Page 1 of 1
help in setting network camera
Posted: Fri Feb 25, 2005 5:36 am
by amit
I would like to setup zoneminder to use network camera,
cananyone provide the details for the source tab to be out in for network camera....
I have provided the host ip as 63.243.46.98
port 8081
and path as /axis-cgi/mjpg/video.cgi
but i did'nt get to see anything from the monitor tab...
Earlier it was showing the problem relted with libpcre....
I have solved and now there is no such error in log/messages...
Please provide some help.....
________
iolite reviews
Posted: Fri Feb 25, 2005 9:01 am
by ma77hias
Source Tab I use for an AXIS 2100
Remote Host Name user:password@xxx.xxx.xxx.xxx
Remote Host Port (the port the Webinterface on the camera is set to)
Remote Host Path /axis-cgi/jpg/image.cgi?resolution=640x480
Remote Image Colours 24 bit colour
Capture Width (pixels) 640 (has to match the settings of resolution on the camera path)
Capture Height (pixels) 480
Orientation Normal
I use the jpg/image.cgi path because i was getting substantial time offsets / picture delays in ZM with the video.cgi path. ZM was delievering the pictures with up to an 5 min delay.
start out with a smaller Res (320x240) again this has to match the settings in the path
If it works with 320x240 and not with 640x480, look at your /var/log/messages to see if you get an error like
zm [ can' shmgt value ...... ] which might suggest your shared memory value is to low
Posted: Thu Mar 17, 2005 12:17 pm
by amit
what should be the username and passowrd..
I have one user ashish with password ashish ..
I tried to set it to this but i am not able to see anything..
I even tried with root as user and its password...but nothing happends...
Can you please provide me the details for this...
________
starcraft 2 replays
User and password
Posted: Thu Mar 17, 2005 3:50 pm
by ma77hias
When you connect directly to the camera via your web browser without Zoneminder what login do you use?
Use this login for Zoneminder.
When you use Zoneminder what do your logs say when you try to connect ?
/var/log/messages
zmdc.log
Which AXIS camera model are you using ?
Posted: Thu Mar 17, 2005 10:21 pm
by cordel
