I do some volunteer sysadmin work in our area. In the past we have used GNU motion for surveillance. (more efficient than ZM but less features) We are converting over to Zoneminder. Phil's zoneminder project is one of my new favorite past-times.
Before I begin I would like to note that the 6620G from D-Link is the exact same camera as the following other units:
Hawking Technologies HNC820G
Vivotek PZ6114/PZ6124
It looks like Vivotek actually manufactures the hardware itself. D-Link and Hawking Tech just use their own firmware releases.
Why did we choose the D-Link 6620 over some of the other netcams out there? Well, we are part of a medium sized distributed network that needs outdoor surveillance in a few key locations where wiring is not an option, but there were existing outlets in the ceiling that we could utilize. Normally as a rule of thumb we try to stay away from wireless as it is so insecure and slower that wire speed. After some research...we started this project by ordering up a Toshiba IK-WB11A (Pan-Tilt) unit with it's outdoor enclosure. After messing around for about a half a day...we got the Toshiba to work perfectly with Zoneminder. I will try to provide documentation on that setup below. The Toshiba did everything we wanted minus optical zoom, 802.11g (it is B only). We started talking about actually deploying this unit and went through our normal battery of tests including security checks. Here is where the unit would not work out. I fired up my notebook which has an intel pro wireless 2200 in it running kismet, airsnort, and then aircrack. Even with the Toshiba set to 128bit WEP encryption...we were able to jump into our access point after a couple hours of sniffing for keys and then running aircrack. We decided that WEP was not an option for this project so we scrapped the idea of the Toshiba because it does not support WPA. We then went shopping again for a camera that would do 30FPS, had optical zoom, and would do WPA wireless security, and had a decent looking outdoor enclosure that could withstand our Minnesota winters. The D-Link 6620G, Hawking Tech HNC820G, and the Vivotek PZ6114/PZ6124 were the only cams we found that fit these requirements.
For our final setup we ordered the following:
1 - D-Link DCS-6620G Camera ($785.98 from newegg.com)
1 - D-Link DCS-70 Outdoor Enclosure ($406 from c-source.com)
1 - Linksys WAP54GPE Outdoor POE Access Point ($389.98 from newegg.com)
Total Equipment: $1581.96 (Kinda Spendy...but worth it)
These units were really finiky about talking to each other using WPA-TKIP but we got it. Use the following options in your wireless config:
Will add this later...don't have access to it from home.
I will just jot down a few key notes for your zoneminder configs tonight, but will try to update this with a more detailed howto as time permits.
Zoneminder settings for DCS-6620G:
Source:
Remote Host Name admin:password@192.168.0.10
Remote Host Port 80
Remote Host Path /cgi-bin/video.jpg
Remote Image Colours 24bit
Capture Width 352
Capture Height 240
Orientation Normal
Buffers:
Image Buffer Size 15
Warmup Frames 5
Pre Event Image Buffer 10
Post Event Image Buffer 10
Alarm Frame Count 1
Misc:
Maximum FPS 10.00
FPS Report Interval 1000
Control:
Controllable Checked
Control Type DCS-6620G (you will have to create this)
Control Device blank
Control Address admin:password@192.168.0.10
Auto Stop Timeout blank
Track Motion blank
Track Delay 0
Return Location Home
Return Delay 0
Control Capability - DCS-6620G:
Main:
Name DCS-6620G
Type Remote
Command zmcontrol-6620g.pl (you will need to create this in /usr/local/bin)
Can Wake blank
Can Sleep blank
Can Reset blank
Move:
Can Move checked
Can Move Diagonally not checked
Can Move Mapped checked
Can Move Absolute checked
Can Move Relative checked
Can Move Continuous checked
Pan:
Can Pan checked
Min Pan Range -135
Max Pan Range 135
Min Pan Step 0
Max Pan Step 0
Has Pan Speed blank
Min Pan Speed blank
Max Pan Speed blank
Has Turbo Pan blank
Turbo Pan Speed blank
Tilt:
Can Tilt checked
Min Tilt Range -45
Max Tilt Range 90
Min Tilt Step blank
Max Tilt Step blank
Has Tilt Speed blank
Min Tilt Speed blank
Max Tilt Speed blank
Has Turbo Tilt blank
Zoom:
Can Zoom checked
Can Zoom Absolute blank
Can Zoom Relative blank
Can Zoom Continuous checked
Min Zoom Range 1
Max Zoom Range 10
Min Zoom Step 1
Max Zoom Step 10
Has Zoom Speed blank
Min Zoom Speed 0
Max Zoom Speed 5
Presets:
Has Presets checked
Num Presets 1
Has Home Preset checked
Can Set Presets blank
For the zmcontrol file in /usr/local/bin I just copied the existing zmcontrol-axis-v2.pl to zmcontrol-6620g.pl and edited. Here are some key snippets:
sub moveUp
print( "Move Up\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=up";
sendCmd( $cmd );
sub zoomTele
print( "Zoom Tele\n" );
my $cmd = "cgi-bin/camctrl.cgi?zoom=tele";
sendCmd( $cmd );
sub zoomWide
print( "Zoom Wide\n" );
my $cmd = "cgi-bin/camctrl.cgi?zoom=wide";
sendCmd( $cmd );
To get the zoom working you will also need to go to the bottom of the file and change the zoom elseifs to:
elsif ( $command eq "zoom_con_tele" )
zoomTele();
elsif ( $command eq "zoom_con_wide" )
That should get you doing PTZ on the 6620G. Most of this information was actually dug up from a PDF that we downloaded from Vivotek's site. D-Link will not provide any of this information.
Now some more configs for getting the Toshiba ID-WB11A working:
Source:
Remote Host Name 192.168.0.11
Remote Host Port 80
Remote Host Path /__live.jpg?&&&
Capture Width (pixels) 640
Capture Height (pixels) 480
Orientation Normal
Buffers:
Image Buffer Size (frames) 20
Warmup Frames 5
Alarm Frame Count 1
Misc:
Maximum FPS 10.00
Control:
Controllable checked
Control Type IK-WB11A (you will need to create this)
Control Device
Control Address 192.168.0.11
Track Motion blank
Track Delay blank
Return Location none
Return Delay 0
Control Capability - IK-WB11A
Main:
Name IK-WB11A
Type Remote
Command zmcontrol-toshiba.pl (you will need to create this)
Can Wake blank
Can Sleep blank
Can Reset blank
Move:
Can Move checked
Can Move Diagonally blank
Pan:
Can Pan checked
Min Pan Range -56
Max Pan Range 56
Min Pan Step 1
Max Pan Step 90
Has Pan Speed blank
Min Pan Speed blank
Max Pan Speed blank
Has Turbo Pan blank
Tilt:
Can Tilt checked
Min Tilt Range -49
Max Tilt Range 5
Min Tilt Step blank
Max Tilt Step blank
Turbo Tilt Speed blank
Zoom...we didn't even mess with it cause it is only digital not optical do-able though.
Presets:
Has Presets checked
Num Presets 10
Can Set Presets checked
For the zmcontrol file in /usr/local/bin I just copied the existing zmcontrol-axis-v2.pl to zmcontrol-toshiba.pl and edited. Here are some key snippets:
sub moveUp
my $cmd = "/pantiltapi.cgi?cont_2=4&ok=dummy.htm";
sendCmd( $cmd );
sub moveDown
print( "Move Down\n" );
my $cmd = "/pantiltapi.cgi?cont_2=8&ok=dummy.htm";
sendCmd( $cmd );
sub moveLeft
print( "Move Left\n" );
my $cmd = "/pantiltapi.cgi?cont_2=1&ok=dummy.htm";
sendCmd( $cmd );
sub moveRight
print( "Move Right\n" );
my $cmd = "/pantiltapi.cgi?cont_2=2&ok=dummy.htm";
sendCmd( $cmd );
That should get you going with Pan & Zoom on the IK-WB11A.
HOWTO - D-Link DCS-6620G With PTZ & Toshiba IK-WB11A
- zoneminder
- Site Admin
- Contact:
Thanks for the advice, got a vivotek and a wk-11a working, thought I would post some additional stuff:
with the Toshiba WK11-A
where ""Z3Vlc3q=" is the user name and "&YnIxT2e=" is the pass..
As I work more with the cameras and zoneminder, I will post more
below is the complete output of "zmcontrol-6620g.pl'
hope this helps someone!
Scott
works but if you have password protection then you need to add it after the /_live.jpg?&&& in hash form like so:Remote Host Name 192.168.0.11
Remote Host Port 80
Orientation Normal
/__live.jpg?&&Z3Vlc3Q=&YnIxT2e=
#!/usr/bin/perl -wT
# ZoneMinder Axis HTTP API v2 Control Script, $Date: 2005/10/17 16:30:49 $, $Revision: 1.4 $
# Copyright (C) 2003, 2004, 2005 Philip Coombes
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
# These are the elements you need to edit to suit your installation
use constant ZM_CONFIG => "/etc/zm.conf"; # Path to the ZoneMinder config file, autogenerated do not change (from zmconfig)
use constant ZM_VERSION => "1.21.4"; # ZoneMinder version number, autogenerated do not change (from zmconfig)
use constant ZM_PATH_BIN => "/usr/lib/zm/bin"; # Path to the ZoneMinder executables, autogenerated do not change (from zmconfig)
# Load the config from the database into the symbol table
BEGIN
no strict 'refs';
open( CONFIG, "<".ZM_CONFIG ) or die( "Can't open config file: $!" );
foreach my $str ( <CONFIG> )
next if ( $str =~ /^\s*$/ );
next if ( $str =~ /^\s*#/ );
my ( $name, $value ) = $str =~ /^\s*([^=\s]+)\s*=\s*([^=\s]+)\s*$/;
$name =~ tr/a-z/A-Z/;
if (( $name eq 'ZM_DB_SERVER' ) ||
( $name eq 'ZM_DB_NAME' ) ||
( $name eq 'ZM_DB_USER' ) ||
( $name eq 'ZM_DB_PASS' ))
*{$name} = sub { $value };
close( CONFIG );
use DBI;
my $dbh = DBI->connect( "DBI:mysql:database=".&ZM_DB_NAME.";host=".&ZM_DB_SERVER, &ZM_DB_USER, &ZM_DB_PASS );
my $sql = "select * from Config";
while( my $config = $sth->fetchrow_hashref() )
*{$config->{Name}} = sub { $config->{Value} };
$sth->finish();
$dbh->disconnect();
use Getopt::Long;
use Device::SerialPort;
use constant LOG_FILE => ZM_PATH_LOGS.'/zmcontrol-6620g.log';
$| = 1;
$ENV{PATH} = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
print( "
Usage: zmcontrol-6620g.pl <various options>
exit( -1 );
my $arg_string = join( " ", @ARGV );
my $address;
my $command;
my ( $speed, $step );
my ( $xcoord, $ycoord );
my ( $width, $height );
my ( $panspeed, $tiltspeed );
my ( $panstep, $tiltstep );
my $preset;
if ( !GetOptions(
'address=s'=>\$address,
'command=s'=>\$command,
'speed=i'=>\$speed,
'step=i'=>\$step,
'xcoord=i'=>\$xcoord,
'ycoord=i'=>\$ycoord,
'width=i'=>\$width,
'height=i'=>\$height,
'panspeed=i'=>\$panspeed,
'tiltspeed=i'=>\$tiltspeed,
'panstep=i'=>\$panstep,
'tiltstep=i'=>\$tiltstep,
'preset=i'=>\$preset
Usage();
if ( !$address )
Usage();
my $log_file = LOG_FILE;
open( LOG, ">>$log_file" ) or die( "Can't open log file: $!" );
open( STDOUT, ">&LOG" ) || die( "Can't dup stdout: $!" );
select( STDOUT ); $| = 1;
open( STDERR, ">&LOG" ) || die( "Can't dup stderr: $!" );
select( STDERR ); $| = 1;
select( LOG ); $| = 1;
print( $arg_string."\n" );
srand( time() );
sub printMsg
my $msg = shift;
my $msg_len = length($msg);
print( $msg );
print( "[".$msg_len."]\n" );
sub sendCmd
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
use LWP::UserAgent;
my $ua = LWP::UserAgent->new;
$ua->agent( "ZoneMinder Control Agent/".ZM_VERSION );
#print( "http://$address/$cmd\n" );
my $req = HTTP::Request->new( GET=>"http://$address/$cmd" );
my $res = $ua->request($req);
if ( $res->is_success )
$result = !undef;
else
print( "Error check failed: '".$res->status_line()."'\n" );
return( $result );
sub cameraReset
print( "Camera Reset\n" );
my $cmd = "nphRestart?PAGE=Restart&Restart=OK";
sendCmd( $cmd );
sub moveUp
sendCmd( $cmd );
sub moveDown
my $cmd = "cgi-bin/camctrl.cgi?move=down";
sendCmd( $cmd );
sub moveLeft
my $cmd = "cgi-bin/camctrl.cgi?move=left";
sendCmd( $cmd );
sub moveRight
my $cmd = "cgi-bin/camctrl.cgi?move=right";
sendCmd( $cmd );
sub moveUpRight
print( "Move Up/Right\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=upright";
sendCmd( $cmd );
sub moveUpLeft
print( "Move Up/Left\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=upleft";
sendCmd( $cmd );
sub moveDownRight
print( "Move Down/Right\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=downright";
sendCmd( $cmd );
sub moveDownLeft
print( "Move Down/Left\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=downleft";
sendCmd( $cmd );
sub moveMap
my ( $xcoord, $ycoord, $width, $height ) = @_;
print( "Move Map to $xcoord,$ycoord\n" );
my $cmd = "cgi-bin/camctrl.cgi?center=$xcoord,$ycoord&imagewidth=$width&imageheight=$height";
sendCmd( $cmd );
sub stepUp
my $step = shift;
print( "Step Up $step\n" );
my $cmd = "cgi-bin/camctrl.cgi?rtilt=$step";
sendCmd( $cmd );
sub stepDown
my $step = shift;
print( "Step Down $step\n" );
my $cmd = "cgi-bin/camctrl.cgi?rtilt=-$step";
sendCmd( $cmd );
sub stepLeft
my $step = shift;
print( "Step Left $step\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=-$step";
sendCmd( $cmd );
sub stepRight
my $step = shift;
print( "Step Right $step\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=$step";
sendCmd( $cmd );
sub stepUpRight
my $panstep = shift;
my $tiltstep = shift;
print( "Step Up/Right $tiltstep/$panstep\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=$panstep&rtilt=$tiltstep";
sendCmd( $cmd );
sub stepUpLeft
print( "Step Up/Left $tiltstep/$panstep\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=-$panstep&rtilt=$tiltstep";
sendCmd( $cmd );
sub stepDownRight
print( "Step Down/Right $tiltstep/$panstep\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=$panstep&rtilt=-$tiltstep";
sendCmd( $cmd );
sub stepDownLeft
print( "Step Down/Left $tiltstep/$panstep\n" );
my $cmd = "cgi-bin/camctrl.cgi?rpan=-$panstep&rtilt=-$tiltstep";
sendCmd( $cmd );
sub zoomTele
my $step = shift;
my $cmd = "cgi-bin/camctrl.cgi?rzoom=$step";
sendCmd( $cmd );
sub zoomWide
my $step = shift;
my $cmd = "cgi-bin/camctrl.cgi?rzoom=-$step";
sendCmd( $cmd );
sub focusNear
my $step = shift;
print( "Focus Near\n" );
my $cmd = "cgi-bin/camctrl.cgi?rfocus=-$step";
sendCmd( $cmd );
sub focusFar
my $step = shift;
print( "Focus Far\n" );
my $cmd = "cgi-bin/camctrl.cgi?rfocus=$step";
sendCmd( $cmd );
sub focusAuto
print( "Focus Auto\n" );
my $cmd = "cgi-bin/camctrl.cgi?autofocus=on";
sendCmd( $cmd );
sub focusMan
print( "Focus Manual\n" );
my $cmd = "cgi-bin/camctrl.cgi?autofocus=off";
sendCmd( $cmd );
sub irisOpen
my $step = shift;
print( "Iris Open\n" );
my $cmd = "cgi-bin/camctrl.cgi?riris=$step";
sendCmd( $cmd );
sub irisClose
my $step = shift;
print( "Iris Close\n" );
my $cmd = "cgi-bin/camctrl.cgi?riris=-$step";
sendCmd( $cmd );
sub irisAuto
print( "Iris Auto\n" );
my $cmd = "cgi-bin/camctrl.cgi?autoiris=on";
sendCmd( $cmd );
sub irisMan
print( "Iris Manual\n" );
my $cmd = "cgi-bin/camctrl.cgi?autoiris=off";
sendCmd( $cmd );
sub presetClear
my $preset = shift || 1;
print( "Clear Preset $preset\n" );
my $cmd = "nphPresetNameCheck?Data=$preset";
sendCmd( $cmd );
sub presetSet
print( "Set Preset $preset\n" );
my $cmd = "cgi-bin/camctrl.cgi?setserverpresetno=$preset";
sendCmd( $cmd );
sub presetGoto
print( "Goto Preset $preset\n" );
my $cmd = "cgi-bin/camctrl.cgi?gotoserverpresetno=$preset";
sendCmd( $cmd );
sub presetHome
print( "Home Preset\n" );
my $cmd = "cgi-bin/camctrl.cgi?move=home";
sendCmd( $cmd );
if ( $command eq "move_con_up" )
moveUp();
elsif ( $command eq "move_con_down" )
moveDown();
elsif ( $command eq "move_con_left" )
moveLeft();
elsif ( $command eq "move_con_right" )
moveRight();
elsif ( $command eq "move_con_upleft" )
moveUpLeft();
elsif ( $command eq "move_con_upright" )
moveUpRight();
elsif ( $command eq "move_con_downleft" )
moveDownLeft();
elsif ( $command eq "move_con_downright" )
moveDownLeft();
elsif ( $command eq "move_map" )
moveMap( $xcoord, $ycoord, $width, $height );
elsif ( $command eq "move_rel_up" )
stepUp( $tiltstep );
elsif ( $command eq "move_rel_down" )
stepDown( $tiltstep );
elsif ( $command eq "move_rel_left" )
stepLeft( $panstep );
elsif ( $command eq "move_rel_right" )
stepRight( $panstep );
elsif ( $command eq "move_rel_upleft" )
stepUpLeft( $panstep, $tiltstep );
elsif ( $command eq "move_rel_upright" )
stepUpRight( $panstep, $tiltstep );
elsif ( $command eq "move_rel_downleft" )
stepDownLeft( $panstep, $tiltstep );
elsif ( $command eq "move_rel_downright" )
stepDownRight( $panstep, $tiltstep );
elsif ( $command eq "zoom_rel_tele" )
zoomTele( $step );
elsif ( $command eq "zoom_rel_wide" )
zoomWide( $step );
elsif ( $command eq "focus_rel_near" )
focusNear( $step );
elsif ( $command eq "focus_rel_far" )
focusFar( $step );
elsif ( $command eq "focus_auto" )
focusAuto();
elsif ( $command eq "focus_man" )
focusMan();
elsif ( $command eq "iris_rel_open" )
irisOpen( $step );
elsif ( $command eq "iris_rel_close" )
irisClose( $step );
elsif ( $command eq "iris_auto" )
irisAuto();
elsif ( $command eq "iris_man" )
irisMan();
elsif ( $command eq "preset_home" )
presetHome();
elsif ( $command eq "preset_set" )
presetSet( $preset );
elsif ( $command eq "preset_goto" )
presetGoto( $preset );
else
print( "Error, can't handle command $command\n" );
Scott
- zoneminder
- Site Admin
- Contact:
See the post here.
I'm just getting ready to convert this, but like I stated before I can make no promises and i will not be able to include any functionality that is not already available in the original script.
There is almost no way to make the DCS-6620 work on the newest Ubuntu 10.04. There are several perl problems and Zoneminder changed the architecture so following the above is not going to work. If you try to use Ubuntu 10.04 just for recording and then make some crontab scripts to make the camera follow a path you are going to run into several problems with Zoneminder randomly turning the picture black and failing the recording.
This script below is the correct script for zoom and moving the DCS-6620 camera on Zoneminder 1.22.3. This is the most up to date version of zone minder on Ubuntu 8.04.4. Just follow the setup in the first post and create this file in /usr/bin. You will need to chmod +x the file as well for it to execute.
#!/usr/bin/perl -wT
# ZoneMinder DCS-6620 Control Script, $Date: 2005/10/17 16:30:49 $, $Revision: 1.4 $
# matching events
use strict;
use constant ZM_CONFIG => "/etc/zm/zm.conf"; # Path to the ZoneMinder config file, autogenerated do not change (from zmconfig)
use constant ZM_PATH_BIN => "/usr/bin"; # Path to the ZoneMinder executables, autogenerated do not change (from zmconfig)
BEGIN
no strict 'refs';
if (( $name eq 'ZM_DB_HOST' ) ||
close( CONFIG );
use DBI;
my $dbh = DBI->connect( "DBI:mysql:database=".&ZM_DB_NAME.";host=".&ZM_DB_HOST, &ZM_DB_USER, &ZM_DB_PASS );
$sth->finish();
$dbh->disconnect();
use Getopt::Long;
$| = 1;
sub Usage
print( "
Usage: zmcontrol-6620g.pl <various>
exit( -1 );
my $address;
my $command;
my $preset;
if ( !GetOptions(
'speed=i'=>\$speed,
'step=i'=>\$step,
'width=i'=>\$width,
Usage();
if ( !$address )
Usage();
srand( time() );
sub printMsg
my $msg = shift;
print( $msg );
sub sendCmd
my $cmd = shift;
my $result = undef;
use LWP::UserAgent;
$result = !undef;
else
return( $result );
sub cameraReset
sendCmd( $cmd );
sub moveUp
sendCmd( $cmd );
sub moveDown
sendCmd( $cmd );
sub moveLeft
sendCmd( $cmd );
sub moveRight
sendCmd( $cmd );
sub moveUpRight
sendCmd( $cmd );
sub moveUpLeft
sendCmd( $cmd );
sub moveDownRight
sendCmd( $cmd );
sub moveDownLeft
sendCmd( $cmd );
sub moveMap
sendCmd( $cmd );
sub stepUp
my $step = shift;
sendCmd( $cmd );
sub stepDown
my $step = shift;
sendCmd( $cmd );
sub stepLeft
my $step = shift;
sendCmd( $cmd );
sub stepRight
my $step = shift;
sendCmd( $cmd );
sub stepUpRight
sendCmd( $cmd );
sub stepUpLeft
sendCmd( $cmd );
sub stepDownRight
sendCmd( $cmd );
sub stepDownLeft
sendCmd( $cmd );
sub zoom_con_tele
sendCmd( $cmd );
sub zoomTele
sendCmd( $cmd );
sub zoom_con_wide
sendCmd( $cmd );
sub zoomWide
sendCmd( $cmd );
sub focusNear
my $step = shift;
sendCmd( $cmd );
sub focusFar
my $step = shift;
sendCmd( $cmd );
sub focusAuto
sendCmd( $cmd );
sub focusMan
sendCmd( $cmd );
sub irisOpen
my $step = shift;
sendCmd( $cmd );
sub irisClose
my $step = shift;
sendCmd( $cmd );
sub irisAuto
sendCmd( $cmd );
sub irisMan
sendCmd( $cmd );
sub presetClear
sendCmd( $cmd );
sub presetSet
sendCmd( $cmd );
sub presetGoto
sendCmd( $cmd );
sub presetHome
sendCmd( $cmd );
moveUp();
moveDown();
moveLeft();
moveRight();
moveUpLeft();
moveUpRight();
moveDownLeft();
moveDownLeft();
zoomTele( $step );
zoomTele( $step );
zoomWide( $step );
zoomWide( $step );
focusNear( $step );
focusFar( $step );
focusAuto();
focusMan();
irisOpen( $step );
irisClose( $step );
irisAuto();
irisMan();
presetHome();
else
