Bleucherry PV-149: What driver to use.
paulandgabriela
Post by paulandgabriela » Fri Jan 12, 2007 4:50 pm
Hi out there,
I have bought a bluecherry PV149 and my camera's came in today. So I wanted to install it but the life-cd supplied by them is not working.
Now I won't want to use the life cd anyhow as I want to add the camera and frame capture card PV149 in my FC6 system.
But I do not know howto continue?
Does anyone has a hint for me?
Thanks,
Paul
Sika
Post by Sika » Fri Jan 12, 2007 9:25 pm
Just follow the "How to" for FC6 from the wiki site. You will need to add to the modprobe.conf file:
modprobe bttv gbuffers=16 card=98,98,98,98
That should get you up and running.
Sika
paulandgabriela
Post by paulandgabriela » Fri Jan 12, 2007 11:00 pm
Hi Sika,
Is this what you mean:
http://ubuntuguide.org/wiki/Fedora_fc5
Thanks,
Paul
paulandgabriela
Post by paulandgabriela » Fri Jan 12, 2007 11:38 pm
I changed /etc/modprobe.conf (see last line) to:
alias eth0 e100
alias snd-card-0 snd-intel8x0
options snd-card-0 index=0
options snd-intel8x0 index=0
remove snd-intel8x0 { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-intel8x0
# options pwc index=1
remove pwc { /usr/sbin/alsactl store 1 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove pwc
However no result.
Cheers,
Paul
eracc
Post by eracc » Sat Jan 13, 2007 12:01 am
paulandgabriela wrote:Hi Sika,
Thanks,
Paul
No, he means the ZoneMinder Wiki. See this:
http://www.zoneminder.com/wiki/index.ph ... ep-by-Step
paulandgabriela
Post by paulandgabriela » Sat Jan 13, 2007 7:04 pm
But overthere is nothing mentioned about the PV-149 or something similar??
Cheers,
Paul
paulandgabriela
Post by paulandgabriela » Sat Jan 13, 2007 7:15 pm
Found some more, but this does not ring a bell for me:
[root@localhost ~]# dmesg |grep -2 bttv
audit(1168711540.490:2): selinux=0 auid=4294967295
Linux video capture interface: v2.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:03:08.0[A] -> GSI 21 (level, low) -> IRQ 169
bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 169, latency: 32, mmio: 0xef000000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt 0000:03:09.0[A] -> GSI 22 (level, low) -> IRQ 193
bttv1: Bt878 (rev 17) at 0000:03:09.0, irq: 193, latency: 32, mmio: 0xee000000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt 0000:03:0a.0[A] -> GSI 23 (level, low) -> IRQ 177
bttv2: Bt878 (rev 17) at 0000:03:0a.0, irq: 177, latency: 32, mmio: 0xed000000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .<6>hdc: ATAPI 40X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
bt878: Unknown symbol bttv_read_gpio
bt878: Unknown symbol bttv_write_gpio
bt878: Unknown symbol bttv_gpio_enable
.<4>bt878: Unknown symbol bttv_read_gpio
ok
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt 0000:03:0b.0[A] -> GSI 20 (level, low) -> IRQ 201
bttv3: Bt878 (rev 17) at 0000:03:0b.0, irq: 201, latency: 32, mmio: 0xec000000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .<6>hdd: ATAPI 32X CD-ROM CD-R/RW drive, 4096kB Cache, DMA
. ok
bt878: AUDIO driver version 0.0.0 loaded
Cheers,
Paul
paulandgabriela
Post by paulandgabriela » Sat Jan 13, 2007 7:23 pm
This is the result of XAWTV:
[root@localhost ffmpeg]# xawtv
This is xawtv-3.95, running on Linux/i686 (2.6.18-1.2849.fc6)
WARNING: v4l-conf is compiled without DGA support.
WARNING: couldn't find framebuffer base address, try manual
configuration ("v4l-conf -a <addr>")
ioctl: VIDIOC_OVERLAY(int=1): Invalid argument
Thanks,
Paul
paulandgabriela
Post by paulandgabriela » Sat Jan 13, 2007 9:43 pm
Found a new command via http://tldp.visiolab.de/HOWTO/html_single/BTTV/
[root@localhost dev]# xawtv -hwscan
looking for available devices
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (ProVideo PV150)
flags: overlay capture
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
But still getting:
[root@localhost dev]# xawtv -device /dev/video0
curtishall
Post by curtishall » Sun Jan 14, 2007 12:52 am
The PV-149 doesn't require any modprobe settings or anything similar by default. The card is automagically found by the latest kernels. As I mentioned in the ticket request you opened you might have a defective card. If that's the case you can return it for a exchange
Curtis Hall
Bluecherry
www.bluecherry.net
paulandgabriela wrote:Found a new command via http://tldp.visiolab.de/HOWTO/html_single/BTTV/
type : v4l2
type : v4l2
type : v4l2
type : v4l2
But still getting:
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
paulandgabriela
One step further, but not there yet.
Post by paulandgabriela » Mon Jan 15, 2007 7:31 pm
No it is not the HW. I have XAWTV working now. The solution was found under:
http://www.mail-archive.com/mjpeg-users ... 07044.html
It seems to be a FC6 issue. You have to find the framebuffer address under /dev/log/Xorg.0.log. Do a search for framebuffer and you will find the address.
The address is 0xF000 0000. One can set it n XAWTV with the command:
v4l-conf -a 0xF0000000.
Now the question is how to do this adaptation for ZoneMinder?
Cheers,
Paul
mrd
Post by mrd » Fri Jan 19, 2007 6:10 pm
I'm having a problem with a PV-149 on the 1.21.3 LiveCD version of ZM. It worked fine with one camera attached until I hooked up a second to the cable/port on the capture card labeled #2 and now when I try to switch the source from one camera to the other for testing, any image it shows does a very fast switching back and forth from one source to the other. I've tried multiple source settings:
Device Numbers 0-4
Device Channels 0-4
No combinations seem to help and one thing to note is that TvTime seems to show each camera fine.
Thanks,
MRD
paulandgabriela
Switched to Suse.
Post by paulandgabriela » Sat Jan 20, 2007 6:04 pm
The liveCD coming with the card is not working at all.
The drive keeps spinning in an endless loop.
I have abandoned FC6.
I switched to Suse 10.2.
It is certainly a lot more work to get it configured. Even harder to do and twice as long as for FC6. I have XAWTV working without a problem and I think I am very close to getting Zoneminder up and running but not sure though.
Cheers,
Paul
paulandgabriela
It works under Suse 10.2
Post by paulandgabriela » Sat Jan 20, 2007 7:41 pm
Guys,
I got it working under Suse 10.2, only thing is that if I am logging in remotely my main window starts up. But then if I click anything I get 403 errors
Access forbidden, for unknown reason.
Still something to digg into I guess.
Cheers,
Paul
mrd
Post by mrd » Wed Jan 24, 2007 4:35 pm
I've switched to the LiveCD that BlueCherry makes and it's working for me...
Just an update...
It must be a driver issue or possibly a kernel issue since the only LiveCD I was able to get working before had an older kernel on it.
MRD
Users browsing this forum: No registered users and 0 guests
