BUG? Enabling OPT_USE_AUTH STOPS streams
BobLaske
Post by BobLaske »
I enabled OPT_USE_AUTH on my system, a system where everything is/was working fine.
I logged in as a user I created and never could view streams.
The next day the admin could no longer view streams.
A while ago, I disabled OPT_USE_AUTH and now viewing streams is back.
This has to be a bug right?
BobLaske
Re: BUG? Enabling OPT_USE_AUTH STOPS streams
Post by BobLaske »
Nobody cares? This seems to be a bug and if it's not, then something is still not right. This is a brand new, fresh install.
No typically it is due to you not setting your timezone.
No one ever looks in their logs for the solution and we are all tired of going through the same steps with people.
Take a look at your logs.
BobLaske
Post by BobLaske »
Please, I do look at logs but you need to know what you're looking for and this is new to me.
Also, the timezone IS set. It's one of the first things I did.
BobLaske
Post by BobLaske »
And, thank you for pointing that out.
I forgot that I had rebuilt because of a problem and didn't set that this time.
Now it's set so I'll try again.
BobLaske
Post by BobLaske »
Same difference. Even with the time zone set in php.ini, adding auth breaks streams. This time, I didn't even add a user and admin has no stream.
BobLaske
Post by BobLaske »
So, if it's not related to the timezone settings, what else is causing this? Surely, someone else must have seen this issue by now?
Could be due to ip differences if you have AUTH_HASH_IPS set. Try unchecking it.
What do you have for AUTH_HASH_LOGINS? Should be checked.
AUTH_RELAY should be hashed, but the others should also work they are just way less secure.
The thing to do would be to turn on debug logging and check the logs.
BobLaske
Post by BobLaske »
Maybe this is where I went wrong then.
For my test, I had only enabled OPT_USE_AUTH and started playing with that. I had not enabled or changed any other settings.
I'll look at the documentation and report back once I've tried what I'm supposed to since I seem to be missing some needed steps.
