Nice! The opening of the default config file works great now. It's a one-click-to-view solution!
I'd still love to see a check mark next to the active cam when the menu softkey is pressed.
Also would love to see the error on exit go away.
I'd say those two would be more useful than the quad view, after using this app for a few days now.
Also, something odd started happening yesterday (before I downloaded the latest release) - the app started showing the top "start" bar, which was cutting off the top of my images. By "start" bar I mean the part of WM5 that has the start button, the current app name, and the various icons about signal strength, battery level, etc. Normally that disappears when I run zm4ppc, but yesterday it started not disappearing. Then I did a soft reset today and things were back to normal. Probably a memory issue, but I just thought I'd mention it.
