Page 1 of 1
8 port 4 chip bt878
Posted: Mon Jun 13, 2005 9:44 am
by maciekc
It has 8 ports and 4 bt878 chips on it.
I don't know model and brand of the card.
When using 2 inputs from chip the fps is about 4-5(PAL)
Card doesn't work with 2 inputs at chip when capturing with resolution bigger than 352x288 - when I tried inputs gone red on zm main page.
driver bttv card=0,0,0,0
@Phil
I made photos of this card, can you put it on your web server?
Posted: Mon Jun 13, 2005 11:14 am
by jameswilson
have you tried changing both input setting to be identical i have found that on multi input cards everything (colour depth resoltion etc ) has to be the same. You could try dropping Normal fps down to 1 then enableing ignore fps limit in options that way you can share fps bandwidth as long as all inputs dont go onto alarm at the same time
James
Posted: Mon Jun 13, 2005 4:53 pm
by maciekc
My fault - not working with interlaced images. I had simply to small shmall & shmmax values. Now card working perfectly.
