Well, I'm too dumb. I did not try to have a look at the included scripts. I confirm, I tested a couple of them and that's OK. Still, it produces a lot of sql errors? See below. But anyway, that was not the subject and topic is now closed. Thank you a lot for your fast answer!
For dumb people as me, as I have a lot to recover and do not care a lot about what is recovered, I need to type Y or ENTER at the prompt, so I used:
06/21/2025 08:24:08.040088 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (FrameId,Delta,Score,Type,Id,EventId,TimeStamp) VALUES (00259,128.917081594467,0,Normal,undef,2438632,2025-03-30 03:42:19)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
DBD::mysql::st execute failed: Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE) at /usr/share/perl5/ZoneMinder/Object.pm line 267, <> line 14.
06/21/2025 08:24:08.040560 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (TimeStamp,EventId,Type,Id,Score,Delta,FrameId) VALUES (2025-03-30 03:42:19,2438632,Normal,undef,0,129.66508769989,00260)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.041032 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (Type,Id,TimeStamp,EventId,FrameId,Delta,Score) VALUES (Normal,undef,2025-03-30 03:42:20,2438632,00261,129.917089939117,0)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.041504 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (Delta,Score,FrameId,TimeStamp,EventId,Type,Id) VALUES (130.641095876694,0,00262,2025-03-30 03:42:20,2438632,Normal,undef)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.041981 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (FrameId,Delta,Score,Type,Id,EventId,TimeStamp) VALUES (00263,131.673104524612,0,Normal,undef,2438632,2025-03-30 03:42:21)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.042458 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (EventId,TimeStamp,Type,Id,Delta,Score,FrameId) VALUES (2438632,2025-03-30 03:42:21,Normal,undef,131.685104608536,0,00264)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.043391 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (FrameId,Delta,Score,Id,Type,EventId,TimeStamp) VALUES (00265,132.165108680725,0,undef,Normal,2438632,2025-03-30 03:42:22)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.044368 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (TimeStamp,EventId,Id,Type,Delta,Score,FrameId) VALUES (2025-03-30 03:42:22,2438632,undef,Normal,132.649112701416,0,00266)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.045150 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (Score,Delta,FrameId,EventId,TimeStamp,Type,Id) VALUES (0,133.145117044449,00267,2438632,2025-03-30 03:42:23,Normal,undef)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.045910 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (Type,Id,EventId,TimeStamp,FrameId,Delta,Score) VALUES (Normal,undef,2438632,2025-03-30 03:42:23,00268,133.429119348526,0)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
06/21/2025 08:24:08.046605 zmrecover[868141].ERR [ZoneMinder::Object:270] [SQL statement execution failed: (INSERT INTO `Frames` (Type,Id,EventId,TimeStamp,FrameId,Score,Delta) VALUES (Normal,undef,2438632,2025-03-30 03:42:24,00269,0,133.917123317719)):Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
