Hello
I'm experimenting with zmeventnotification. It's running and detecting. Great functionality.
Questions:
1) Has anyone figured out a way to email the detected object including snapshot? I looked around this forum and googled it but emailing does not seem popular. If anyone has step by step info on how I could email it would be great.
2) I tried Zmninja and it seems to work OK except I seem to have issues viewing alarms. This may be caused by the fact that I use exclusively "mocord" so each alarm is a lengthy 30 minute event. Can zmninja be used with mocord?
Thanks all. Any help would be appreciated.
I use Ubuntu 20.04 - Zoneminder 1.34.22
zmeventnotification questions
Re: zmeventnotification questions
You could probably create a ZM filter and generate an email. I use Pushover instead.
1) You should use custom zm_event_end script. I've use autodelete + it has telegram notification on object detection. Adding email is just a matter of finding right smtp-client and passing parameters with text and snapshot image or even video.LBDG wrote: ↑Tue Dec 22, 2020 9:44 pmHello
Questions:
