Installation error in Zoneminder matser 1.35.26~20210413091429-focal [Solved ]
- bkjaya1952
I have tried to install ( fresh installation ) the latest release of Zoneminder master 1.35.26~20210413091429-focal & found the following mysql error
Detected db service is mysql.service
Checking for db
Creating zm db
ERROR 1136 (21S01) at line 793: Column count doesn't match value count at row 1
Error creating db.
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error
exit status 1
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for systemd (245.4-4ubuntu3.5) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
Checking for db
Creating zm db
Error creating db.
exit status 1
zoneminder
- zoneminder -master -error.txt
- (762 Bytes) Downloaded 109 times
Re: Installation error in Zoneminder matser 1.35.26~20210413091429-focal
If you did a clean install then disregard the following:
My upgrade was fine Linux Mint 20.1 ZM 1.35.26~20210413091429-focal from previous version
also installed a kernel update
Jimmy
Jimmy
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
- bkjaya1952
The problem is in the fresh installation..There is no problem in upgrading from previous version.DVB Hardware wrote: ↑Tue Apr 13, 2021 7:30 pm If you did a clean install then disregard the following:
Jimmy
Just pushed a fix.
- bkjaya1952
Re: Installation error in Zoneminder matser 1.35.26~20210413091429-focal [Solved ]
Thank you Sir !.
Installation problem solved , after using your fix ( fix at the following link ) on the /usr/share/zoneminder/db/zm_create.sql ,
https://github.com/ZoneMinder/zoneminde ... e6c99192d0
- zm_create.txt
- (224.92 KiB) Downloaded 107 times
I have just run into this myself: I'm afraid its not clear to me how to apply the fix. Do I edit zm_create_sql.in and retry the install, or can I pick up the change via git somehow?
Thanks,
Michael
Thanks,
Michael
- bkjaya1952
sudo su
add-apt-repository ppa:iconnor/zoneminder-master
apt update
apt -y install zoneminder
( Now you will see some error message ie Error: Process completed with exit code 100. )
Then go to the following Issac Connor's web link
You can see the corrected lines within the green color block .
Open the file at /usr/share/zoneminder/db/zm_create.sql
sudo gedit /usr/share/zoneminder/db/zm_create.sql
Delete the 793 line of the opened file zm_create.sql .
Then copy Issac Connor's fix at above link marked in green color block and paste at line 793 and save.
Then configure zoneminder and apache as usual.
Please refer the following link for get more details
https://bkjaya.wordpress.com/2020/11/16 ... cal-fossa/
But now:
1.35.26~20210417163214-focal
- db upgrade fails.
Ran zmupdate manually failed.
Got it to work with the suggested mysql work-around.
- db upgrade fails.
- bkjaya1952
It is apparent that the Isaac Cooor's fix has already being included in the latest Zoneminder master 1.35.26~20210417163214-focal
Therefore it is not necessary to apply the fix manually
May be ok on fresh install, but upgrade fails now. At least for me.It is apparent that the Isaac Cooor's fix has already being included in the latest Zoneminder master 1.35.26~20210417163214-focal
- bkjaya1952
Hi dougmccrary,dougmccrary wrote: ↑Sun Apr 18, 2021 8:03 amMay be ok on fresh install, but upgrade fails now. At least for me.It is apparent that the Isaac Cooor's fix has already being included in the latest Zoneminder master 1.35.26~20210417163214-focal
Even for a fresh install of the above version, ZM will not work unless you drop the zm database & re create
