###Shutdown Zoneminder
/etc/rc.d/init.d/zm stop
###Download New Version
wget http://www2.zoneminder.com/downloads/Zo ... 2.2.tar.gz
###Untar and Unzip New Version Source
tar -xzvf ZoneMinder-1.22.2.tar.gz
###Change perms
chmod -R 755 ZoneMinder-1.22.2
###Change Directories
cd ZoneMinder-1.22.2
###Configure your build
./configure --with-ffmpeg --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin --with-webgroup=apache --with-webuser=apache --with-mysql=/usr --with-libarch=lib64 --disable-crashtrace
###Compile your build
make
###Install your build
make install
###Edit the new zm.conf and set your database name, db username, and db password
vi /usr/local/etc/zm.conf
you will need to enter your details for the following variables:
# ZoneMinder database name
ZM_DB_NAME=zm
# ZoneMinder database user
ZM_DB_USER=zmuser
# ZoneMinder database password
ZM_DB_PASS=zmpass
###Change directories
cd scripts
###Update your database
./zmupdate.pl -version=1.22.1 -user=zmuser -pass=zmpass
###Copy new startup script
cp zm /etc/rc.d/init.d/
###Set perms on new startup script
chmod 755 /etc/rc.d/init.d/zm
###Start Zoneminder
/etc/rc.d/init.d/zm start
###1.22.2 will complain about:
line 128: /usr/local/sbin/motd.sh: No such file or directory
You can either just ignore this or edit your zm startup script to not call motd.sh...no biggy really.
Thanks to Phil for making this project possible!!
