Thousands of Blue Screen events on remote IP cameras
jonathancnewcomb
Re: Thousands of Blue Screen events on remote IP cameras
Post by jonathancnewcomb » Sun Feb 03, 2013 5:17 pm
Hello, I am a network engineer, I had a similar problem and I found that TCP retransmissions were the root cause of the problem. You can validate this by installing tcpdump and tcptrace on your linux box (look for them in your package manager) then use the following filter:
$ tcpdump -i [interface] -w dump.out port 80
Let this run until you catch a loss of signal, then evaluate using tcptrace:
Use CTRL+C to break
Note: You should see "X packets received by filter" where X is > 0
$ tcptrace dump.out
Now then, you will see a list of TCP streams that were captured, there will be a number associated. Find the number next to the stream for your camera and replace the "#" below with that number:
$ tcptrace -r -l -o# dump.out
You will see values in the output such as RTT and max # retrans, ensure that your RTT is below 150ms and the number of retransmissions are close to 0 (this will vary depending on capture time). Also, you will see throughput used by the stream, ensure your switch is capable of handling the load. All switches have maximum throughput and you may have to take that into account too.
mmike
Post by mmike » Mon Jul 31, 2017 3:45 am
netwrkr wrote:
Tue May 01, 2012 2:25 pm
Similar issue here - I resolved it by removing any settings in "Maximum FPS" for each camera. HTH
Same problem, this fixed the issue. I also removed the Alarm Maximum FPS also to see what happens.
Vladyck
Post by Vladyck » Thu Jan 31, 2019 9:37 am
I had same problem. decreasing FPS & quality on camera appropriate to monitor`s settings / network bandwidth has resolved this
Users browsing this forum: No registered users and 10 guests
