Creating videos with ffmpeg when FPS is below 25
ekiboy69
Problem temporarily solved with earlier ffmpeg version
Post by ekiboy69 » Mon Oct 03, 2005 10:29 pm
I managed to solve the issue by downgrading to an earlier version of ffmpeg. So ffmpeg is to blame. 0.4.8 works without the -strict parameter. The end result is MPEG2 compliant.
Phil & James: thank you for guiding me to the right direction.
I still do think having a working method of MPEG2 export is essential :-)
I am going to be away for a day or two. I might be able to test the patch as well after I've come back.
Good night,
jameswilson
Post by jameswilson » Tue Oct 04, 2005 12:07 am
i Have done more experiemnts on this and yes i can definetly export mpegs but...
The quality is very poor, very blocky how do i imrove this?
James
ekiboy69
Post by ekiboy69 » Wed Oct 05, 2005 7:04 am
jameswilson wrote:i Have done more experiemnts on this and yes i can definetly export mpegs but...
James
What is your ffmpeg command line parametres like?
I am using -hq -s cif
I guess the -hq for high quality is the most important thing. Im am getting good video with the previous version of ffmpeg.
zoneminder
Site Admin
Post by zoneminder » Wed Oct 05, 2005 6:33 pm
I'm trying with the CVS ffmpeg now that I can support it, but not getting anywhere as it's complaing about frame rates still. I'm no video expert but will see if I can figure out a way round. There's 100's of options though!
Phil
cordel
Post by cordel » Wed Oct 05, 2005 6:51 pm
The -strict option usualy got the 0.4.9_pre1 version to work. Might try that if you haven't already.
Regards,
Cordel
jameswilson
Post by jameswilson » Wed Oct 05, 2005 6:53 pm
good luck phil!
From you previous post would time be better spent (once its working with a version fully (maybe 0.4.8)) to stick with it and only support that version, unless a real huge reason exits to use newer ones. Or is ffmpeg not the best choice. I dont know im just curious.
JAmes
Cordel: It generates whole videos ok (at poor blocky quality) but wont stream though
zoneminder
Site Admin
Post by zoneminder » Thu Oct 06, 2005 3:05 pm
I've cracked the issue with ffmpeg CVS. Essentially you have to specify the rate twice once before the input files (giving the input rate) and once afterwards (giving your desired output rate, which you put to say 15). That way it's happy to create valid mpegs no matter what the input rate is.
Unfortunately I've had to change a few other things to support this, in fact I've revamped the whole video generation thing a bit. However if you want to try it yourself then the easiest thing to do is edit zmvideo.pl and add a '-r 25' or similar to the ffmpeg command line near the end of the options and after the -i parameter.
I don't really want to stick to an old version of ffmpeg if possiblae as that prevents improvements in features and speed etc from being able to be used. The CVS version now seems to work ok and I must say it seems pretty speedy to me!
Phil
jameswilson
Post by jameswilson » Thu Oct 06, 2005 3:10 pm
Thanks Phill great news.
Will this edit also make pmeg streaming work or does something else need to be edited? And if i edit this zmvideo.pl stop and start zm will take the new values?
James
cordel
Post by cordel » Thu Oct 06, 2005 7:39 pm
Good show and great find Phil :D
James you don't even have to restart zm.
Off to the packaging.... Mmmm, what should we call it?
ffmpeg-0.4.9-20051001.FC?.ctu.i386.rpm should do it.
Regards,
Cordel
jameswilson
Post by jameswilson » Thu Oct 06, 2005 9:36 pm
isnt that a bit confusing i mean, cmon
rpm, wtf is that
lol
James
zoneminder
Site Admin
Post by zoneminder » Sun Oct 09, 2005 11:10 am
Streaming didn't work, but now it does (!) so I think most things are there. As I said, I've taken this opportunity to revamp the web bit of generating videos so there are a few more options to control ffmpeg as everyone wants to do things slightly differently.
Phil
jameswilson
Post by jameswilson » Sun Oct 09, 2005 2:29 pm
sounds great when can we have it?
lol
James
zoneminder
Site Admin
Post by zoneminder » Mon Oct 10, 2005 9:04 pm
Soon hopefully. I'm thinking of just putting out a release with all the bitty stuff I've been doing lately as I'm still not completely done with some of the bigger features.
Phil
jameswilson
Post by jameswilson » Mon Oct 10, 2005 9:12 pm
im drooling, whats coming?
James
cordel
Post by cordel » Mon Oct 10, 2005 9:43 pm
Users browsing this forum: No registered users and 11 guests
