CentOS 8 cannot install zoneminder
Re: CentOS 8 cannot install zoneminder
I'm in the same boat. I'm trying to use NGINX. I can follow the installation instructions up until I get to start NGINX, and I get errors. This has got to be the most clunky software I've ever tried to install...
ZM 1.36
Ubuntu 22.04 LTS / NGINX
ESXi 6.7 VM
ESXi 6.7 VM
I realize that this is a bit old, but I tried and got it installed on Centos8 by doing:
dnf config-manager --set-enabled PowerTools
dnf install zoneminder
@knight-of-ni works perfectly when I enable PowerTools.
Thanks for the headsup.
I enabled power tools using this: https://andrewsarver.com/enable-centos- ... ools-repo/
then "sudo yum install perl-DateTime"
then was able to "sudo yum install zoneminder" and it all went according to plan
Hi
I was happy to find this thread and the previous posting ... I enabled the PowerTools, I installed 'perl-DateTime' ...
??? Please help step by step to install zm on a new Centos 8 system (me=rookie)
Thx
... not here: (I translate from German): "Last check for expired metadata Fri 30 Oct No match for argument zoneminder"... then was able to "sudo yum install zoneminder" and it all went according to plan
Thx
I'm overstrained ... should I download 'https://mirrors.rpmfusion.org/free/el/r ... noarch.rpm' - and then?
Yes, you download and install it. That adds the repo to your system. Then you can install any software that the new repo knows about.
