R2D2
Post
by R2D2 » Sat Jan 26, 2019 2:44 pm
after a long time, i installed ZM again, but i cannot get working the ZM API.
When i type this in my Browser,
i get this:
Fatal error: Cannot use 'object' as class name as it is reserved in /usr/share/zoneminder/www/api/lib/Cake/Core/Object.php on line 18
How can i solve this?
R2D2 on Sat Feb 02, 2019 9:46 am, edited 1 time in total.
Post
by bbunge » Sat Jan 26, 2019 8:13 pm
Linux distro and version please...
R2D2
Post
by R2D2 » Sat Jan 26, 2019 8:27 pm
Distro is Gentoo
ZM is 1.32.3
R2D2
Post
by R2D2 » Sun Jan 27, 2019 8:29 am
After some "Experiments", now i get this issue:
Warning (2): Use of undefined constant ZM_OPT_USE_API - assumed 'ZM_OPT_USE_API' (this will throw an Error in a future version of PHP) [APP/Controller/AppController.php, line 63]
Warning (2): ini_set() [<a href='http://php.net/function.ini-set'>function.ini-set</a>]: Headers already sent. You cannot change the session module's ini settings at this time [CORE/Cake/Model/Datasource/CakeSession.php, line 581]
CakePHP: the rapid development php framework
Fatal Error
Error: require_once() [<a href='http://php.net/function.require'>function.require</a>]: Failed opening required '../../../includes/config.php' (include_path='.:/usr/share/php7:/usr/share/php')
File: /usr/share/zoneminder/www/api/app/Config/bootstrap.php
Line: 123
Notice: If you want to customize this error message, create app/View/Errors/fatal_error.ctp
CakePHP 2.10.8
Warning (2): Use of undefined constant ZM_DB_USER - assumed 'ZM_DB_USER' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_PASS - assumed 'ZM_DB_PASS' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_NAME - assumed 'ZM_DB_NAME' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_SSL_CA_CERT - assumed 'ZM_DB_SSL_CA_CERT' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_SSL_CLIENT_KEY - assumed 'ZM_DB_SSL_CLIENT_KEY' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_SSL_CLIENT_CERT - assumed 'ZM_DB_SSL_CLIENT_CERT' (this will throw an Error in a future version of PHP) [CORE/Cake/Model/ConnectionManager.php, line 69]
Warning (2): Use of undefined constant ZM_DB_HOST - assumed 'ZM_DB_HOST' (this will throw an Error in a future version of PHP) [APP/Config/database.php, line 92]
Warning (2): Use of undefined constant ZM_DB_HOST - assumed 'ZM_DB_HOST' (this will throw an Error in a future version of PHP) [APP/Config/database.php, line 101]
BTW, i'am using PHP 7.1
server01 ~ # php -v
PHP 7.1.26 (cli) (built: Jan 19 2019 12:09:17) ( ZTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.1.0, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.1.26, Copyright (c) 1999-2018, by Zend Technologies
server01 ~ #
R2D2
Post
by R2D2 » Sun Jan 27, 2019 11:21 am
I edited the "
/usr/share/zoneminder/www/api/app/Config/bootstrap.php" from,
require_once("../../../includes/config.php");
to
require_once("/usr/share/zoneminder/www/includes/config.php")
but now i get the following issue:
Uncaught FatalErrorException: [MissingPluginException] Plugin Crud could not be found.
#0 /usr/share/zoneminder/www/api/lib/Cake/Core/App.php(227): CakePlugin::path('Crud')
#1 /usr/share/zoneminder/www/api/lib/Cake/Core/App.php(549): App::path('Lib', 'Crud')
#2 [internal function]: App::load('CrudControllerT...')
#3 /usr/share/zoneminder/www/api/app/Controller/AppController.php(34): spl_autoload_call('CrudControllerT...')
#4 /usr/share/zoneminder/www/api/lib/Cake/Core/App.php(547): include('/usr/share/zone...')
#5 [internal function]: App::load('AppController')
#6 [internal function]: spl_autoload_call('AppController')
#7 /usr/share/zoneminder/www/api/lib/Cake/Error/ExceptionRenderer.php(155): class_exists('AppController')
#8 /usr/share/zoneminder/www/api/lib/Cake/Error/ExceptionRenderer.php(95): ExceptionRenderer->_getController(Object(ParseError))
#9 /usr/share/zoneminder/www/api/lib/Cake/Error/ErrorHandler.php(126): ExceptionRenderer->__construct(Object(ParseError))
#10 [internal function]: ErrorHandler::h
Post
by rockedge » Tue Jan 29, 2019 3:48 am
you must identify which version of CakePHP and CRUD you have in your ZM setup.
change what you done back to it's original code. go look in /usr/share/zoneminder/www/api/app/Plugin/Crud/README.md
(or the path to your ZM installation) At the top of this file it should have :
# Version notice
This version of Crud is for CakePHP 2.x.
This fork has been patched for PHP 7.2 compatibilty, specifically for the [ZoneMinder](https://github.com/ZoneMinder/ZoneMinder) project.
This fork will no longer be necessary once [Pull Reqeust #282](https://github.com/FriendsOfCake/crud/pull/582) has been merged.
if not, you might have the version CRUD and CakePHP that isn't fixed to work with PHP 7.2+
the correct versions are
here at this link and can be swapped in manually with relative ease.
R2D2
Post
by R2D2 » Tue Jan 29, 2019 6:47 pm
OK, reverted all, an did the instructions from your link above.
But now i get this issue:
Fatal error: Uncaught FatalErrorException: [CakeSessionException] Unable to configure the session, setting session.use_trans_sid failed.
#0 /usr/share/zoneminder/www/api/lib/Cake/Model/Datasource/CakeSession.php(732): CakeSession::_configureSession()
#1 /usr/share/zoneminder/www/api/lib/Cake/Model/Datasource/CakeSession.php(219): CakeSession::_startSession()
#2 /usr/share/zoneminder/www/api/lib/Cake/Model/Datasource/CakeSession.php(248): CakeSession::start()
#3 /usr/share/zoneminder/www/api/lib/Cake/View/Helper/SessionHelper.php(134): CakeSession::check('Message.flash')
#4 /usr/share/zoneminder/www/api/app/View/Layouts/error.ctp(46): SessionHelper->flash()
#5 /usr/share/zoneminder/www/api/lib/Cake/View/View.php(971): include('/usr/share/zone...')
#6 /usr/share/zoneminder/www/api/lib/Cake/View/View.php(933): View->_evaluate('/usr/share/zone...', Array)
#7 /usr/share/zoneminder/www/api/lib/Cake/View/View.php(546): View->_render('/usr/share/zone...')
#8 /usr/share/zoneminder/www/api/lib/Cake/View/View.php(481): View->renderL in /usr/share/zoneminder/www/api/lib/Cake/Error/ErrorHandler.php on line 138
R2D2
Post
by R2D2 » Sat Feb 02, 2019 9:45 am
Post
by rockedge » Sat Feb 02, 2019 2:37 pm
yes I was hoping the links I listed had this information...great that you have it going! Good work.
rayrayray
Post
by rayrayray » Tue Feb 12, 2019 4:20 pm
Thank you! I was struggling with the same API error with Ubuntu 18.04.01 LTS and 1.32.3. I didn't need any of the code changes in that forum post -- the code fix and CakePHP plugin files were already present on my system. I only needed these updates to my Apache2 config:
RewriteEngine on
RewriteBase /zm/api
</Directory>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteBase /zm/api
</Directory>
RewriteEngine On
RewriteRule ^ index.php [L]
RewriteBase /zm/api
</Directory>
You spoony bard!
