Zoneminder 1.35.5~20200725145046-focal filters can't be saved
Forum for questions and support relating to 1.35.x development only.
bkjaya1952
Post by bkjaya1952 » Sun Jul 26, 2020 5:53 pm
In Zoneminder 1.35.520200725145046-focal , the filters conditional statements can't be saved.
In earlier versions , when there is an error , the log button color was changed into yellow or red . But that color change does not occur in the version 1.35.520200725145046-focal
Re: Zoneminder 1.35.5~20200725145046-focal filters can't be saved
Post by dougmccrary » Sun Jul 26, 2020 9:01 pm
Unsurprisingly, ditto in bionic.
I notice you can rename existing ones and make new ones.
Post by knight-of-ni » Sun Jul 26, 2020 11:34 pm
This was caused by yesterday's changes to Object.php. If you need to get this working now, you can roll back to the June 4 version of this file:
https://github.com/ZoneMinder/zoneminde ... Object.php
I've confirmed the filter problem goes away when using this version of Object.php.
bkjaya1952
Post by bkjaya1952 » Mon Jul 27, 2020 3:46 am
Thank you Sir.
I have used June 4 version of Object.php as you suggested and working successfully :D
bkjaya1952
Post by bkjaya1952 » Mon Jul 27, 2020 4:48 am
The above errors have not been resolved in latest update of Zoneminder 1.35.5~20200726223348-focal
Until make the corrections in the next release, we may have to use the solution given by Admin Eng knight-of-ni with his above post ,
(replacing Object.php at /usr/share/zoneminder/www/includes/ with June 4 version of Object.php)
Post by dougmccrary » Mon Jul 27, 2020 6:30 am
That one is now old.
1.35.5~20200726223348-focal works, at least so far as filters and colors (like for the LOG).
bkjaya1952
Post by bkjaya1952 » Mon Jul 27, 2020 3:59 pm
Problems resolved only partially . Although the filters can be used, can't be saved. The change in colors of log button is also not solved completely.
Post by dougmccrary » Mon Jul 27, 2020 8:29 pm
Not sure about log.
But on the filters, did you reload the page? I can save filter changes no mine.
bkjaya1952
Post by bkjaya1952 » Fri Jul 31, 2020 5:00 pm
Not sure about log.
Hi dougmccrary
Yes you are correct . The filters can be saved in Zoneminder 1.35.5~20200726223348-focal . The change in color problem of log button still remains.
bkjaya1952
Post by bkjaya1952 » Sun Aug 02, 2020 6:56 am
After the latest update of Zoneminder 1.35.5~20200801102905-focal all the problems have been solved !! :D :D
1. Filters can be saved
2. The color change in log button is OK
Painter
Post by Painter » Mon Aug 03, 2020 4:36 pm
It looks like new issues have been introduced though...
1) In every page i've been i noticed an auto-refresh of the page every 5 seconds. If i have selected let's say some events or if i want to delete some i have to be very fast an press delete/save or whatever. The same applies of course when in the system menu options.
Connected to the above, when playing back an event i cannot play it for the full length as it restarts from the beginning every 5".
2) At the "RUNNING" button on the top right with the options to select the ZM running state, i use to have start/stop/restart (or something similar)
Now i only have Start and default as options.
Post by knight-of-ni » Mon Aug 03, 2020 5:04 pm
1) is already fixed
2) aware of it. Haven't fixed it yet.
UPDATE: #2 is fixed
Painter
Post by Painter » Mon Aug 03, 2020 7:03 pm
Indeed, both are fine for me now. Impressed with the speed of the response.
Thanks!
Post by dougmccrary » Tue Aug 04, 2020 6:34 am
I'm seeing a refresh every minute on montage view, though. Not normal there, IIRC.
Post by knight-of-ni » Tue Aug 04, 2020 12:02 pm
A 1 minute full page refresh is by design and has been part of ZoneMinder for many years.
You can set the refresh period to whatever you want. It's under the High/Medium/Low B/W settings under options.
UPDATE: Annndddd.... you said Montage. I guess I should finish my morning coffee before posting. I'm not sure if the setting I mentioned affects that or not. Try it.
Users browsing this forum: Baidu [Spider] and 1 guest
