Ghosting ?
Re: Ghosting ?
maybe out of order frames? Have you watched it frame-by-frame?
Re: Ghosting ?
Are you doing .jpegs or just video? Any relation to how much movement is going on? Is the camera doing motion detection?
Is zm doing motion?
Is zm doing motion?
- knight-of-ni
Re: Ghosting ?
You are dropping frames. Could be a network problem. Could be a server resource problem.
Try forcing the stream type to unicast tcp.
Lower your frame rate.
What is the load on the server?
This isn't a wifi camera is it?
