Shared Memory Config TIPS
Posted: Fri Jul 06, 2007 4:55 am
I have been fighting with a random hang memory problem after an upgrade from a FC4 to FC6 install. It ended up being my shared memory settings. See below for details, but first my system info:
The system is also running MythTV (SVN version with the MythTV Zoneminder plugin - Nice Piece Of work!). With both ZM and MythTV I have some significant (but not huge) video capture & streaming requirements. When I was running ZM on FC4 with double the buffer sizes and FPS it was happy. Other reasons forced my to update to FC6. (Video capture drivers for the capture card I am using for MythTV)
Random system hangs and slowdowns were occurring between 1-3 days.
/var/log/messages was telling me that I should decreases the buffers or slow down capture.... Which I did. To levels less than what I was running on FC4 and I was still hanging, so I knew it was something else. I followed the FAQ info on setting the Shared memory to no avail.
REMEMBER to restart httpd and ZM after changes to the shared memory settings!
I had tried many, many things but was stumped. I even grabbed and extra 2GB memory to help out, with no luck, UNTIL...
I came across and article about shared memory setting when running DB2. ( http://publib.boulder.ibm.com/infocente ... 008238.htm ). It made some statement that conflicted with those in the FAQ so I gave them a try. The essential difference was that the kernel.shmall setting is NOT in a direct memory setting in KB but in pages of memory. it is Max Pages of memory
For example: If you want to allocate a maximum memory setting to 8GB you have to convert it to the number of pages (or segments).
with a page size of 4096NOT 8388608000 as would be suggested in the FAQ.
shmmax is the max amount to allocate in one request
this is is an actual memory size (as opposed to pages) set to 4GB
Can anyone else confirm this is correct??? I don't want to make an update to the Wiki FAQ or a A Shared Memory page on the Wiki until I have confirmed this. I know these values are huge and will adjust them down after some burn -in time.
Here is my /etc/sysctl.conf
Here is my interprocess communication status
NOTE that even though I set the kernel.shmall = 2048000 it is reported (as described and expected) as 8GB
My system has not hung since. So far a full 7 days and not a hint of trouble.
- FC6 with a custom kernel build 2.6.21.5 build for my AMD X2
3GB (originally 1GB) RAM
over 700GB disks with JFS filesystem and a logical volume manager
ZM 1.22.3
3 Bosch cameras via a ProVideo PV150 - 4 Bt878 port capture card
Camera settings - 384x240 with FPS=8, alarm FPS=20, buffer =40 frames & 10,20,20 warm pre and post
Hauppage PVR-350 (mpeg2 vid in/out capture card)
kernel.shmall=8000x1024x1024/4096
kernel.shmall=2048000
kernel.shmmax = 4194304000
# Kernel sysctl configuration file for Red Hat Linux
# For binary values, 0 is disabled, 1 is enabled. See sysctl(8) and
# sysctl.conf(5) for more details.
# Controls IP packet forwarding
net.ipv4.ip_forward = 0
# Controls source route verification
net.ipv4.conf.default.rp_filter = 1
# Do not accept source routing
net.ipv4.conf.default.accept_source_route = 0
# Controls the System Request debugging functionality of the kernel
kernel.sysrq = 0
# Controls whether core dumps will append the PID to the core filename.
# Useful for debugging multi-threaded applications.
kernel.core_uses_pid = 1
# Controls the use of TCP syncookies
net.ipv4.tcp_syncookies = 1
# The default shared memory limit for SHMMAX is 32 MB and for SHMALL is 2 MB, but it can be changed.
# For example, to allow 128 MB:
# SEE http://publib.boulder.ibm.com/infocenter/db2luw/v9/index.jsp?topic=/com.ibm.db2.udb.uprun.doc/doc/t0008238.htm
# this is the max pages set to 8GB divided by the page size of 4096 = 8000x1024x1024/4096
# this is is an actual mem size (as opposed to pages) set to 4GB
# reload these with a sysctl -p
# list the mem settings eith a ipcs -l
[root@dvr tmp]# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 4096000
max total shared memory (kbytes) = 8192000
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 16
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
