ZoneMinder 1.22.2 on SuSE 10.1
BarryH
Post by BarryH »
Dgsconseil was kind enough to write a step-by-step newbie kit to install ZoneMinder under SUSE 10.0 OSS. I copied it and modified it to for SuSE 10.1 with a GUI and the KDE.
This is only a short How-To on how I installed SuSE and ZoneMinder software on SUSE 10.1 OSS, it is not intended to be a reference because I do not specify any of the security rules or optimizations needed for a production server. I just specify the main steps to get Zone Minder Running.
By the way, this is not the smallest installation possible. It’s just what I used and it worked. It seemed that if I skipped any of the additional packages, I’d run into trouble. Although, you can probably do without the Open Office.
Fresh install Suse 10.1 OSS (CD install)
Base installation with KDE Desktop and additional packages
Additional Software Packages chosen during install:
- Graphical Base system
- KDE Desktop Environment
- All of KDE
- Help and Supports Docs
- Office applications
- Multimedia
- Simple Web Server with Apache2
- LDAP Server and Tools
- Network and Server
- C/C++ Complier and Tools
- Kernel Development
- KDE Development
- TCL/TK development system
- Java
- Experienced user
- LaTex, SGML and XML
If using the firewall, add HTTP Server to the Allowed Services list, if you want to access ZoneMinder with a web browser.
Once the Installation is finished, open the YAST control center. (Under System)
If you have an internet connection: In YAST, add packman as an http installation source (used to install ffmpeg)
  Type : HTTP
  Server : packman.unixheads.com
  Path : suse/10.1
Go into YAST Software Management
Verify that these packages are installed
Install any that are missing (Enter each name in Search box)
  apache2
  apache2-worker
  apache2-mod_perl
  apache2-mod_php5
  apache2-mod-apparmor
  php5
  mysql
  mysql-devel
  gcc
  gcc-c++
  libmpeg2
  libmpeg2-devel
  ffmpeg
  libffmpeg0
  libffmpeg0-devel
  libjpeg
  libjpeg-devel
  pcre-devel
  xawtv
  openssl-devel
Updating perl CPANand installing perl packages
I've done all off the perl related installation under user root because of problems with cpan packages installation. It seems like a slow process, have patience.
(From a terminal window)
 perl -MCPAN -e shell
 install Bundle::CPAN
 reload CPAN
 install Archive::Tar (seems to be optional => depend on the way you install yourdistro)
 install Archive::Zip (seems to be optional => depend on the way you install yourdistro)
 install MIME::Lite
 install MIME::Tools
 install DateTime
 install Date::Manip updated 2006-03-04 thanx to mickecarlsson
 install Bundle::libnet
 install Device::SerialPort
 install Astro::SunTime Updated 2006 03 24 correct spelling error on SunTime (thanx to mickecarlsson)
 install X10
Configure servers to be started at boot time
 (In a terminal window (command shell))
 su - cd /etc/rc.d/rc5.d
 ln -s ../apache2 S98apache2
 ln -s ../apache2 K01apache2
 ln -s ../mysql S98mysql
 ln -s ../mysql K01mysql
Start servers manually
 sudo /etc/rc.d/apache2 start
 sudo /etc/rc.d/mysql start
Downloading and installing latest Zoneminder release (v1.22.2) :
Download and save ZoneMinder tarball from:
http://www2.zoneminder.com/downloads/Zo ... 2.2.tar.gz
Extract tarball
In a Terminal window, inside directory that ZoneMinder download was saved to
 tar zxvf ZoneMinder-1.22.2.tar.gz
 cd ZoneMinder-1.22.2
Download and apply the v1.22.2 patch for ffmpeg from Wiki:
http://www.zoneminder.com/wiki/index.php/1.22.2_Patches
To apply the patch you should do the following :-
 ·Download the patch and move a copy to your ZoneMinder build directory
 · Open a command shell (terminal window)
 · Change directory to your ZoneMinder build directory
 · Apply the patch by typing
 patch -p0 < zm-1.22.2-ffmpeg.patch
 · Check that the patch is applied correctly and you do not get any rejects
 · If necessary rebuild, then reinstall
Now Configuration Time !
(be sure you are in ZoneMinder-1.22.2 directory)
./configure --with-webdir=/srv/www/htdocs --with-cgidir=/srv/www/cgi-bin --with-webgroup=www --with-webuser=wwwrun ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zm ZM_DB_PASS=zm
Make sure you’re in the ZoneMinder-1.22.2 directory and Login to MySQL (PW is blank)
 mysql -h localhost -u root -p
Under MySQL prompt type
 (Entering Each line may echo some additional lines, just ignore them)
 source db/zm_create.sql;
 grant select,insert,update,delete on zm.* to 'zm'@localhost identified by 'zm';
 flush privileges;
 quit
Now compile and install this nice piece of software !
 make
 sudo make install
Configure ZoneMinder to be started at boot time
 su -
 # from zoneminder source directory
 cp scripts/zm /etc/rc.d cd /etc/rc.d
 chmod +x zm
 cd rc5.d
 ln -s ../zm S99zm
 ln -s ../zm K00zm
Logoff and logon as root, or create a new session as root.
Edit /etc/rc.d/zm with your favorite text editor (kwrite ?)
 remove the line related to include functions
 replace all occurences of echo_success by echo success
 replace all occurences of echo_failure by echo failure
 save the changes
Copy the /srv/www/htdocs/zm.php file on top of the /srv/www/htdocs/index.php file.
Rename or delete the /srv/www/htdocs/index.html file
Deal with the Shared Memory problem
(I chose 256,000,000 because my cams are 640x480)
Add the following lines to your /etc/sysctl.conf file:
 # Memory modifications for ZoneMinder
 kernel.shmall = 256000000
 kernel.shmmax = 256000000
Now you can reboot your computer to apply changes
Start all servers if they are not allready started when you boot your computer :
 (From within a Terminal window)
 sudo zmpkg.pl start
Now open your web browser and point to http://localhost/
If that doesn’t work, try http://localhost/zm.php
Create your monitor and start playing !
Here are some options I use when configuring a monitor for my Axis IP camera at 640x480, color.:
Under the General Tab
Source Type = Remote
Function = Modetect
Enabled = Checked
Linked Monitors = (leave it blank)
Maximum FPS = 4.0
Alarm Maximum FPS = 8.0
Under the Source Tab
Remote host name = IP of camera (i.e. 192.168.3.2)
Remote Host Port = 80
Remote Host Path = /axis-cgi/jpg/image.cgi?resolution=640x480
Remote Image Colours = 24 bit colour
Capture Width = 640
Capture Height = 480
If you want to utilize mpeg instead of jpeg, use this for the host path:
Remote Host Path = /axis-cgi/mjpg/video.cgi?
Additional Information:
ZoneMinder Logs are in /tmp
zmaudit.log
zmupdate.log
zmwatch.log => take attention to this one because the shared memory problem is reported here
zmpkg.log
zmdc.log
Apache2 Logs are in /var/logs/apache2
zoneminder
Site Admin
Post by zoneminder »
Thanks for posting this. It would be really neat if you wouldn't mind putting it into the Wiki as well :D
Phil
