Stuck on Privacy Page after installation on Ubuntu
I logged in with admin/admin after installation and all the "accept" button does is reload the Privacy Policy page.
Re: Stuck on Privacy Page after installation on Ubuntu
ISTR a checkbox...
You should not have to log in on initial access to http://ipaddr/zm
Accept or reject the privacy option in the lower right corner and you should go to the Zoneminder Console. Configure from there and remember to set the timezone in Options/System/Timezone
- bkjaya1952
To avoid getting Web_Title_Login and stuck on Privacy
Drop the existing database zm and re do the mysql configuring as follows
mysql -e "drop database zm;"
mysql -uroot --password=""< /usr/share/zoneminder/db/zm_create.sql 2>/dev/null
mysql -e "ALTER USER 'zmuser'@localhost IDENTIFIED BY 'zmpass';"
mysql -e "GRANT ALL PRIVILEGES ON zm.* TO 'zmuser'@'localhost' WITH GRANT OPTION;"
mysql -e "FLUSH PRIVILEGES ;"
In the above codes it is for no mysql password . If you want to have a password , please refer the procedure in the following link .
https://bkjaya.wordpress.com/2020/11/16 ... cal-fossa/
