I have then defined 4 monitors:
one with an usb cam, three with a grandtec capture card with no problems.
Opening the monitor watch window in stream mode works all right for each monitor (for the first time !).
Problem: If I close and reopen the same watch window, there is no image anymore; but the image is ok again if I change the scale. Note that when in still mode, the image is always ok for every monitor.
It is the same thing with the montage window.
Where should I look ? (found nothing in the different logs I looked in)
