Page 1 of 1
zm-0.9.14 zmschema.sql MIA?
Posted: Thu Jul 10, 2003 9:22 pm
by furrest
zmschema.sql
Couldn't find this file in the zm tarball. Of course this assumes its supposed to be there....
It is 'supposed' to be there? Right?
Re: zm-0.9.14 zmschema.sql MIA?
Posted: Thu Jul 10, 2003 9:26 pm
by zoneminder
Yes it is supposed to be there. In the db directory to be precise. Before you have run zmconfig.pl it will exist as zmconfig.sql.z which is what is in the distribution. Once you run zmconfig.pl it will substitute the database name in there and then you'll get the .sql version.
However I would strongly suggest getting .15 which has just been released to avoid a few hiccups that .14 had in it.
Cheers,
Phil,
Posted: Thu Jul 10, 2003 9:35 pm
by furrest
Phillip,
It was there, i just was having trouble spelling schema , bah!
I went and grabbed 15.
Thanks,
Forrest
