zmeventnotification: Error parsing config:/etc/zm/objectconfig.ini
Discussion topics related to mobile applications for ZoneMinder
asker
Re: zmeventnotification: Error parsing config:/etc/zm/objectconfig.ini
Post by asker » Mon Jun 22, 2020 4:56 pm
Let's focus on the error that you posted:
File "/usr/lib/python3.7/urllib/request.py", line 1319, in do_open raise URLError(err)urllib.error.URLError: <urlopen error [Errno -2] Name or service not known>
It doesn't say Permission denied, nor does it say 404 (Not found). "Name or service not known" means the download function tried to use a URL to download the image and python does not know how to handle that URL.
Based on what I found:
1. It may be that your URL config is wrong. We ruled that out
2. It may be that DNS cannot resolve that URL from the server you are running zm_detect.py. I think we also ruled that out, because wget works and I assume you ran it from the same server
3. It may be that you are using a proxy? Is that a possibility?
Anyway, to your question, files are downloaded to /var/lib/zmeventnotification/images. You should have write permissions to it, because you ran zm_detect with -u www-data
Please don't ask me questions via PM. Feel free to post in the forums or Github
SkippyDo
Post by SkippyDo » Mon Jun 22, 2020 6:46 pm
No, no proxy. That is, none that I'm aware of: I have not intentionally created any such configuration. I'd actually had a previous version of object detection working (back when it was zmeventserver) under ZM 1.32: for a brief time. I'm using the same hardware and basic configurations: I suspect, however, that I may not have been running UFW (can't recall).
SkippyDo
Post by SkippyDo » Sat Jun 27, 2020 1:18 pm
I'm really wanting to resolve whatever is causing my issue/error. Should I open up a new thread since it doesn't appear related to parsing the objectconfig.ini file?
I'd like to better understand how to read the error logs as I posted in my June 17th post. Top of error log shows "animation: Traceback:Traceback (most recent call last". Do I read from the bottom of that log entry (which contains " File "/usr/lib/python3.7/urllib/request.py", line 1319, in do_open raise URLError(err)urllib.error.URLError: <urlopen error [Errno -2] Name or service not known>")?
asker
Post by asker » Sat Jun 27, 2020 2:33 pm
The real issue is generally at the bottom of python errors, but in this case, one error caused another, so it is in the middle.
The key issue is this error:
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags):socket.gaierror: [Errno -2] Name or service not known
If you google around, the reason is that the address it is trying to resolve is not resolvable via DNS.
You're going to have to figure out why that is so. Not much else I can point to.
SkippyDo
Post by SkippyDo » Sun Jun 28, 2020 9:55 am
Yeah, OK. I didn't want to make that assumption.
I've run into a dead end. Problem is at some really low level that I cannot unearth. Everything works except object detection. I'll just live with things as-is.
asker
Post by asker » Mon Jun 29, 2020 12:22 am
If you are able to give me ssh access I can try and debug. I still feel it’s something configuration related.
SkippyDo
Post by SkippyDo » Tue Jun 30, 2020 1:18 pm
I think this is a server configuration issue and not an application configuration, application related to ZM/zmeventnotifcation.
"getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags):socket.gaierror: [Errno -2] Name or service not known"
Per an answer given to/on https://stackoverflow.com/questions/572 ... own-python
socket.gaierror: [Errno -2] Name or service not known means that the name resolution is failing for the given domain (api.github.com).
Name resolution (DNS in the usual notion) can fail for various reasons. As you have disconnected the internet, the reason is pretty obvious (Name or service not known).
gai (GetAddressInfo) is actually used by glibc to perform the name resolutions, it's part of glibc (and socket is using that as you can imagine). You can also actually configure it in /etc/gai.conf.
Not sure what the call is querying, and what it's using to do the query, whether FQDN or just the hostname. If it's a broadcast request to resolve the hostname IP then I can see that failing as the server is directly on the WAN (DMZ'd off my ISP router; DHCP, not static). And, if for some reason it's expecting to resolve as an ipv6 address and is depending on local resources (itself) then that could be dealt with via /etc/hosts (which has an ipv4 entry for hostname and FDQN for the loopback interface at 127.0.1.1, but no equivalent ipv6 entry) or via /etc/gai.conf (set preference to ipv4): I don't understand ipv6, so not real sure how I'd go about making either change or test. This kind of lines up with your suspecting that this might be a proxy issue (which I'd stated I wasn't using any proxy server/services).
asker
Post by asker » Tue Jun 30, 2020 5:50 pm
It is a system issue if you have that problem with any URL and outside of the ES.
I think you did wget tests and they worked. I assume you tested them on the same server where the ES is.
SkippyDo
Post by SkippyDo » Thu Jul 02, 2020 10:52 am
Correct, I did run wget on the ES (and ZM) server.
Just seems, according to that error, that it's having issues resolving the hostname/IP. It's like the python scripts are calling some other library routines (than is wget). Well, that or the URL (and rest) is getting corrupted when handed off to some underlying library: there's nothing special in the URL and args that I can see that could be suspect (no strange characters).
Are there any configuration files other than ZM and zmeventnotification that could be a source of this problem? If not, I could just email you the relevant files. I'm not adverse to allowing you access to the server, it's just that I don't think that you'd find anything if only looking at the config files, which I could just send: already noted that the relevant directories have the required permissions/ownership.
asker
Post by asker » Thu Jul 02, 2020 1:08 pm
I don't plan to only read config files. I plan to check your install and execute myself to see what is going on. It is much easier for me than long forum posts
SkippyDo
Post by SkippyDo » Sat Jul 04, 2020 12:53 pm
Could you refresh my memory as to how to contact you directly?
