Need help with Smartwares CIP-39218AT outdoor ip-cam
athoopen
Post by athoopen » Fri Dec 28, 2018 12:35 pm
Guru's
I need your help. I was able to put my hands on a CIP39218AT cam. Works great with the App delivered with the device. However I have trouble getting the stream url to be able to configure it into ZoneMinder.
Using VLC I have found that via http://[INT-IP-ADDRESS]/snapshot.jpg?user=[USER]&pwd=[PASWD] I can get a single snapshot of the camera but NOT the stream.
Anybody of you have an idea how to get the correct url for streaming?
Thanks in advance,
Arjan ten Hoopen
Sukkel67
Re: Need help with Smartwares CIP-39218AT outdoor ip-cam
Post by Sukkel67 » Sun May 19, 2019 9:42 pm
Hoi Arjan,
Ik heb hetzelfde probleem, alleen snapshots lukt tot nu toe.
Ik heb de Smartwares Servicedesk gemail met dezelfde vraag.
Als ze een oplossing hebben zal ik het doorgeven.
Groetjes,
Sukkel67
lovelash
Post by lovelash » Mon Jun 10, 2019 7:43 am
Wyzecam's offerings are very inexpensive for what they are. They are for indoor use, but people have been using them outdoors without issue. They also just released a beta firmware to allow rtsp so you can connect it to your own NVR, such as blue Iris, ispy etc
YI cam also is an outdoor camera that is pretty good bang for your buck you cannot check out.
If you want the next price point up I'd suggest looking at reolink or amcrest's lineup.
https://get-shareit.com https://authorityapk.com Tutuapp
Users browsing this forum: endtyranny and 5 guests
