Page 1 of 1
Debian Repo Distribution
Posted: Fri Mar 05, 2021 2:44 pm
by benjobeast
I installed following the documented instructions for Debian Stretch. I then noticed that this installed v1.32.3 is there a link somewhere to when the repo version will be updated to 1.34?
https://zmrepo.zoneminder.com/debian/release/stretch/
Re: Debian Repo Distribution
Posted: Fri Mar 05, 2021 5:04 pm
by iconnor
We create a new repo for each major version. You need to use {url]
https://zmrepo.zoneminder.com/debian/re ... 4/stretch/[/url]
Posted: Fri Mar 05, 2021 9:54 pm
by benjobeast
Thank you! I will use that.
Posted: Fri Mar 05, 2021 10:45 pm
by benjobeast
So I have put
deb https://zmrepo.zoneminder.com/debian/release-1.34 stretch
into my sources.list and I am getting an error saying
E: Malformed entry 16 in list file /etc/apt/sources.list (Component)
Posted: Sat Mar 06, 2021 12:36 am
by iconnor
needs a trailing /
Posted: Sat Mar 06, 2021 4:24 am
by benjobeast
I actually did try that too no luck.
Posted: Sat Mar 06, 2021 4:57 am
by benjobeast
Correction, I misunderstood which trailing slash I was missing. I thought it was after release-1.34, you meant after stretch. Thank you for the help!
Posted: Mon May 03, 2021 9:27 pm
by nik282000
Just wanted to pop in and say thanks to iconnor. I've used ZoneMinder on Debian for about a year and a half now and it is awesome.
