Synch problem with second camera
Posted: Tue Nov 28, 2006 10:57 pm
I got a 4 port X Guard capture card http://www.grandtec.com/xguard.htm
I have 2 cams currently connected http://www.ptast.com/media/
One cam (Front) is captured OK but the second one (Backyard) is out of synch.
Here's how it should look (in the dark)
And here how it is now
How do I resolve this issue?
You can view my setting at http://213.250.83.82/zm/
username: guest
password: zmguest
11/29/06 00:16:19.128505 zmc_dvideo[4042].DB1-zm_monitor.cpp/329 [Monitor Backyard-IR has function 2]
11/29/06 00:16:19.128570 zmc_dvideo[4042].DB1-zm_monitor.cpp/330 [Monitor Backyard-IR LBF = '%y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
11/29/06 00:16:19.128614 zmc_dvideo[4042].DB1-zm_monitor.cpp/331 [Monitor Backyard-IR IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 1, FM = 0]
11/29/06 00:16:19.129599 zmc_dvideo[4042].DB1-zm_zone.cpp/849 [Got 0 zones for monitor Backyard-IR]
11/29/06 00:16:19.129708 zmc_dvideo[4042].DB1-zm_monitor.cpp/1619 [Loaded monitor 1(Backyard-IR), 0 zones]
11/29/06 00:16:19.129751 zmc_dvideo[4042].INF-zmc.cpp/183 [Starting Capture]
11/29/06 00:16:57.151480 zmc_dvideo[4042].INF-zm_signal.cpp/54 [Got signal (Terminated), exiting]
11/29/06 00:16:57.151900 zmc_dvideo[4042].ERR-zm_local_camera.cpp/615 [Sync failure for frame 5 buffer 5(1): Interrupted system call]
username: guest
password: zmguest
