Page 1 of 2
Upgraded from 1.34.16 to 1.34.18 no motion events
Posted: Sun Aug 09, 2020 2:41 am
by drkananga
I upgraded from .16 to .18 and after that I cant se any motion events
Not in watch view, not in montage review..
All cameras are in mocord
All I did vas "apt update, apt apgrade" on my pc (Ubuntu)
were do I start to troubleshoot?
Re: Upgraded from 1.34.16 to 1.34.18 no motion events
Posted: Sun Aug 09, 2020 3:16 am
by iconnor
Start by posting some logs.
This would be a big problem if it affects more than 1 person. The devs have had no problems with motion events.
Please everyone check your systems and report in.
Posted: Sun Aug 09, 2020 12:20 pm
by bbunge
Have a test setup running with just one FFMPEG cam. Seems to be working OK except for setting up a USB cam. Ubuntu 20.04 LAMP
Productiion system, 19 cams, in warehouse was upgraded yesterday afternoon. It too gets motion after it was upgraded. Ubuntu 18.04 LEMP
bb
Posted: Sun Aug 09, 2020 12:26 pm
by bkjaya1952
I have tested with fresh installation of Zoneminder 1.34.18 for a Hikvision IP camera and found views ,motion events , and montage review are working correctly .
Only problem that I have noticed is inability in adding usb camera monitors ( This problem has already been informed by a post )
- Screenshot from 2020-08-09 17-45-59.png (394.95 KiB) Viewed 3484 times
Posted: Sun Aug 09, 2020 9:53 pm
by w00tl00ps
Hi, I think I might be having the same issue as the OP.
I'm using an old laptop with Ubuntu 18.04 and I recently updated to 1.34.18. My cameras that are on mocord records video properly but do not register any motion events. I noticed that if I switch them to modect, everything works perfectly. Motion is detected and I also receive notifications via zmNinja and MQTT.
I restarted ZoneMinder with one of my cameras set to mocord and I see a couple errors show up in the logs for my FrontDoor camera when I step in front of it:
2020-08-09 17:48:16 zmc_m2 16594 INF FrontDoor: images:600 - Capturing at 7.14 fps, capturing bandwidth 304160bytes/sec zm_monitor.cpp 2534
2020-08-09 17:48:15 zma_m1 16597 INF Driveway: 500 - Analysing at 6.25 fps zm_monitor.cpp 1303
2020-08-09 17:48:14 zmc_m1 16586 INF Driveway: images:500 - Capturing at 6.25 fps, capturing bandwidth 669701bytes/sec zm_monitor.cpp 2534
2020-08-09 17:48:12 zma_m2 16803 INF In mode 5/1, warming up zma.cpp 136
2020-08-09 17:48:12 zma_m2 16803 INF FrontDoor: 001 - Opening new event 78424, section start zm_monitor.cpp 1525
2020-08-09 17:48:12 zmc_m2 16594 INF Re-starting video storage module zm_ffmpeg_camera.cpp 806
2020-08-09 17:48:12 zmc_m2 16594 INF Opening video storage stream /var/cache/zoneminder/events/2/2020-08-09/78424/78424-video.mp4 format: mp4 zm_videostore.cpp 63
2020-08-09 17:48:12 zmc_m2 16594 INF some options not used, turn on debugging for a list. zm_videostore.cpp 440
2020-08-09 17:48:12 zmc_m2 16594 INF Didn't find a frame before event starttime. keeping all zm_packetqueue.cpp 321
2020-08-09 17:48:12 zmc_m2 16594 INF Event video offset is 73.673 sec (<0 means video starts early) zm_ffmpeg_camera.cpp 883
2020-08-09 17:48:11 zmdc 16556 INF 'zma -m 2' starting at 20/08/09 17:48:11, pid = 16803 zmdc.pl
2020-08-09 17:48:11 zmdc 16803 INF 'zma -m 2' started at 20/08/09 17:48:11 zmdc.pl
2020-08-09 17:48:11 zmdc 16556 INF Starting pending process, zma -m 2 zmdc.pl
2020-08-09 17:48:11 zms_m2 16799 INF Authenticated user 'hassio' zm_user.cpp 141
2020-08-09 17:48:11 zmc_m2 16594 WAR Buffer overrun at index 1, image 561, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 2497
2020-08-09 17:48:11 zms_m3 16800 INF Authenticated user 'hassio' zm_user.cpp 141
2020-08-09 17:48:11 zms_m1 16801 INF Authenticated user 'hassio' zm_user.cpp 141
2020-08-09 17:48:10 zmdc 16556 ERR 'zma -m 2' exited abnormally, exit status 11 zmdc.pl
2020-08-09 17:48:09 zma_m2 16599 ERR Signal address is 0x47075cf0, from 0x4a2841 zm_signal.cpp 83
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 0: /usr/bin/zma(_Z14zm_die_handleriP9siginfo_tPv+0x7c) [0x4e491c] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 1: linux-gate.so.1(__kernel_rt_sigreturn+0) [0xb7fd5bcc] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 2: /usr/bin/zma(_ZN5Event16AddPreAlarmFrameEP5Image7timevaliS1_+0x91) [0x4a2841] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 3: /usr/bin/zma(_ZN7Monitor7AnalyseEv+0x25a6) [0x4a1c76] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 4: /usr/bin/zma(main+0x46c) [0x4704ec] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 5: /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf1) [0xb56a0e91] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 ERR Backtrace 6: /usr/bin/zma(+0x1c6b9) [0x4716b9] zm_signal.cpp 104
2020-08-09 17:48:09 zma_m2 16599 INF addr2line -e /usr/bin/zma 0x4e491c 0xb7fd5bcc 0x4a2841 0x4a1c76 0x4704ec 0xb56a0e91 0x4716b9 zm_signal.cpp 112
2020-08-09 17:48:09 zma_m2 16599 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 111
2020-08-09 17:48:08 zma_m2 16599 INF FrontDoor: 484 - Gone into alarm state PreAlarmCount: 13 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:08 zma_m2 16599 INF FrontDoor: 485 - Gone into alarm state PreAlarmCount: 14 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:08 zma_m2 16599 INF FrontDoor: 486 - Gone into alarm state PreAlarmCount: 15 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:08 zma_m2 16599 INF FrontDoor: 487 - Gone into alarm state PreAlarmCount: 16 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:08 zma_m2 16599 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2020-08-09 17:48:07 zma_m2 16599 INF FrontDoor: 481 - Gone into alarm state PreAlarmCount: 10 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:07 zma_m2 16599 INF FrontDoor: 482 - Gone into alarm state PreAlarmCount: 11 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:07 zma_m2 16599 INF FrontDoor: 483 - Gone into alarm state PreAlarmCount: 12 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:07 zma_m2 16599 INF FrontDoor: 480 - Gone into alarm state PreAlarmCount: 9 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:07 zma_m2 16599 INF FrontDoor: 479 - Gone into alarm state PreAlarmCount: 8 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:06 zma_m2 16599 INF FrontDoor: 478 - Gone into alarm state PreAlarmCount: 7 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:06 zma_m2 16599 INF FrontDoor: 477 - Gone into alarm state PreAlarmCount: 6 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:06 zma_m2 16599 INF FrontDoor: 476 - Gone into alarm state PreAlarmCount: 5 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:06 zma_m2 16599 INF FrontDoor: 475 - Gone into alarm state PreAlarmCount: 4 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:06 zma_m2 16599 INF FrontDoor: 474 - Gone into alarm state PreAlarmCount: 3 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:05 zma_m2 16599 INF FrontDoor: 473 - Gone into alarm state PreAlarmCount: 2 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:05 zma_m2 16599 INF FrontDoor: 471 - Gone into prealarm state zm_monitor.cpp 1640
2020-08-09 17:48:05 zma_m2 16599 INF FrontDoor: 468 - Gone into alarm state PreAlarmCount: 14 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:04 zma_m2 16599 INF FrontDoor: 464 - Gone into alarm state PreAlarmCount: 10 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:04 zma_m3 16607 INF DCS: 500 - Analysing at 6.67 fps zm_monitor.cpp 1303
2020-08-09 17:48:04 zma_m2 16599 INF FrontDoor: 465 - Gone into alarm state PreAlarmCount: 11 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:04 zma_m2 16599 INF FrontDoor: 466 - Gone into alarm state PreAlarmCount: 12 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:04 zma_m2 16599 INF FrontDoor: 467 - Gone into alarm state PreAlarmCount: 13 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:03 zma_m2 16599 INF FrontDoor: 459 - Gone into alarm state PreAlarmCount: 5 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:03 zma_m2 16599 INF FrontDoor: 460 - Gone into alarm state PreAlarmCount: 6 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:03 zma_m2 16599 INF FrontDoor: 461 - Gone into alarm state PreAlarmCount: 7 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:03 zmc_m3 16603 INF DCS: images:500 - Capturing at 6.67 fps, capturing bandwidth 293760bytes/sec zm_monitor.cpp 2534
2020-08-09 17:48:03 zma_m2 16599 INF FrontDoor: 462 - Gone into alarm state PreAlarmCount: 8 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:03 zma_m2 16599 INF FrontDoor: 463 - Gone into alarm state PreAlarmCount: 9 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:02 zma_m2 16599 INF FrontDoor: 457 - Gone into alarm state PreAlarmCount: 3 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:02 zma_m2 16599 INF FrontDoor: 458 - Gone into alarm state PreAlarmCount: 4 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:02 zma_m2 16599 INF FrontDoor: 456 - Gone into alarm state PreAlarmCount: 2 > AlarmFrameCount:3 Cause: All zm_monitor.cpp 1565
2020-08-09 17:48:02 zmc_m2 16594 INF FrontDoor: images:500 - Capturing at 7.14 fps, capturing bandwidth 328829bytes/sec zm_monitor.cpp 2534
2020-08-09 17:48:02 zma_m2 16599 INF FrontDoor: 454 - Gone into prealarm state zm_monitor.cpp 1640
2020-08-09 17:48:01 zma_m2 16599 INF ExtendAlarm count: 0, ExtendAlarm frames: 0 zm_zone.cpp 188
Any assistance would be great.
Thanks!
Posted: Sun Aug 09, 2020 11:51 pm
by drkananga
Same issue as w00tl00ps
Ubuntu 1804, when change to modect there are alarms in live watch and it works.
change back to mocord, no alarm
2020-08-10 01:23:33.911015 zma_m4[13845].INF-zm_monitor.cpp/1303 [Bullet: 400 - Analysing at 11.11 fps]
2020-08-10 01:23:24.044850 zma_m4[13845].INF-zm_monitor.cpp/1303 [Bullet: 300 - Analysing at 9.09 fps]
2020-08-10 01:23:13.690208 zma_m4[13845].INF-zm_monitor.cpp/1303 [Bullet: 200 - Analysing at 10.00 fps]
2020-08-10 01:23:03.688982 zma_m4[13845].INF-zm_monitor.cpp/1303 [Bullet: 100 - Analysing at 8.33 fps]
2020-08-10 01:22:55.042767 zma_m4[13845].INF-zm_monitor.cpp/1525 [Bullet: 001 - Opening new event 46710, section start]
2020-08-10 01:22:54.948125 zma_m4[13845].INF-zma.cpp/136 [In mode 5/1, warming up]
2020-08-10 01:22:50.694376 zma_m4[13843].ERR-zm_monitor.cpp/580 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-08-10 01:22:49.551621 zma_m4[13831].ERR-zm_monitor.cpp/499 [Shared data not initialised by capture daemon for monitor Bullet]
2020-08-10 01:22:41.833476 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 800 - Analysing at 10.00 fps]
2020-08-10 01:22:31.835520 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 700 - Analysing at 10.00 fps]
2020-08-10 01:22:21.785762 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 600 - Analysing at 10.00 fps]
2020-08-10 01:22:11.810197 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 500 - Analysing at 10.00 fps]
2020-08-10 01:22:01.770381 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 400 - Analysing at 10.00 fps]
2020-08-10 01:21:51.783194 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 300 - Analysing at 10.00 fps]
2020-08-10 01:21:41.779673 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 200 - Analysing at 10.00 fps]
2020-08-10 01:21:31.730145 zma_m4[13800].INF-zm_monitor.cpp/1303 [Bullet: 100 - Analysing at 5.00 fps]
2020-08-10 01:21:23.287703 zma_m4[13800].INF-zma.cpp/136 [In mode 3/1, warming up]
2020-08-10 01:21:05.937495 zma_m4[13798].ERR-zm_monitor.cpp/580 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-08-10 01:20:59.665702 zma_m4[13796].INF-zma.cpp/136 [In mode 3/1, warming up]
2020-08-10 01:20:06.008530 zma_m4[13778].INF-zm_monitor.cpp/1303 [Bullet: 300 - Analysing at 10.00 fps]
2020-08-10 01:19:56.018426 zma_m4[13778].INF-zm_monitor.cpp/1303 [Bullet: 200 - Analysing at 9.09 fps]
2020-08-10 01:19:45.971072 zma_m4[13778].INF-zm_monitor.cpp/1303 [Bullet: 100 - Analysing at 11.11 fps]
2020-08-10 01:19:38.040937 zma_m4[13778].INF-zma.cpp/136 [In mode 3/1, warming up]
2020-08-10 01:19:34.643202 zma_m4[13772].ERR-zm_monitor.cpp/499 [Shared data not initialised by capture daemon for monitor Bullet]
2020-08-10 01:19:33.978685 zma_m4[13720].INF-zm_event.cpp/593 [Updating frames delta by -0.24 sec to match video file]
2020-08-10 01:19:33.903943 zma_m4[13720].INF-zm_monitor.cpp/692 [Bullet: image_count:2722 - Closing event 46707, shutting down]
2020-08-10 01:19:31.740048 zma_m4[13720].INF-zm_monitor.cpp/1303 [Bullet: 2700 - Analysing at 10.00 fps]
2020-08-10 01:19:21.743673 zma_m4[13720].INF-zm_monitor.cpp/1303 [Bullet: 2600 - Analysing at 10.00 fps]
2020-08-10 01:19:11.728719 zma_m4[13720].INF-zm_monitor.cpp/1303 [Bullet: 2500 - Analysing at 10.00 fps]
2020-08-10 01:23:41.509876 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:500 - Capturing at 10.00 fps, capturing bandwidth 228264bytes/sec]
2020-08-10 01:23:31.489113 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:400 - Capturing at 12.50 fps, capturing bandwidth 283928bytes/sec]
2020-08-10 01:23:23.333653 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:300 - Capturing at 8.33 fps, capturing bandwidth 191234bytes/sec]
2020-08-10 01:23:11.466931 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:200 - Capturing at 10.00 fps, capturing bandwidth 228663bytes/sec]
2020-08-10 01:23:01.448478 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:100 - Capturing at 14.29 fps, capturing bandwidth 309685bytes/sec]
2020-08-10 01:22:55.210537 zmc_m4[13844].INF-zm_ffmpeg_camera.cpp/883 [Event video offset is -0.129 sec (<0 means video starts early)]
2020-08-10 01:22:55.185561 zmc_m4[13844].INF-zm_videostore.cpp/440 [some options not used, turn on debugging for a list.]
2020-08-10 01:22:55.106190 zmc_m4[13844].INF-zm_videostore.cpp/63 [Opening video storage stream /mnt/sdb/sdb_zm/events/4/2020-08-10/46710/46710-video.mp4 format: mp4]
2020-08-10 01:22:54.248544 zmc_m4[13844].INF-zm_monitor.cpp/2534 [Bullet: images:1 - Capturing at 0.33 fps, capturing bandwidth 35111bytes/sec]
2020-08-10 01:22:51.023613 zmc_m4[13844].INF-zmc.cpp/223 [Starting Capture version 1.34.18]
2020-08-10 01:22:50.748056 zmc_m4[13844].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-08-10 01:22:50.024802 zmc_m4[13827].ERR-zm_ffmpeg_camera.cpp/630 [swscale does not support the codec format for input: (null)]
2020-08-10 01:22:49.662761 zmc_m4[13827].INF-zmc.cpp/223 [Starting Capture version 1.34.18]
2020-08-10 01:22:49.384253 zmc_m4[13827].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-08-10 01:22:40.061753 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:800 - Capturing at 9.09 fps, capturing bandwidth 206101bytes/sec]
2020-08-10 01:22:29.888636 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:700 - Capturing at 10.00 fps, capturing bandwidth 228586bytes/sec]
2020-08-10 01:22:19.876407 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:600 - Capturing at 10.00 fps, capturing bandwidth 234757bytes/sec]
2020-08-10 01:22:09.855200 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:500 - Capturing at 11.11 fps, capturing bandwidth 253591bytes/sec]
2020-08-10 01:22:00.032729 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:400 - Capturing at 9.09 fps, capturing bandwidth 207153bytes/sec]
2020-08-10 01:21:49.816756 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:300 - Capturing at 10.00 fps, capturing bandwidth 228512bytes/sec]
2020-08-10 01:21:39.811617 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:200 - Capturing at 10.00 fps, capturing bandwidth 228308bytes/sec]
2020-08-10 01:21:29.801311 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:100 - Capturing at 14.29 fps, capturing bandwidth 309600bytes/sec]
2020-08-10 01:21:22.612082 zmc_m4[13799].INF-zm_monitor.cpp/2534 [Bullet: images:1 - Capturing at 0.06 fps, capturing bandwidth 7791bytes/sec]
2020-08-10 01:21:08.763713 zmc_m4[13799].ERR-zm_ffmpeg_camera.cpp/394 [Unable to open input rtsp://xxxxxxx@192.168.1.98:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif due to: No route to host]
2020-08-10 01:21:06.409980 zmc_m4[13799].INF-zmc.cpp/223 [Starting Capture version 1.34.18]
2020-08-10 01:21:06.154074 zmc_m4[13799].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-08-10 01:20:59.531116 zmc_m4[13768].INF-zmc.cpp/318 [Failed to capture image from monitor 4 Bullet (1/1)]
2020-08-10 01:20:59.504190 zmc_m4[13768].INF-zm_monitor.cpp/2448 [Return from Capture (-1), signal loss]
2020-08-10 01:20:59.479101 zmc_m4[13768].INF-zm_ffmpeg_camera.cpp/759 [Unable to read packet from stream 0: error -541478725 "End of file".]
2020-08-10 01:20:59.453997 zmc_m4[13768].WAR-zm_ffmpeg_camera.cpp/976 [Unable to receive frame 313: code -1094995529 Invalid data found when processing input. error count is 0]
2020-08-10 01:20:59.429023 zmc_m4[13768].ERR-zm_ffmpeg.cpp/548 [Unable to send packet Invalid data found when processing input, continuing]
2020-08-10 01:20:05.188199 zmc_m4[13768].INF-zm_monitor.cpp/2534 [Bullet: images:300 - Capturing at 10.00 fps, capturing bandwidth 228158bytes/sec]
2020-08-10 01:19:55.169262 zmc_m4[13768].INF-zm_monitor.cpp/2534 [Bullet: images:200 - Capturing at 10.00 fps, capturing bandwidth 228433bytes/sec]
2020-08-10 01:19:45.160826 zmc_m4[13768].INF-zm_monitor.cpp/2534 [Bullet: images:100 - Capturing at 14.29 fps, capturing bandwidth 311294bytes/sec]
2020-08-10 01:19:38.000490 zmc_m4[13768].INF-zm_monitor.cpp/2534 [Bullet: images:1 - Capturing at 0.25 fps, capturing bandwidth 26617bytes/sec]
2020-08-10 01:19:34.776362 zmc_m4[13768].INF-zmc.cpp/223 [Starting Capture version 1.34.18]
2020-08-10 01:19:34.465460 zmc_m4[13768].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-08-10 01:19:29.330789 zmc_m4[13716].INF-zm_monitor.cpp/2534 [Bullet: images:2700 - Capturing at 10.00 fps, capturing bandwidth 228514bytes/sec]
2020-08-10 01:19:19.316436 zmc_m4[13716].INF-zm_monitor.cpp/2534 [Bullet: images:2600 - Capturing at 10.00 fps, capturing bandwidth 228229bytes/sec]
2020-08-10 01:19:09.308186 zmc_m4[13716].INF-zm_monitor.cpp/2534 [Bullet: images:2500 - Capturing at 10.00 fps, capturing bandwidth 228201bytes/sec]
Posted: Mon Aug 10, 2020 5:28 pm
by systemd
I also have this issue with 1.34.18 as w00tl00ps and drkananga described, my cameras on Modect is working, but Mocord does not register any alerted frames.
Ubuntu 18.04.5 LTS
zoneminder 1.34.18-bionic1
zoneminder-doc 1.34.18-bionic1
Posted: Mon Aug 10, 2020 10:18 pm
by tcg
I am seeing the same issue. After upgrading one of my machines to 1.34.18, all MOCORD event detection stopped. I have a few other ZM installs that are still at 1.34.16 and they are still working as expected. As mentioned above, I can switch to MODECT and it works like it is supposed to.
This particular ZM setup has 3 servers with 70 monitors. The CPU usage is down across the board on all of them.
Posted: Tue Aug 11, 2020 12:55 am
by drkananga
Is it possible to downgrade to 1.34.16?
If so, how?
Posted: Tue Aug 11, 2020 11:32 am
by bkjaya1952
drkananga wrote: ↑Tue Aug 11, 2020 12:55 am
If so, how?
Download the Zoneminder 1.34.16 deb file that suit to your Linux system from the following Isaac's web site and install .
Then On the terminal and run
zmupdate.pl
to downgrade the data base.
https://launchpad.net/~iconnor/+archive ... tate=built
Posted: Tue Aug 11, 2020 12:23 pm
by iconnor
I'll try to investigate and get a fix out today.
In the meantime yeah just install the deb for 1.34.16.
Posted: Tue Aug 11, 2020 1:25 pm
by tcg
I'm running in dlandon/zoneminder Docker containers. His Dockerfile picks up whatever you have on your 1.34 PPA. I don't see an easy way to downgrade that so I'll just hang on for an update.
Thanks for your work on this iconnor.
Posted: Tue Aug 11, 2020 2:50 pm
by iconnor
So far unable to reproduce this.
w00tl00ps appears to actually have a segfault occurring. Is anyone else having a segfault?
What do people have for their pre-alarm frames and other buffer settings?
Posted: Tue Aug 11, 2020 3:01 pm
by iconnor
Okay I think I found it.
Posted: Tue Aug 11, 2020 3:52 pm
by bkjaya1952
tcg wrote: ↑Tue Aug 11, 2020 1:25 pm
Download the Zoneminder 1.34.16 to the host computer
Start the container
sudo docker start Zoneminder
Copy the zoneminder deb file from the host to the container .
sudo docker cp zoneminder.deb Zoneminder:/
Go in to the container and install the copied deb
sudo docker exec -t -i Zoneminder /bin/bash
dpkg -i zoneminder .deb
zmupdate.pl
exit
sudo docker restart Zoneminder
Note:- replace zoneminder.deb with the actual name of the zoneminder 1.34.16 file
