Page 1 of 1
axis 2100 and zm
Posted: Mon Mar 27, 2006 1:54 pm
by occhiostanco
I can't find which web path to specify to get an image out from axis 2100 ip camera.
Camera server/image is available at the target ip location
http://ip/view/index.shtml) but I can't figure which path to
specify in zm:monitor:source:remote_host_path
I tried /axis-cgi/jpg/image.cgi as well as
/axis-cgi/jpg/image.cgi?resolution=320x240
but no image....
Any hint ?
Roberto
Posted: Mon Mar 27, 2006 2:13 pm
by occhiostanco
... my monitor:source settings:
remote host name: 130.186.6.92
remote host port: 80
remote host path: /axis-cgi/jpg/image.cgi?resolution=320x240
(this line works if specified as url in browser)
remote image colours: 24 bit
capture width: 320
capture height:240
orientation: normal
thanks
Roberto
Posted: Mon Mar 27, 2006 10:09 pm
by zoneminder
Do the presets for Axis cams not work for you?
Posted: Tue Mar 28, 2006 7:02 am
by Flash_
Don't know the 2100, but if it has mjpeg support that's preferable;
/axis-cgi/mjpg/video.cgi?resolution=640x480
add &compression=50 for smaller files and &color=0 for b&w.
I don't know if the 2100 has the inbuilt url-builder tool, but that's very useful (even if it forgets to include non-standard ports).
axis presets ...
Posted: Tue Mar 28, 2006 7:48 am
by occhiostanco
Sorry Phil,
I'm very new to zm...
Now I saw the "preset" link in monitor configuration, but, maybe
I have a basic problem in the main zm console.
From the documentation/screenshot I read that I should click
in the monitor "name" link to view the image.
Also, i could click in the "montage" link to see all active monitors.
BUT neither monitor "name", nor "montage" are links for me and I can't
click them.
Also, the Delete button does not delete the marked monitor...
I feel I may have a permission problem in the console ?
What should I check ?
Posted: Tue Mar 28, 2006 1:42 pm
by zoneminder
If the monitor 'name' is not a link then it implies that your monitor is not running. Did you start ZM? What colour are the monitor function and device columns?
There is a deleting monitor bug in 1.22.0. There is a patch which you should be able to find if you search the forums but if you can't find it I'll post it here. Either way it is fixed in 1.22.1 which will be out in the next few days.
axis preset...
Posted: Tue Mar 28, 2006 2:39 pm
by occhiostanco
oops, zm was not running.
Now the zm init script is ok, zm is running and I can click
monitor "names", "cycle" and "montage".
But still no images (I see the usual broken image item in the browser).
However if I hit the "zones" button in the monitor "name" window
I get an image and can define zones against it
Ideas ?
Roberto
Posted: Thu Mar 30, 2006 10:28 pm
by zoneminder
Can you post the source of a non-working page? Is your httpd cgi config set up correctly? E.g. pointing to the right directory with the right permissions?
