Ubuntu 16.04, zmpkg.pl is on /usr/bin/.
From terminal I can change the state with on issue at all with
sudo usr/bin/zmpkg.pl Closed
After reading the FAQ I added with crontab -e the fellowing lines:
01 7 * * 1-6 root /usr/bin/zmpkg.pl Open
01 22 * * 1-5 root /usr/bin/zmpkg.pl Closed
31 15 * * 6 root /usr/bin/zmpkg.pl Closed
effe@DivinaCameras:~$ tail -f /var/log/syslog | grep CRON
Sep 8 11:11:01 DivinaCameras CRON[3547]: (effe) CMD (/usr/bin/zmpkg.pl Closed)
Sep 8 11:11:01 DivinaCameras CRON[3546]: (CRON) info (No MTA installed, discarding output)
Sep 8 11:13:01 DivinaCameras CRON[3587]: (effe) CMD (www-data /usr/bin/zmpkg.pl Closed)
Sep 8 11:13:01 DivinaCameras CRON[3586]: (CRON) info (No MTA installed, discarding output)
Sep 8 11:15:01 DivinaCameras CRON[3636]: (effe) CMD (root /usr/bin/zmpkg.pl Closed)
Sep 8 11:15:01 DivinaCameras CRON[3635]: (CRON) info (No MTA installed, discarding output)
Sep 8 11:34:01 DivinaCameras CRON[3928]: (effe) CMD (effe /usr/bin/zmpkg.pl Closed)
Sep 8 11:34:01 DivinaCameras CRON[3927]: (CRON) info (No MTA installed, discarding output)
Thanks,
F.
