make[1]: Entering directory `/ZoneMinder-1.24.2'
Making all in src
make[2]: Entering directory `/ZoneMinder-1.24.2/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zmc.o -MD -MP -MF ".deps/zmc.Tpo" -c -o zmc.o zmc.cpp; \
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_box.o -MD -MP -MF ".deps/zm_box.Tpo" -c -o zm_box.o zm_box.cpp; \
then mv -f ".deps/zm_box.Tpo" ".deps/zm_box.Po"; else rm -f ".deps/zm_box.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_buffer.o -MD -MP -MF ".deps/zm_buffer.Tpo" -c -o zm_buffer.o zm_buffer.
then mv -f ".deps/zm_buffer.Tpo" ".deps/zm_buffer.Po"; else rm -f ".deps/zm_buffer.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_camera.o -MD -MP -MF ".deps/zm_camera.Tpo" -c -o zm_camera.o zm_camera.
then mv -f ".deps/zm_camera.Tpo" ".deps/zm_camera.Po"; else rm -f ".deps/zm_camera.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_comms.o -MD -MP -MF ".deps/zm_comms.Tpo" -c -o zm_comms.o zm_comms.cpp;
then mv -f ".deps/zm_comms.Tpo" ".deps/zm_comms.Po"; else rm -f ".deps/zm_comms.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_config.o -MD -MP -MF ".deps/zm_config.Tpo" -c -o zm_config.o zm_config.
then mv -f ".deps/zm_config.Tpo" ".deps/zm_config.Po"; else rm -f ".deps/zm_config.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_coord.o -MD -MP -MF ".deps/zm_coord.Tpo" -c -o zm_coord.o zm_coord.cpp;
then mv -f ".deps/zm_coord.Tpo" ".deps/zm_coord.Po"; else rm -f ".deps/zm_coord.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm.o -MD -MP -MF ".deps/zm.Tpo" -c -o zm.o zm.cpp; \
then mv -f ".deps/zm.Tpo" ".deps/zm.Po"; else rm -f ".deps/zm.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_db.o -MD -MP -MF ".deps/zm_db.Tpo" -c -o zm_db.o zm_db.cpp; \
then mv -f ".deps/zm_db.Tpo" ".deps/zm_db.Po"; else rm -f ".deps/zm_db.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -I/usr/include -MT zm_debug.o -MD -MP -MF ".deps/zm_debug.Tpo" -c -o zm_debug.o zm_debug.c
then mv -f ".deps/zm_debug.Tpo" ".deps/zm_debug.Po"; else rm -f ".deps/zm_debug.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_event.o -MD -MP -MF ".deps/zm_event.Tpo" -c -o zm_event.o zm_event.cpp;
then mv -f ".deps/zm_event.Tpo" ".deps/zm_event.Po"; else rm -f ".deps/zm_event.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_exception.o -MD -MP -MF ".deps/zm_exception.Tpo" -c -o zm_exception.o z \
then mv -f ".deps/zm_exception.Tpo" ".deps/zm_exception.Po"; else rm -f ".deps/zm_exception.Tpo"; exit 1; f
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_file_camera.o -MD -MP -MF ".deps/zm_file_camera.Tpo" -c -o zm_file_cameera.cpp; \
then mv -f ".deps/zm_file_camera.Tpo" ".deps/zm_file_camera.Po"; else rm -f ".deps/zm_file_camera.Tpo"; exi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_ffmpeg_camera.o -MD -MP -MF ".deps/zm_ffmpeg_camera.Tpo" -c -o zm_ffmpempeg_camera.cpp; \
then mv -f ".deps/zm_ffmpeg_camera.Tpo" ".deps/zm_ffmpeg_camera.Po"; else rm -f ".deps/zm_ffmpeg_camera.Tpo
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_image.o -MD -MP -MF ".deps/zm_image.Tpo" -c -o zm_image.o zm_image.cpp;
then mv -f ".deps/zm_image.Tpo" ".deps/zm_image.Po"; else rm -f ".deps/zm_image.Tpo"; exit 1; fi
zm_image.cpp: In member function âvoid Image::Blend(const Image&, int) constâ:
zm_image.cpp:779: warning: operation on âpdestâ may be undefined
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -I/usr/include -MT zm_jpeg.o -MD -MP -MF ".deps/zm_jpeg.Tpo" -c -o zm_jpeg.o zm_jpeg.c; \
then mv -f ".deps/zm_jpeg.Tpo" ".deps/zm_jpeg.Po"; else rm -f ".deps/zm_jpeg.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql//include -I/usr/include -Wall -Wno-sign-compare -fno-inline -__STDC_CONSTANT_MACROS -frepo -g -O2 -MT zm_local_camera.o -MD -MP -MF ".deps/zm_local_camera.Tpo" -c -o zm_local_c_camera.cpp; \
then mv -f ".deps/zm_local_camera.Tpo" ".deps/zm_local_camera.Po"; else rm -f ".deps/zm_local_camera.Tpo";
zm_local_camera.h:96: error: âPixelFormatâ does not name a type
zm_local_camera.h:97: error: âPixelFormatâ does not name a type
zm_local_camera.h:98: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_local_camera.h:98: error: expected â;â before â*â token
zm_local_camera.cpp:40: error: âPixelFormatâ does not name a type
zm_local_camera.cpp:252: error: expected constructor, destructor, or type conversion before â*â token
zm_local_camera.cpp: In constructor âLocalCamera::LocalCamera(int, const std::string&, int, int, const std::string& int, int, int, int, bool)â:
zm_local_camera.cpp:319: error: âimagePixFormatâ was not declared in this scope
zm_local_camera.cpp:319: error: âPIX_FMT_GRAY8â was not declared in this scope
zm_local_camera.cpp:319: error: âPIX_FMT_RGB24â was not declared in this scope
zm_local_camera.cpp:320: error: âcapturePixFormatâ was not declared in this scope
zm_local_camera.cpp:320: error: âgetFfPixFormatFromV4lPaletteâ was not declared in this scope
zm_local_camera.cpp: In member function âvoid LocalCamera::Initialise()â:
zm_local_camera.cpp:336: error: âAV_LOG_DEBUGâ was not declared in this scope
zm_local_camera.cpp:336: error: âav_log_set_levelâ was not declared in this scope
zm_local_camera.cpp:338: error: âAV_LOG_QUIETâ was not declared in this scope
zm_local_camera.cpp:338: error: âav_log_set_levelâ was not declared in this scope
zm_local_camera.cpp:431: error: âcapturePicturesâ was not declared in this scope
zm_local_camera.cpp:431: error: expected type-specifier before âAVFrameâ
zm_local_camera.cpp:431: error: expected `;' before âAVFrameâ
zm_local_camera.cpp:455: error: âimagePixFormatâ was not declared in this scope
zm_local_camera.cpp:455: error: âcapturePixFormatâ was not declared in this scope
zm_local_camera.cpp:457: error: âavcodec_alloc_frameâ was not declared in this scope
zm_local_camera.cpp:460: error: âAVPictureâ was not declared in this scope
zm_local_camera.cpp:460: error: expected primary-expression before â)â token
zm_local_camera.cpp:460: error: âavpicture_fillâ was not declared in this scope
zm_local_camera.cpp:594: error: âcapturePicturesâ was not declared in this scope
zm_local_camera.cpp:594: error: expected type-specifier before âAVFrameâ
zm_local_camera.cpp:594: error: expected `;' before âAVFrameâ
zm_local_camera.cpp:602: error: âimagePixFormatâ was not declared in this scope
zm_local_camera.cpp:602: error: âcapturePixFormatâ was not declared in this scope
zm_local_camera.cpp:604: error: âavcodec_alloc_frameâ was not declared in this scope
zm_local_camera.cpp:607: error: âAVPictureâ was not declared in this scope
zm_local_camera.cpp:607: error: expected primary-expression before â)â token
zm_local_camera.cpp:607: error: âavpicture_fillâ was not declared in this scope
zm_local_camera.cpp: In member function âvirtual int LocalCamera::Capture(Image&)â:
zm_local_camera.cpp:1576: error: expected initializer before â*â token
zm_local_camera.cpp:1578: error: âimagePixFormatâ was not declared in this scope
zm_local_camera.cpp:1578: error: âcapturePixFormatâ was not declared in this scope
zm_local_camera.cpp:1582: error: âSWS_BICUBICâ was not declared in this scope
zm_local_camera.cpp:1582: error: âsws_getContextâ was not declared in this scope
zm_local_camera.cpp:1586: error: âtmpPictureâ was not declared in this scope
zm_local_camera.cpp:1586: error: âavcodec_alloc_frameâ was not declared in this scope
zm_local_camera.cpp:1589: error: âavpicture_get_sizeâ was not declared in this scope
zm_local_camera.cpp:1590: error: âav_mallocâ was not declared in this scope
zm_local_camera.cpp:1593: error: âAVPictureâ was not declared in this scope
zm_local_camera.cpp:1593: error: expected primary-expression before â)â token
zm_local_camera.cpp:1593: error: âavpicture_fillâ was not declared in this scope
zm_local_camera.cpp:1595: error: âcapturePicturesâ was not declared in this scope
zm_local_camera.cpp:1595: error: âtmpPictureâ was not declared in this scope
zm_local_camera.cpp:1595: error: âsws_scaleâ was not declared in this scope
make[2]: *** [zm_local_camera.o] Error 1
make[2]: Leaving directory `/ZoneMinder-1.24.2/src'
make[1]: Leaving directory `/ZoneMinder-1.24.2'
Thanks all
Moo
- zoneminder
- Site Admin
- Contact:
Ahhh, ok, think what i'm using now is most recent "stable" avail. on their git repo, config as follows; (p.s. had to change all a s s to as5 because of forum rules
install prefix /usr/local
source path /usr/src/ffmpeg
C compiler gcc
ARCH x86 (generic)
big-endian no
runtime cpu detection no
yasm yes
MMX enabled yes
MMX2 enabled yes
3DNow! enabled yes
3DNow! extended enabled yes
SSE enabled yes
SSSE3 enabled yes
CMOV enabled no
CMOV is fast no
EBX available yes
EBP available yes
10 operands supported yes
debug symbols yes
strip symbols yes
optimizations yes
static yes
shared yes
postprocessing support no
new filter support yes
network support yes
threading support pthreads
SDL support no
Sun medialib support no
AVISynth enabled no
frei0r enabled no
libdc1394 support no
libdirac enabled no
libfaac enabled no
libgsm enabled no
libmp3lame enabled no
libnut enabled no
libopencore-amrnb support no
libopencore-amrwb support no
libopencv support no
libopenjpeg enabled no
librtmp enabled no
libschroedinger enabled no
libspeex enabled no
libtheora enabled no
libvorbis enabled no
libvpx enabled no
libx264 enabled no
libxavs enabled no
libxvid enabled no
zlib enabled yes
bzlib enabled yes
Enabled decoders:
aac dsicinaudio mpc7
aac_latm dsicinvideo mpc8
aasc dvbsub mpeg1video
ac3 dvdsub mpeg2video
adpcm_4xm dvvideo mpeg4
adpcm_adx dxa mpegvideo
adpcm_ct eac3 msmpeg4v1
adpcm_ea eacmv msmpeg4v2
adpcm_ea_maxis_xa eamad msmpeg4v3
adpcm_ea_r1 eatgq msrle
adpcm_ea_r2 eatgv msvideo1
adpcm_ea_r3 eatqi mszh
adpcm_ea_xas eightbps nellymoser
adpcm_g722 eightsvx_exp nuv
adpcm_g726 eightsvx_fib pam
adpcm_ima_amv escape124 pbm
adpcm_ima_dk3 ffv1 pcm_alaw
adpcm_ima_dk4 ffvhuff pcm_bluray
adpcm_ima_ea_eacs flac pcm_dvd
adpcm_ima_ea_sead flashsv pcm_f32be
adpcm_ima_iss flic pcm_f32le
adpcm_ima_qt flv pcm_f64be
adpcm_ima_smjpeg fourxm pcm_f64le
adpcm_ima_wav fraps pcm_lxf
adpcm_ima_ws frwu pcm_mulaw
adpcm_ms gif pcm_s16be
adpcm_sbpro_2 gsm pcm_s16le
adpcm_sbpro_3 gsm_ms pcm_s16le_planar
adpcm_sbpro_4 h261 pcm_s24be
adpcm_swf h263 pcm_s24daud
adpcm_thp h263i pcm_s24le
adpcm_xa h264 pcm_s32be
adpcm_yamaha huffyuv pcm_s32le
alac idcin pcm_s8
als iff_byterun1 pcm_u16be
amrnb iff_ilbm pcm_u16le
amrwb imc pcm_u24be
amv indeo2 pcm_u24le
anm indeo3 pcm_u32be
ansi indeo5 pcm_u32le
ape interplay_dpcm pcm_u8
as5 interplay_video pcm_zork
asv1 jpegls pcx
asv2 kgv1 pgm
atrac1 kmvc pgmyuv
atrac3 lagarith pgssub
aura loco pictor
aura2 mace3 png
avs mace6 ppm
bethsoftvid mdec ptx
bfi mimic qcelp
bink mjpeg qdm2
binkaudio_dct mjpegb qdraw
binkaudio_rdft mlp qpeg
bmp mmvideo qtrle
c93 motionpixels r10k
cavs mp1 r210
cdgraphics mp1float ra_144
cinepak mp2 ra_288
cljr mp2float rawvideo
cook mp3 rl2
cscd mp3adu roq
cyuv mp3adufloat roq_dpcm
dca mp3float rpza
dnxhd mp3on4 rv10
dpx mp3on4float rv20
rv30 truehd vp6f
rv40 truemotion1 vp8
sgi truemotion2 vqa
shorten truespeech wavpack
sipr tscc wmapro
smackaud tta wmav1
smacker twinvq wmav2
smc txd wmavoice
snow ulti wmv1
sol_dpcm v210 wmv2
sonic v210x wmv3
sp5x vb wnv1
srt vc1 ws_snd1
sunrast vcr1 xan_dpcm
svq1 vmdaudio xan_wc3
svq3 vmdvideo xan_wc4
targa vmnc xl
theora vorbis xsub
thp vp3 yop
tiertexseqvideo vp5 zlib
tiff vp6 zmbv
tmv vp6a
Enabled encoders:
a64multi jpegls pcm_u32le
a64multi5 ljpeg pcm_u8
aac mjpeg pcm_zork
ac3 mp2 pcx
ac3_fixed mpeg1video pgm
adpcm_adx mpeg2video pgmyuv
adpcm_g722 mpeg4 png
adpcm_g726 msmpeg4v1 ppm
adpcm_ima_qt msmpeg4v2 qtrle
adpcm_ima_wav msmpeg4v3 ra_144
adpcm_ms nellymoser rawvideo
adpcm_swf pam roq
adpcm_yamaha pbm roq_dpcm
alac pcm_alaw rv10
as5 pcm_f32be rv20
asv1 pcm_f32le sgi
asv2 pcm_f64be snow
bmp pcm_f64le sonic
dnxhd pcm_mulaw sonic_ls
dvbsub pcm_s16be svq1
dvdsub pcm_s16le targa
dvvideo pcm_s24be tiff
ffv1 pcm_s24daud v210
ffvhuff pcm_s24le vorbis
flac pcm_s32be wmav1
flashsv pcm_s32le wmav2
flv pcm_s8 wmv1
gif pcm_u16be wmv2
h261 pcm_u16le xsub
h263 pcm_u24be zlib
h263p pcm_u24le zmbv
huffyuv pcm_u32be
Enabled hwaccels:
Enabled parsers:
aac dvdsub mpeg4video
aac_latm flac mpegaudio
ac3 h261 mpegvideo
cavsvideo h263 pnm
dca h264 vc1
dirac mjpeg vp3
dnxhd mlp vp8
dvbsub
Enabled demuxers:
aac ipmovie pcm_u32be
ac3 iss pcm_u32le
aea iv8 pcm_u8
aiff ivf pva
amr lmlm4 qcp
anm lxf r3d
apc m4v rawvideo
ape matroska rl2
applehttp mjpeg rm
asf mlp roq
as5 mm rpl
au mmf rso
avi mov rtp
avs mp3 rtsp
bethsoftvid mpc sap
bfi mpc8 sdp
bink mpegps segafilm
c93 mpegts shorten
caf mpegtsraw siff
cavsvideo mpegvideo smacker
cdg msnwc_tcp sol
daud mtv sox
dirac mvi spdif
dnxhd mxf srt
dsicin mxg str
dts nc swf
dv nsv thp
dxa nut tiertexseq
ea nuv tmv
ea_cdata ogg truehd
eac3 oma tta
ffm pcm_alaw tty
ffmetadata pcm_f32be txd
filmstrip pcm_f32le vc1
flac pcm_f64be vc1t
flic pcm_f64le vmd
flv pcm_mulaw voc
fourxm pcm_s16be vqf
g722 pcm_s16le w64
gsm pcm_s24be wav
gxf pcm_s24le wc3
h261 pcm_s32be wsaud
h263 pcm_s32le wsvqa
h264 pcm_s8 wtv
idcin pcm_u16be wv
iff pcm_u16le xa
image2 pcm_u24be yop
image2pipe pcm_u24le yuv4mpegpipe
ingenient
Enabled muxers:
a64 ipod pcm_s16le
ac3 ivf pcm_s24be
adts m4v pcm_s24le
aiff matroska pcm_s32be
amr matroska_audio pcm_s32le
asf md5 pcm_s8
asf_stream mjpeg pcm_u16be
as5 mlp pcm_u16le
au mmf pcm_u24be
avi mov pcm_u24le
avm2 mp2 pcm_u32be
cavsvideo mp3 pcm_u32le
crc mp4 pcm_u8
daud mpeg1system psp
dirac mpeg1vcd rawvideo
dnxhd mpeg1video rm
dts mpeg2dvd roq
dv mpeg2svcd rso
eac3 mpeg2video rtp
ffm mpeg2vob rtsp
ffmetadata mpegts sap
filmstrip mpjpeg sox
flac mxf spdif
flv mxf_d10 srt
framecrc null swf
framemd5 nut tg2
g722 ogg tgp
gif pcm_alaw truehd
gxf pcm_f32be vc1t
h261 pcm_f32le voc
h263 pcm_f64be wav
h264 pcm_f64le webm
image2 pcm_mulaw yuv4mpegpipe
image2pipe pcm_s16be
Enabled protocols:
concat mmst rtmpt
file pipe rtmpte
gopher rtmp rtp
http rtmpe tcp
md5 rtmps udp
mmsh
Enabled filters:
anull format pixdesctest
anullsink gradfun scale
anullsrc hflip setdar
blackframe hqdn3d setpts
buffer movie setsar
color noformat settb
copy null slicify
crop nullsink transpose
cropdetect nullsrc unsharp
drawbox overlay vflip
fifo pad yadif
Enabled bsfs:
aac_adtstoasc mjpeg2jpeg mp3_header_decompress
chomp mjpega_dump_header noise
dump_extradata mov2textsub remove_extradata
h264_mp4toannexb mp3_header_compress text2movsub
imx_dump_header
Enabled indevs:
alsa oss v4l2
dv1394 v4l
Enabled outdevs:
alsa oss
License: GPL version 2 or later
Creating config.mak and config.h...
I'm still get the same errors with the latest rpmforge repo of ffmpeg and when I build it from svn,
The solutions highlighted inside this post allow me to build and install ZM but there are problems with the install and some functions are broken or missing.
Build and Install 1.24.3 on CentOS 5.5 with the latest updates, and ffmpeg 0.6.1
At the moment the time line bar wont work and the fast forward / reverse only work if the previous event button is pressed first.
See my earlier posts for detailed output from the build ect
Ah, getting the dreadded mmap errors now! Have come across this with my last working build in the past so will crack on with fixing...however find it slightly odd that I wasn't experiencing this with the .2 install?
Clipo did you experience this error @ compile time by any chance, too?
configure: error: zm requires Sys::Mmap for mapped memory
- zoneminder
- Site Admin
- Contact:
If you have the rpmforge repository enabled then you can just install it as otherwise you will need to use perl and the CPAN module but that is pretty simple too.
yum install perl-Sys-Mmap
Phil
