ReoLink RLC-420-5MP connection
rtalada
Post by rtalada » Tue Jan 07, 2020 11:06 pm
Here is how I have the camera setup in my environment
First thing to do is define the IP address.
I found that adding the device to dhcp using manual allocation worked quite well considering that no initial IP address was provided.
Log on to the camera using the assigned IP address
Username: admin
no password
Camera variables:
Basic Settings:
Stream: Clear
Resolution: 2048 x 1536
Frame Rate: 30
Max Bitrate: 6144
H.264 Profile: Main
Stream: Fluent
Resolution: 640 x 480
Frame Rate: 10
Max Bitrate: 160
H.264 Profile: Main
Zoneminder Variables:
General:
Source Type: Ffmpeg
Max FPS (?): null
Alarm Max FPS (?): null
Source:
Source Path: rstp://{username:password}@{IPaddress}
Method (?): TCP
Options (?): /h264Preview_01_main
Capture Width: 640
Capture Height: 480
banzaay
Re: ReoLink RLC-420-5MP connection
Post by banzaay » Wed Jan 08, 2020 9:42 am
I have configured the Reolink RLC-511W, this is my configuration:
  • General:
Source Type: Ffmpeg
Max FPS (?): null
  • Source:
Source Path: rtsp://admin:PWD@192.168.1.51/h264Preview_01_sub (this is for the Stream Fluent,ohterwise you can use rtsp://admin:PWD@192.168.1.51/h264Preview_01_main with resolution 2560x1920)
Method (?): TCP
Options (?): null
Capture Width: 640
Capture Height: 480
Mirko
FFRRRR
Post by FFRRRR » Fri Nov 13, 2020 8:14 am
here is a detailed configuration process I find in the reddit. May it helps you.
https://www.reddit.com/r/reolinkcam/com ... inder_nvr/
Users browsing this forum: No registered users and 9 guests
