I've run across having a similar needs as I, but it's been approached in a different (what I believe is more complicated) manner.
I'm thinking that having a filter test for "Run State" (string comparison) would allow me to create a run state of say "NoEmail" and I could toggle the server's run state to "NoEmail" which would then cause the filter test to turn off sending e-mail (for those filters conditioned to do so). I utilize zmNinja a lot; it readily allows for the changing of run states (but no access to modify filters).
My need arises out of the fact that I would like to reduce the amount of e-mail alerts that I am generating (mail host/provider starts blocking me as spam when I start generating a lot of e-mails). I have conditions that do not allow me to more finely tune down the number of alerts; I'm about as optimized as I can be using zones.
I don't want to add external scripts and stuff because I wish to minimize the calls outside of Zoneminder's code.
Run State filter test?
Re: Run State filter test?
I see that there's something in 1.31?
https://github.com/ZoneMinder/zoneminder/pull/1752
But I cannot find much else discussing it.
See: https://github.com/zoneminder/zoneminder/issues/1750SkippyDo wrote: ↑Fri May 04, 2018 7:47 pmI see that there's something in 1.31?
viewtopic.php?f=30&=&t=21459
viewtopic.php?f=29&=&t=21702
https://wiki.zoneminder.com/SMS_Notifications#Notes
Read the pull request/code. I have hacked this into 1.30.4 and it works great.
You "hacked it into 1.30.4?" Not part of 1.30.4?
Everything you link to points to that github 1752 thread and that thread only states that there is a code change (supposedly for this), there is no mention of how it was implemented (I cannot find any documentation).
The SMS_Notification Notes points to: https://wiki.zoneminder.com/Filter_on_run_states, which comes up as:
There is currently no text in this page. You can search for this page title in other pages, or [?title=Special:Log&page=Filter_on_run_states search the related logs], but you do not have permission to create this page.
And of course, when I do a search as suggested I get nothing of use (comes back to the SMS notifications page, again).
No, it is not part of 1.30.4, I don't think.
Right now, your options are to upgrade to 1.31 which is unstable, wait for 1.31 to have a stable release, or hack it into 1.30.4. Hacking it into 1.30.4, means downloading the source, and compiling from scratch. Per: https://wiki.zoneminder.com/SMS_Notifications#Notes
I do need to fix this link.SkippyDo wrote: ↑Sat May 05, 2018 6:06 pmThe SMS_Notification Notes points to: https://wiki.zoneminder.com/Filter_on_run_states, which comes up as:
OK, thanks for the clarification.
Knowing that it'll be in the next release I'll just hold off and wait: I'd compiled 1.30.4 previously when I was testing an implementation (new to ZM) and found it to be a bit of a headache (I did, however, manage to get it to compile and work); I'm basically in production now and don't want to mess things up.
Users browsing this forum: No registered users and 6 guests
