Cannot View Event Video
bclwow
Post by bclwow » Mon Nov 27, 2017 9:49 pm
I'm currently running ZM 1.30.4 on Ubuntu 16.04.2 LTS. I had a previous, identical installation (at least I'm pretty sure it was identical except for this problem) on a VM server running with no issues. Same cameras, same config, etc.
I built a more powerful VM server and created a new, clean VM and installed Zoneminder according to the Easy Way: Ubuntu 16.04 installation guide. Live streaming works, filters are working, defined zones and motion detection are working and events are captured and logged. The trouble is replaying recorded event video. When I try to playback it will display one frame from the event then immediately go black displaying "Time to next event = X seconds". This happens regardless of web browser and also happens in zmNinja. Still images display and I can download the event video file and it will play fine on the computer.
I've double checked the CGI paths, all seem correct. I did change the PATH_ZMS from /zm/cgi-bin/nph-zms to just /zm/cgi-bin/zms with no differences noted.
Here's the logfile for the last 10 minutes after a ZM restart. During this time I did several live views and tried to view events individually and via montage.
Help? Thanks.
2017-11-27 16:40:34.486105	zma_m4		16923	INF	Pool: 6000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:40:34.482165	zma_m5		16921	INF	Garage: 6000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:40:34.441150	zma_m3		16920	INF	East Side: 6000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:40:34.396806	zma_m2		16922	INF	Front Door: 6000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:40:32.359300	zmc_m5		16856	INF	Garage: 6000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:40:32.139414	zmc_m4		16844	INF	Pool: 6000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:40:31.952300	zmc_m3		16833	INF	East Side: 6000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:40:31.737957	zmc_m2		16823	INF	Front Door: 6000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:40:28.249101	zms		17343	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:38:53.517958	zma_m5		16921	INF	Garage: 5000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:38:53.514038	zma_m4		16923	INF	Pool: 5000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:38:53.402160	zma_m3		16920	INF	East Side: 5000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:38:53.385077	zma_m2		16922	INF	Front Door: 5000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:38:51.327996	zmc_m5		16856	INF	Garage: 5000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:38:51.140362	zmc_m4		16844	INF	Pool: 5000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:38:50.976418	zmc_m3		16833	INF	East Side: 5000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:38:50.743892	zmc_m2		16823	INF	Front Door: 5000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:38:24.364528	zms		17255	ERR	Unable to send stream frame: Broken pipe	zm_event.cpp	1348
2017-11-27 16:38:24.363537	zms		17255	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:37:12.472808	zma_m5		16921	INF	Garage: 4000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:37:12.468544	zma_m4		16923	INF	Pool: 4000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:37:12.397456	zma_m3		16920	INF	East Side: 4000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:37:12.390628	zma_m2		16922	INF	Front Door: 4000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:37:10.338656	zmc_m5		16856	INF	Garage: 4000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:37:10.152698	zmc_m4		16844	INF	Pool: 4000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:37:09.922124	zmc_m3		16833	INF	East Side: 4000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:37:09.737255	zmc_m2		16823	INF	Front Door: 4000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:35:31.467216	zma_m5		16921	INF	Garage: 3000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:35:31.445717	zma_m4		16923	INF	Pool: 3000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:35:31.382920	zma_m2		16922	INF	Front Door: 3000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:35:31.378762	zma_m3		16920	INF	East Side: 3000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:35:29.318168	zmc_m5		16856	INF	Garage: 3000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:35:29.106817	zmc_m4		16844	INF	Pool: 3000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:35:28.936366	zmc_m3		16833	INF	East Side: 3000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:35:28.719449	zmc_m2		16823	INF	Front Door: 3000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:34:48.142791	zms		17093	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:34:47.966973	zms		17095	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:34:47.946221	zms		17096	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:34:47.935545	zms		17094	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:33:58.763821	web_js		10733	ERR	Uncaught RangeError: Maximum call stack size exceeded	http://10.2.6.20/zm/tools/mootools/mootools-core.js	1
2017-11-27 16:33:50.479776	zma_m4		16923	INF	Pool: 2000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:33:50.457720	zma_m5		16921	INF	Garage: 2000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:33:50.364967	zma_m2		16922	INF	Front Door: 2000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:33:50.356858	zma_m3		16920	INF	East Side: 2000 - Analysing at 9.90 fps	zm_monitor.cpp	1296
2017-11-27 16:33:49.532307	web_js		14933	ERR	Uncaught RangeError: Maximum call stack size exceeded	http://10.2.6.20/zm/tools/mootools/mootools-core.js	1
2017-11-27 16:33:48.308767	zmc_m5		16856	INF	Garage: 2000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:33:48.108553	zmc_m4		16844	INF	Pool: 2000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:33:47.947071	zmc_m3		16833	INF	East Side: 2000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:33:47.707178	zmc_m2		16823	INF	Front Door: 2000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:32:45.261469	zms		17009	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:32:35.745506	zms		16947	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:32:21.266423	zms		16956	ERR	Unable to send stream frame: Broken pipe	zm_event.cpp	1348
2017-11-27 16:32:21.260291	zms		16956	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:32:09.458640	zma_m4		16923	INF	Pool: 1000 - Analysing at 10.10 fps	zm_monitor.cpp	1296
2017-11-27 16:32:09.455485	zma_m5		16921	INF	Garage: 1000 - Analysing at 10.10 fps	zm_monitor.cpp	1296
2017-11-27 16:32:09.367279	zma_m2		16922	INF	Front Door: 1000 - Analysing at 10.10 fps	zm_monitor.cpp	1296
2017-11-27 16:32:09.358369	zma_m3		16920	INF	East Side: 1000 - Analysing at 10.10 fps	zm_monitor.cpp	1296
2017-11-27 16:32:07.317384	zmc_m5		16856	INF	Garage: 1000 - Capturing at 9.80 fps	zm_monitor.cpp	3125
2017-11-27 16:32:07.123607	zmc_m4		16844	INF	Pool: 1000 - Capturing at 9.80 fps	zm_monitor.cpp	3125
2017-11-27 16:32:06.923907	zmc_m3		16833	INF	East Side: 1000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:32:06.688747	zmc_m2		16823	INF	Front Door: 1000 - Capturing at 9.90 fps	zm_monitor.cpp	3125
2017-11-27 16:31:51.570520	zmvideo		16959	INF	Finished Event-20975-r1-s1.mpg	zmvideo.pl
2017-11-27 16:31:46.536040	zmtelemetry		16887	WAR	Telemetry server returned HTTP POST error code: 500	zmtelemetry.pl
2017-11-27 16:31:46.309630	zmvideo		16959	INF	Creating video file Event-20975-r1-s1.mpg for event 20975	zmvideo.pl
2017-11-27 16:31:36.052455	web_js		16092	WAR	Ignoring passed dimensions 1920x1080 when getting popup size for tag 'video' - getPopupSize()	?view=event
2017-11-27 16:31:18.558745	zms		16950	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-11-27 16:31:06.467910	zmtelemetry		16887	INF	Sending data to ZoneMinder Telemetry server.	zmtelemetry.pl
2017-11-27 16:31:06.465560	zmupdate		16880	ERR	Error check failed: '500 Can't connect to update.zoneminder.com:443'	zmupdate.pl
2017-11-27 16:30:30.176236	zma_m2		16922	INF	In mode 3/1, warming up	zma.cpp	142
2017-11-27 16:30:30.163197	zma_m4		16923	INF	In mode 3/1, warming up	zma.cpp	142
2017-11-27 16:30:30.120189	zma_m5		16921	INF	In mode 3/1, warming up	zma.cpp	142
2017-11-27 16:30:30.108207	zma_m3		16920	INF	In mode 3/1, warming up	zma.cpp	142
2017-11-27 16:30:30.075720	zmdc		16922	INF	'zma -m 2' started at 17/11/27 16:30:30	zmdc.pl
2017-11-27 16:30:30.075160	zmdc		16923	INF	'zma -m 4' started at 17/11/27 16:30:30	zmdc.pl
2017-11-27 16:30:30.069030	zmdc		16794	INF	'zma -m 4' starting at 17/11/27 16:30:30, pid = 16923	zmdc.pl
2017-11-27 16:30:30.067580	zmdc		16921	INF	'zma -m 5' started at 17/11/27 16:30:30	zmdc.pl
2017-11-27 16:30:30.067560	zmdc		16794	INF	Starting pending process, zma -m 4	zmdc.pl
2017-11-27 16:30:30.066770	zmdc		16794	INF	'zma -m 2' starting at 17/11/27 16:30:30, pid = 16922	zmdc.pl
2017-11-27 16:30:30.065440	zmdc		16794	INF	Starting pending process, zma -m 2	zmdc.pl
2017-11-27 16:30:30.064810	zmdc		16794	INF	'zma -m 5' starting at 17/11/27 16:30:30, pid = 16921	zmdc.pl
2017-11-27 16:30:30.063360	zmdc		16794	INF	Starting pending process, zma -m 5	zmdc.pl
2017-11-27 16:30:30.062780	zmdc		16920	INF	'zma -m 3' started at 17/11/27 16:30:30	zmdc.pl
2017-11-27 16:30:30.062400	zmdc		16794	INF	'zma -m 3' starting at 17/11/27 16:30:30, pid = 16920	zmdc.pl
2017-11-27 16:30:30.060080	zmdc		16794	INF	Starting pending process, zma -m 3	zmdc.pl
2017-11-27 16:30:26.343840	zmtelemetry		16887	INF	Collecting data to send to ZoneMinder Telemetry server.	zmtelemetry.pl
2017-11-27 16:30:26.257730	zmupdate		16880	INF	Checking for updates	zmupdate.pl
2017-11-27 16:30:26.169080	zmdc		16887	INF	'zmtelemetry.pl' started at 17/11/27 16:30:26	zmdc.pl
2017-11-27 16:30:26.163510	zmdc		16794	INF	'zmtelemetry.pl' starting at 17/11/27 16:30:26, pid = 16887	zmdc.pl
2017-11-27 16:30:26.161340	zmfilter		16865	INF	Scanning for events	zmfilter.pl
2017-11-27 16:30:26.065880	zmwatch		16874	INF	Watchdog pausing for 30 seconds	zmwatch.pl
2017-11-27 16:30:26.064760	zmwatch		16874	INF	Watchdog starting	zmwatch.pl
2017-11-27 16:30:26.040750	zmdc		16880	INF	'zmupdate.pl -c' started at 17/11/27 16:30:26	zmdc.pl
2017-11-27 16:30:26.040750	zmdc		16794	INF	'zmupdate.pl -c' starting at 17/11/27 16:30:26, pid = 16880	zmdc.pl
2017-11-27 16:30:25.935040	zmdc		16874	INF	'zmwatch.pl' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.927930	zmdc		16794	INF	'zmwatch.pl' starting at 17/11/27 16:30:25, pid = 16874	zmdc.pl
2017-11-27 16:30:25.838300	zmdc		16869	INF	'zmaudit.pl -c' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.838300	zmdc		16794	INF	'zmaudit.pl -c' starting at 17/11/27 16:30:25, pid = 16869	zmdc.pl
2017-11-27 16:30:25.764090	zmdc		16865	INF	'zmfilter.pl' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.764080	zmdc		16794	INF	'zmfilter.pl' starting at 17/11/27 16:30:25, pid = 16865	zmdc.pl
2017-11-27 16:30:25.746462	zmc_m5		16856	INF	Priming capture from rtsp://notuser:notpass@10.2.6.24:554/Streaming/Channels/1?transportmode=mcast&profile=Profile_1	zm_ffmpeg_camera.cpp	104
2017-11-27 16:30:25.745458	zmc_m5		16856	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-11-27 16:30:25.712600	zmdc		16794	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.702442	zma_m5		16863	ERR	Shared data not initialised by capture daemon for monitor Garage	zm_monitor.cpp	442
2017-11-27 16:30:25.674890	zmdc		16863	INF	'zma -m 5' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.668100	zmdc		16794	INF	'zma -m 5' starting at 17/11/27 16:30:25, pid = 16863	zmdc.pl
2017-11-27 16:30:25.666730	zmdc		16794	INF	Starting pending process, zma -m 5	zmdc.pl
2017-11-27 16:30:25.665920	zmdc		16794	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.663877	zma_m5		16859	ERR	Shared data not initialised by capture daemon for monitor Garage	zm_monitor.cpp	442
2017-11-27 16:30:25.630860	zmdc		16859	INF	'zma -m 5' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.621380	zmdc		16794	INF	'zma -m 5' starting at 17/11/27 16:30:25, pid = 16859	zmdc.pl
2017-11-27 16:30:25.552280	zmdc		16856	INF	'zmc -m 5' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.551140	zmdc		16794	INF	'zmc -m 5' starting at 17/11/27 16:30:25, pid = 16856	zmdc.pl
2017-11-27 16:30:25.549690	zmdc		16794	INF	Starting pending process, zmc -m 5	zmdc.pl
2017-11-27 16:30:25.548980	zmdc		16794	ERR	'zmc -m 5' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.538353	zmc_m4		16844	INF	Priming capture from rtsp://notuser:notpass@10.2.6.23:554/Streaming/Channels/1?transportmode=mcast&profile=Profile_1	zm_ffmpeg_camera.cpp	104
2017-11-27 16:30:25.535514	zmc_m4		16844	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-11-27 16:30:25.525860	zmdc		16853	INF	'zmc -m 5' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.524220	zmdc		16794	INF	'zmc -m 5' starting at 17/11/27 16:30:25, pid = 16853	zmdc.pl
2017-11-27 16:30:25.489770	zmdc		16794	ERR	'zma -m 4' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.487706	zma_m4		16851	ERR	Shared data not initialised by capture daemon for monitor Pool	zm_monitor.cpp	442
2017-11-27 16:30:25.462360	zmdc		16851	INF	'zma -m 4' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.454780	zmdc		16794	INF	'zma -m 4' starting at 17/11/27 16:30:25, pid = 16851	zmdc.pl
2017-11-27 16:30:25.453240	zmdc		16794	INF	Starting pending process, zma -m 4	zmdc.pl
2017-11-27 16:30:25.452380	zmdc		16794	ERR	'zma -m 4' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.449988	zma_m4		16847	ERR	Shared data not initialised by capture daemon for monitor Pool	zm_monitor.cpp	442
2017-11-27 16:30:25.426340	zmdc		16847	INF	'zma -m 4' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.424940	zmdc		16794	INF	'zma -m 4' starting at 17/11/27 16:30:25, pid = 16847	zmdc.pl
2017-11-27 16:30:25.374210	zmc_m3		16833	INF	Priming capture from rtsp://notuser:notpass@10.2.6.22:554/Streaming/Channels/1?transportmode=mcast&profile=Profile_1	zm_ffmpeg_camera.cpp	104
2017-11-27 16:30:25.372630	zmc_m3		16833	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-11-27 16:30:25.345230	zmdc		16844	INF	'zmc -m 4' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.341890	zmdc		16794	INF	'zmc -m 4' starting at 17/11/27 16:30:25, pid = 16844	zmdc.pl
2017-11-27 16:30:25.340540	zmdc		16794	INF	Starting pending process, zmc -m 4	zmdc.pl
2017-11-27 16:30:25.339410	zmdc		16794	ERR	'zmc -m 4' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.320650	zmdc		16841	INF	'zmc -m 4' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.319260	zmdc		16794	INF	'zmc -m 4' starting at 17/11/27 16:30:25, pid = 16841	zmdc.pl
2017-11-27 16:30:25.305000	zmdc		16794	ERR	'zma -m 3' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.303249	zma_m3		16839	ERR	Shared data not initialised by capture daemon for monitor East Side	zm_monitor.cpp	442
2017-11-27 16:30:25.274910	zmdc		16839	INF	'zma -m 3' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.268540	zmdc		16794	INF	'zma -m 3' starting at 17/11/27 16:30:25, pid = 16839	zmdc.pl
2017-11-27 16:30:25.266910	zmdc		16794	INF	Starting pending process, zma -m 3	zmdc.pl
2017-11-27 16:30:25.265980	zmdc		16794	ERR	'zma -m 3' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.263866	zma_m3		16835	ERR	Shared data not initialised by capture daemon for monitor East Side	zm_monitor.cpp	442
2017-11-27 16:30:25.220060	zmdc		16835	INF	'zma -m 3' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.218370	zmdc		16794	INF	'zma -m 3' starting at 17/11/27 16:30:25, pid = 16835	zmdc.pl
2017-11-27 16:30:25.196100	zmc_m2		16823	INF	Priming capture from rtsp://notuser:notpass@10.2.6.25:554/Streaming/Channels/1?transportmode=mcast&profile=Profile_1	zm_ffmpeg_camera.cpp	104
2017-11-27 16:30:25.195333	zmc_m2		16823	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-11-27 16:30:25.130960	zmdc		16833	INF	'zmc -m 3' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.124320	zmdc		16794	INF	'zmc -m 3' starting at 17/11/27 16:30:25, pid = 16833	zmdc.pl
2017-11-27 16:30:25.122530	zmdc		16794	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-11-27 16:30:25.121180	zmdc		16794	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.098710	zmdc		16830	INF	'zmc -m 3' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.098690	zmdc		16794	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.096740	zmdc		16794	INF	'zmc -m 3' starting at 17/11/27 16:30:25, pid = 16830	zmdc.pl
2017-11-27 16:30:25.096439	zma_m2		16828	ERR	Shared data not initialised by capture daemon for monitor Front Door	zm_monitor.cpp	442
2017-11-27 16:30:25.066340	zmdc		16828	INF	'zma -m 2' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.060270	zmdc		16794	INF	'zma -m 2' starting at 17/11/27 16:30:25, pid = 16828	zmdc.pl
2017-11-27 16:30:25.058310	zmdc		16794	INF	Starting pending process, zma -m 2	zmdc.pl
2017-11-27 16:30:25.057790	zmdc		16794	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:25.055916	zma_m2		16825	ERR	Shared data not initialised by capture daemon for monitor Front Door	zm_monitor.cpp	442
2017-11-27 16:30:25.019550	zmdc		16825	INF	'zma -m 2' started at 17/11/27 16:30:25	zmdc.pl
2017-11-27 16:30:25.018490	zmdc		16794	INF	'zma -m 2' starting at 17/11/27 16:30:25, pid = 16825	zmdc.pl
2017-11-27 16:30:24.981310	zmdc		16823	INF	'zmc -m 2' started at 17/11/27 16:30:24	zmdc.pl
2017-11-27 16:30:24.980130	zmdc		16794	INF	'zmc -m 2' starting at 17/11/27 16:30:24, pid = 16823	zmdc.pl
2017-11-27 16:30:24.978450	zmdc		16794	INF	Starting pending process, zmc -m 2	zmdc.pl
2017-11-27 16:30:24.977500	zmdc		16794	ERR	'zmc -m 2' exited abnormally, exit status 255	zmdc.pl
2017-11-27 16:30:24.935620	zmdc		16820	INF	'zmc -m 2' started at 17/11/27 16:30:24	zmdc.pl
2017-11-27 16:30:24.935620	zmdc		16794	INF	'zmc -m 2' starting at 17/11/27 16:30:24, pid = 16820	zmdc.pl
2017-11-27 16:30:24.864250	zmpkg		16777	INF	Single server configuration detected. Starting up services.	zmpkg.pl
2017-11-27 16:30:21.861120	zmdc		16794	INF	Server starting at 17/11/27 16:30:21	zmdc.pl
2017-11-27 16:30:21.709640	zmpkg		16777	INF	Command: start	zmpkg.pl
2017-11-27 16:30:21.688270	zmpkg		16777	INF	Sanity checking States table...	zmpkg.pl
2017-11-27 16:30:21.596780	zmdc		19836	INF	Server shutdown at 17/11/27 16:30:21	zmdc.pl
Re: Cannot View Event Video
Post by bbunge » Mon Nov 27, 2017 11:27 pm
Check free space in tmpfs.
Change PATH_SWAP to /dev/shm
bclwow
Post by bclwow » Wed Nov 29, 2017 6:44 pm
tmpfs is 11% used.
Changed PATH_SWAP and restarted ZM. No change. Still won't playback events. :(
bclwow
Post by bclwow » Thu Jul 05, 2018 4:19 pm
Following up on this again. Tried many different things then gave up for a while. Yesterday, the inability to playback events finally bugged me enough to create another brand new VM install for Zoneminder. Same directions, same set up, no issues except event playback still doesn't work. Displays one frame then goes black. I can pull up the still images and scroll through them and download the entire event video for playback. But I cannot review any event playback in a browser or zmNinja.
Here's the interesting thing I did differently this time. I set one camera to record continuously and I CAN playback the continuous recordings without any issue. What the heck...
Lee Sharp
Post by Lee Sharp » Sun Aug 05, 2018 1:41 am
I am also getting this. Not often, and on different cameras. But often enough to be a problem. I lothe to try the fix below as then the events start too late. viewtopic.php?f=29&t=21511
Also, tmpfs is 3% and my swap is almost untouched. But it is using a bit so I may try bumping the ram. it is a VM after all.
Lee Sharp
Post by Lee Sharp » Sun Aug 12, 2018 3:01 am
Bumped CPU and RAM and still get it.
Post by iconnor » Sun Aug 12, 2018 5:54 pm
Check your apache logs. I'll bet you are getting a lot of 404's on the cgi request.
Post by bbunge » Mon Aug 13, 2018 12:59 am
You may want to check your install procedures. Use this: https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
There is a script that make the install easy. You will still need to set up the cameras. Also, use a minimal Ubuntu install with a net install .iso.
Lee Sharp
Post by Lee Sharp » Sun Sep 02, 2018 1:23 am
Nothing in the apache logs. OK, the FQDN error, and that is about it.
I did you that recipe on an Ubuntu server install. Went thought it more then twice as I missed a pathing setting.
phoner
Post by phoner » Sat Jun 20, 2020 4:42 am
Any new updates on this issue? Same issue using version v1.34.12
I noticed chrome is a little more forgiving in that it will allow you to skip to the next set once the message comes up. In firefox it gives a black screen and seems to not play anything else.
phoner
Post by phoner » Fri Jul 10, 2020 3:45 pm
I'm going to reinstall the whole system, these errors are popping up all over. I'm wondering if I should go back a few versions before this was an issue?
Users browsing this forum: No registered users and 14 guests
